Antom
  1. Hello, I am using an X96 Air (S905X3) with Armbian (6.1.127-ophub) and I can see the hardware decoder working: v4l2-ctl --list-devices Amlogic Video Decoder (platform:meson-vdec): /dev/video0 However, the hardware encoder (VENC) does not appear: ls /dev/video* /dev/video0 ls /dev/amvenc* ls: cannot access '/dev/amvenc*': No such file or directory I want to use ffmpeg with hardware encoding (h264_v4l2m2m) for real-time RTMP streaming, but without the encoder device, it is not possible. Could you please explain: Does this kernel support VENC on S905X3 at all? If not, what changes are required to enable hardware encoder in the kernel? Is there any instructions or topics ? Any guidance or examples would be very helpful. Thank you!
  2. I did it, so, you say that edge Ubuntu 24.04 have all required drivers for VPU ? that was my question
  3. Hi, I have a TV box with an RK322x chip. I want to use FFmpeg and process video using FFmpeg hardware decoding. Please tell me: do I need to recompile the system/distro build, or does it work out of the box right now? If not, which distribution is better to choose? Please tell me.
  4. Have the same issue, who has a ideas ?
  5. Antom replied to Antom's topic in Amlogic CPU Boxes
    Okay, got it, will use Armbian now but my question is open. Is it possible to boot Armbian from USB ?
  6. A have TVBOX on Amlogic S905l, but this tvbox don't have sdcard, is it possible to boot this board from armbian burned to USB, if yes, can someone share documentation ? I mean to boot from USB before booting from EMMC. I shorted the contacts on the board to disable emmc and I see this message in the TTL logs: GXL:BL1:9ac50e:bb16dc;FEAT:ADFD318C:0;POC:3;RCY:0;EMMC:800;NAND:81;SD:800;USB:8;LOOP:1;EMMC:800;NAND:81;SD:800;USB:8;LOOP:2;EMMC:800;NAND:81;SD:800;USB:8;LOOP:3;EMMC:0;READ:0;0.0;CHK:0; looks like chip is asking for USB, but I'm not sure that it can boot from Maybe I need to create a specific bootable USB? I used an image https://github.com/ophub/amlogic-s9xxx-armbian Link: https://github.com/ophub/amlogic-s9xxx-armbian/releases/download/Armbian_bookworm_save_2025.06/Armbian_25.08.0_amlogic_s905l-mg101_bookworm_6.12.31_server_2025.06.01.img.gz Please help me
  7. have a problem with the same box how to boot from sdcard before boot from emmc ? as I know we need to run as update aml_autoscript file, but how to do that from armbian booted from sd card ?
  8. Thank you! it's really work! wow, my eMMC is dead, os sees the real size of eMMC, but R\W operations are not available. One more question, I have MX10 with an sv6051p wifi chip, but the os is not see any wifi devices, is it possible to turn on sv6051p chip?
  9. wow, good news! just a small clarification, Do you mean pins that turn on maskrom mode? in my side on the other side of the board under emmc. Also another question, what about speed? i guess eMMC is better than sdcard?
  10. one second, if i short the clock ping of eMMC, what are the next steps ? how to boot Armbian from sd card? just flash img to sd card, put it to box and it will boot from sd card ?
  11. it looks like the bootloader is in stock because the multitool is loaded successfully, but I cant burn Armbian to emmc, it is stuck. How can I run Armbian from sdcard ?
  12. One question about my bricked MX10 4\64 GB, is it possible to update by maskrom image of armbian ? i suspect that my mmc is dead, I got Download IDB Failed, one more question, is it possible to boot Armbian from SD CARD if mmc is dead?
  13. Thank you so much! everything is clear for me. another question, where I can find the latest Legacy img ? i guess it is only Debian buster?
  14. So, the case with updating UUID like Hqnicolas say won`t work?
  15. Understood, but how to determine correct UUID ?
