May 15, 20233 yr Currently we get 'sduuid' in form of [[ -z $sdblkid ]] && sdblkid=$(blkid -o full /dev/mmcblk*p1) # 3 - Extract the UUID from $sdblkid via regex: sduuid=$(echo "$sdblkid" | sed -nE 's/^.*[[:space:]]UUID="([0-9a-zA-Z-]*)".*/\1/p') which outputs only UUID 78cdc7b8-0f2e-4444-ba7c-38aa26198de1 This is fine, as long as we use it correctly afterwards, but everytime we modifify fstab, echo "${sduuid} /media/mmcboot ext4 ${mountopts[ext4]}" >> "${TempDir}"/rootfs/etc/fstab echo "/media/mmcboot/boot /boot none bind 0 0" >> "${TempDir}"/rootfs/etc/fstab which results in # <file system> <mount point> <type> <options> <dump> <pass> tmpfs /tmp tmpfs defaults,nosuid 0 0 78cdc7b8-0f2e-4444-ba7c-38aa26198de1 /media/mmcboot ext4 defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 /media/mmcboot/boot /boot none bind 0 0 UUID=52f9b8a6-b6ab-4e81-a362-5c4ca041d539 / ext4 defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide 0 1 Missing "UUID=" and prevents booting correctly. But we cannot simply change sduuid, because on other steps it is used correctly. Maybe make clear which variable has the form of "UUID=XXXXX-XXX-XXXX" in their name, for better understanding, like sduuid for only UUID ("blabla-bla") and sdwuuid für "UUID=blabla-bla". Or use the lazy mode with a check before we modify fstab and add "UUID" as simple string. Example log Spoiler cat /var/log/nand-sata-install.log Sun May 14 11:31:23 PM CEST 2023: Start armbian-install. Old UUID: UUID=78cdc7b8-0f2e-4444-ba7c-38aa26198de1 SD UUID: 78cdc7b8-0f2e-4444-ba7c-38aa26198de1 SATA UUID: UUID=52f9b8a6-b6ab-4e81-a362-5c4ca041d539 eMMC UUID: Boot: $1 Root: $2 /dev/nvme0n1p1 ext4 Usage: 4895 Dest: 44227 /etc/fstab: UUID=78cdc7b8-0f2e-4444-ba7c-38aa26198de1 / ext4 defaults,noatime,commit=600,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 /etc/mtab: /dev/mmcblk1p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0 /dev/nvme0n1p1 /mnt/armbian-install.CyDgPN/rootfs ext4 rw,relatime,stripe=32 0 0 /dev/zram1 /var/log ext4 rw,relatime,discard 0 0 Files currently open for writing: packageki 2313 root 10u REG 179,1 32768 135722 /var/lib/PackageKit/transactions.db colord 2634 colord 5u REG 179,1 16384 135743 /var/lib/colord/mapping.db colord 2634 colord 6u REG 179,1 28672 135744 /var/lib/colord/storage.db colord 2634 colord 7u REG 179,1 28672 135744 /var/lib/colord/storage.db pulseaudi 3063 rock 10u REG 179,1 12288 259682 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-device-volumes.tdb pulseaudi 3063 rock 11u REG 179,1 16384 259683 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-stream-volumes.tdb pulseaudi 3063 rock 12u REG 179,1 12288 259684 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-card-database.tdb evolution 3600 rock 12u REG 179,1 86016 259771 /home/rock/.local/share/evolution/addressbook/system/contacts.db tracker-m 3937 rock 9ur REG 179,1 2809856 259696 /home/rock/.cache/tracker3/files/meta.db tracker-m 3937 rock 10u REG 179,1 41112 266876 /home/rock/.cache/tracker3/files/meta.db-wal tracker-m 3937 rock 11ur REG 179,1 32768 266877 /home/rock/.cache/tracker3/files/meta.db-shm tracker-m 3937 rock 13ur REG 179,1 1294336 259709 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db tracker-m 3937 rock 14u REG 179,1 98912 259981 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db-wal tracker-m 3937 rock 15ur REG 179,1 32768 266879 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db-shm tracker-m 3937 rock 16ur REG 179,1 1425408 259706 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db tracker-m 3937 rock 17u REG 179,1 280192 266880 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db-wal tracker-m 3937 rock 18ur REG 179,1 32768 266881 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db-shm tracker-m 3937 rock 19ur REG 179,1 1294336 259712 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db tracker-m 3937 rock 20u REG 179,1 98912 266882 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db-wal tracker-m 