April 25, 20233 yr i have a tablet on Allwinner A20, I burned Armbian_23.5.0-trunk.134_Lime2_bookworm_edge_6.2.12_xfce_desktop.img.xz into sdcard, it looks like everything is okay, but the tablet work only via HDMI, how to enable the tablet display ?
April 25, 20233 yr Author I get script.bin (script.fex) file from my tablet, how to adopt it to the new Armbian kernel?
May 4, 20233 yr Author Please help, here is the script.bin part for enabling LCD display [disp_init] disp_init_enable = 1 disp_mode = 0 screen0_output_type = 1 screen0_output_mode = 4 screen1_output_type = 1 screen1_output_mode = 4 fb0_framebuffer_num = 2 fb0_format = 10 fb0_pixel_sequence = 0 fb0_scaler_mode_enable = 0 fb0_width = 0 fb0_height = 0 fb1_framebuffer_num = 2 fb1_format = 10 fb1_pixel_sequence = 0 fb1_scaler_mode_enable = 0 fb1_width = 0 fb1_height = 0 lcd0_backlight = 197 lcd1_backlight = 197 lcd0_bright = 50 lcd0_contrast = 50 lcd0_saturation = 57 lcd0_hue = 50 lcd1_bright = 50 lcd1_contrast = 50 lcd1_saturation = 57 lcd1_hue = 50 [lcd0_para] lcd_used = 1 lcd_x = 1024 lcd_y = 600 lcd_width = 155 lcd_height = 85 lcd_dclk_freq = 51 lcd_pwm_not_used = 0 lcd_pwm_ch = 0 lcd_pwm_freq = 10000 lcd_pwm_pol = 1 lcd_pwm_max_limit = 255 lcd_if = 0 lcd_hbp = 158 lcd_ht = 1344 lcd_vbp = 25 lcd_vt = 1270 lcd_vspw = 3 lcd_hspw = 20 lcd_hv_if = 0 lcd_hv_smode = 0 lcd_hv_s888_if = 0 lcd_hv_syuv_if = 0 lcd_lvds_ch = 0 lcd_lvds_mode = 0 lcd_lvds_bitwidth = 0 lcd_lvds_io_cross = 0 lcd_cpu_if = 0 lcd_frm = 1 lcd_io_cfg0 = 0 lcd_gamma_correction_en = 0 lcd_gamma_tbl_0 = 0x0 lcd_gamma_tbl_1 = 0x10101 lcd_gamma_tbl_255 = 0xffffff lcd_bl_en_used = 1 lcd_bl_en = port:PH07<1><0><default><1> lcd_power_used = 1 lcd_power = port:PH08<1><2><default><1> lcd_pwm_used = 1 lcd_pwm = port:PB02<2><0><default><default> lcdd0 = port:PD00<2><0><default><default> lcdd1 = port:PD01<2><0><default><default> lcdd2 = port:PD02<2><0><default><default> lcdd3 = port:PD03<2><0><default><default> lcdd4 = port:PD04<2><0><default><default> lcdd5 = port:PD05<2><0><default><default> lcdd6 = port:PD06<2><0><default><default> lcdd7 = port:PD07<2><0><default><default> lcdd8 = port:PD08<2><0><default><default> lcdd9 = port:PD09<2><0><default><default> lcdd10 = port:PD10<2><0><default><default> lcdd11 = port:PD11<2><0><default><default> lcdd12 = port:PD12<2><0><default><default> lcdd13 = port:PD13<2><0><default><default> lcdd14 = port:PD14<2><0><default><default> lcdd15 = port:PD15<2><0><default><default> lcdd16 = port:PD16<2><0><default><default> lcdd17 = port:PD17<2><0><default><default> lcdd18 = port:PD18<2><0><default><default> lcdd19 = port:PD19<2><0><default><default> lcdd20 = port:PD20<2><0><default><default> lcdd21 = port:PD21<2><0><default><default> lcdd22 = port:PD22<2><0><default><default> lcdd23 = port:PD23<2><0><default><default> lcdclk = port:PD24<2><0><default><default> lcdde = port:PD25<2><0><default><default> lcdhsync = port:PD26<2><0><default><default> lcdvsync = port:PD27<2><0><default><default> [lcd1_para] lcd_used = 0 lcd_x = 0 lcd_y = 0 lcd_dclk_freq = 0 lcd_pwm_not_used = 0 lcd_pwm_ch = 1 lcd_pwm_freq = 0 lcd_pwm_pol = 0 lcd_if = 0 lcd_hbp = 0 lcd_ht = 0 lcd_vbp = 0 lcd_vt = 0 lcd_vspw = 0 lcd_hspw = 0 lcd_hv_if = 0 lcd_hv_smode = 0 lcd_hv_s888_if = 0 lcd_hv_syuv_if = 0 lcd_lvds_ch = 0 lcd_lvds_mode = 0 lcd_lvds_bitwidth = 0 lcd_lvds_io_cross = 0 lcd_cpu_if = 0 lcd_frm = 0 lcd_io_cfg0 = 0 lcd_gamma_correction_en = 0 lcd_gamma_tbl_0 = 0x0 lcd_gamma_tbl_1 = 0x10101 lcd_gamma_tbl_255 = 0xffffff lcd_bl_en_used = 0 lcd_bl_en = lcd_power_used = 0 lcd_power = lcd_pwm_used = 1 lcd_pwm = port:PI03<2><0><default><default> lcd_gpio_0 = lcd_gpio_1 = lcd_gpio_2 = lcd_gpio_3 = lcdd0 = port:PH00<2><0><default><default> lcdd1 = port:PH01<2><0><default><default> lcdd2 = port:PH02<2><0><default><default> lcdd3 = port:PH03<2><0><default><default> lcdd4 = port:PH04<2><0><default><default> lcdd5 = port:PH05<2><0><default><default> lcdd6 = port:PH06<2><0><default><default> lcdd7 = port:PH07<2><0><default><default> lcdd8 = port:PH08<2><0><default><default> lcdd9 = port:PH09<2><0><default><default> lcdd10 = port:PH10<2><0><default><default> lcdd11 = port:PH11<2><0><default><default> lcdd12 = port:PH12<2><0><default><default> lcdd13 = port:PH13<2><0><default><default> lcdd14 = port:PH14<2><0><default><default> lcdd15 = port:PH15<2><0><default><default> lcdd16 = port:PH16<2><0><default><default> lcdd17 = port:PH17<2><0><default><default> lcdd18 = port:PH18<2><0><default><default> lcdd19 = port:PH19<2><0><default><default> lcdd20 = port:PH20<2><0><default><default> lcdd21 = port:PH21<2><0><default><default> lcdd22 = port:PH22<2><0><default><default> lcdd23 = port:PH23<2><0><default><default> lcdclk = port:PH24<2><0><default><default> lcdde = port:PH25<2><0><default><default> lcdhsync = port:PH26<2><0><default><default> lcdvsync = port:PH27<2><0><default><default> Help me to convert it to dtb file