3937 rock 21ur REG 179,1 32768 266883 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db-shm tracker-m 3937 rock 22ur REG 179,1 1294336 259715 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db tracker-m 3937 rock 23u REG 179,1 98912 266885 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db-wal tracker-m 3937 rock 24ur REG 179,1 32768 266886 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db-shm tracker-m 3937 rock 25ur REG 179,1 1372160 259701 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db tracker-m 3937 rock 26u REG 179,1 189552 266887 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db-wal tracker-m 3937 rock 27ur REG 179,1 32768 266888 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db-shm tracker-m 3937 rock 28ur REG 179,1 1294336 259718 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db tracker-m 3937 rock 29u REG 179,1 98912 266889 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db-wal tracker-m 3937 rock 30ur REG 179,1 32768 266890 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db-shm gvfsd-met 3984 rock 9u REG 179,1 32768 259692 /home/rock/.local/share/gvfs-metadata/root-ee3d16b7.log Trying to stop running services to minimize open files: Stopping cron.service Checking again for open files: packageki 2313 root 10u REG 179,1 32768 135722 /var/lib/PackageKit/transactions.db colord 2634 colord 5u REG 179,1 16384 135743 /var/lib/colord/mapping.db colord 2634 colord 6u REG 179,1 28672 135744 /var/lib/colord/storage.db colord 2634 colord 7u REG 179,1 28672 135744 /var/lib/colord/storage.db pulseaudi 3063 rock 10u REG 179,1 12288 259682 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-device-volumes.tdb pulseaudi 3063 rock 11u REG 179,1 16384 259683 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-stream-volumes.tdb pulseaudi 3063 rock 12u REG 179,1 12288 259684 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-card-database.tdb evolution 3600 rock 12u REG 179,1 86016 259771 /home/rock/.local/share/evolution/addressbook/system/contacts.db tracker-m 3937 rock 9ur REG 179,1 2809856 259696 /home/rock/.cache/tracker3/files/meta.db tracker-m 3937 rock 10u REG 179,1 41112 266876 /home/rock/.cache/tracker3/files/meta.db-wal tracker-m 3937 rock 11ur REG 179,1 32768 266877 /home/rock/.cache/tracker3/files/meta.db-shm tracker-m 3937 rock 13ur REG 179,1 1294336 259709 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db tracker-m 3937 rock 14u REG 179,1 98912 259981 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db-wal tracker-m 3937 rock 15ur REG 179,1 32768 266879 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db-shm tracker-m 3937 rock 16ur REG 179,1 1425408 259706 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db tracker-m 3937 rock 17u REG 179,1 280192 266880 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db-wal tracker-m 3937 rock 18ur REG 179,1 32768 266881 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db-shm tracker-m 3937 rock 19ur REG 179,1 1294336 259712 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db tracker-m 3937 rock 20u REG 179,1 98912 266882 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db-wal tracker-m 3937 rock 21ur REG 179,1 32768 266883 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db-shm tracker-m 3937 rock 22ur REG 179,1 1294336 259715 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db tracker-m 3937 rock 23u REG 179,1 98912 266885 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db-wal tracker-m 3937 rock 24ur REG 179,1 32768 266886 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db-shm tracker-m 3937 rock 25ur REG 179,1 1372160 259701 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db tracker-m 3937 rock 26u REG 179,1 189552 266887 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db-wal tracker-m 3937 rock 27ur REG 179,1 32768 266888 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db-shm tracker-m 3937 rock 28ur REG 179,1 1294336 259718 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db tracker-m 3937 rock 29u REG 179,1 98912 266889 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db-wal tracker-m 3937 rock 30ur REG 179,1 32768 266890 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db-shm gvfsd-met 3984 rock 9u REG 179,1 32768 259692 /home/rock/.local/share/gvfs-metadata/root-ee3d16b7.log Copying 149044 files to /dev/nvme0n1p1. Finishing transfer to disk, boot from SD/eMMC Checking again for open files: packageki 2313 root 10u REG 179,1 32768 135722 /var/lib/PackageKit/transactions.db colord 2634 colord 5u REG 179,1 16384 135743 /var/lib/colord/mapping.db colord 2634 colord 6u REG 179,1 28672 135744 /var/lib/colord/storage.db colord 2634 colord 7u REG 179,1 28672 135744 /var/lib/colord/storage.db pulseaudi 3063 rock 10u REG 179,1 12288 259682 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-device-volumes.tdb pulseaudi 3063 rock 11u REG 179,1 16384 259683 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-stream-volumes.tdb pulseaudi 3063 rock 12u REG 179,1 12288 259684 /home/rock/.config/pulse/9e37a4772d8740b5bb96b8e39212a59e-card-database.tdb evolution 3600 rock 12u REG 179,1 86016 259771 /home/rock/.local/share/evolution/addressbook/system/contacts.db tracker-m 3937 rock 9ur REG 179,1 2809856 259696 /home/rock/.cache/tracker3/files/meta.db tracker-m 3937 rock 10u REG 179,1 41112 266876 /home/rock/.cache/tracker3/files/meta.db-wal tracker-m 3937 rock 11ur REG 179,1 32768 266877 /home/rock/.cache/tracker3/files/meta.db-shm tracker-m 3937 rock 13ur REG 179,1 1294336 259709 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db tracker-m 3937 rock 14u REG 179,1 98912 259981 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db-wal tracker-m 3937 rock 15ur REG 179,1 32768 266879 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Documents.db-shm tracker-m 3937 rock 16ur REG 179,1 1425408 259706 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db tracker-m 3937 rock 17u REG 179,1 280192 266880 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db-wal tracker-m 3937 rock 18ur REG 179,1 32768 266881 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Software.db-shm tracker-m 3937 rock 19ur REG 179,1 1294336 259712 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db tracker-m 3937 rock 20u REG 179,1 98912 266882 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db-wal tracker-m 3937 rock 21ur REG 179,1 32768 266883 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Pictures.db-shm tracker-m 3937 rock 22ur REG 179,1 1294336 259715 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db tracker-m 3937 rock 23u REG 179,1 98912 266885 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db-wal tracker-m 3937 rock 24ur REG 179,1 32768 266886 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Audio.db-shm tracker-m 3937 rock 25ur REG 179,1 1372160 259701 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db tracker-m 3937 rock 26u REG 179,1 189552 266887 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db-wal tracker-m 3937 rock 27ur REG 179,1 32768 266888 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23FileSystem.db-shm tracker-m 3937 rock 28ur REG 179,1 1294336 259718 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db tracker-m 3937 rock 29u REG 179,1 98912 266889 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db-wal tracker-m 3937 rock 30ur REG 179,1 32768 266890 /home/rock/.cache/tracker3/files/http%3A%2F%2Ftracker.api.gnome.org%2Fontology%2Fv3%2Ftracker%23Video.db-shm gvfsd-met 3984 rock 9u REG 179,1 32768 259692 /home/rock/.local/share/gvfs-metadata/root-ee3d16b7.log Sun May 14 11:34:21 PM CEST 2023: Finished
May 15, 20233 yr Solution Are you looking at current code in github source? I think this has already been fixed.
May 15, 20233 yr Author Okay, somehow i got lost between the repos, next-gen and 150balbes (. Thanks, let's find out out where I went wrong and what else I might pulled 🙂
