June 4, 20233 yr I have serious issues with the serial number being exposed in /proc/cpuinfo. Especially when browsers have access to this information. Afaik, its u-boot who passed this information on to Linux. Any idea how to mask this from Linux? Your help is appreciated
June 10, 20233 yr Author Well I tried the following, but it did "not" work unfortunately apt install device-tree-compiler then converted the nanopi-r6c device tree from dtb to dts dtc -I dtb -O dts -o rk3588s-nanopi-r6c.dtb rk3588s-nanopi-r6c.dts Inserted a serial-number /dts-v1/; / { compatible = "friendlyelec,nanopi-r6c\0rockchip,rk3588"; interrupt-parent = <0x01>; #address-cells = <0x02>; #size-cells = <0x02>; model = "FriendlyElec NanoPi R6C"; serial-number = "0000000000000000" then converted the nanopi-r6c device tree from dts to dtb dtc -I dts -O dtb -o rk3588s-nanopi-r6c.dts rk3588s-nanopi-r6c.dtb renamed the original .bak and copied the new file into /boot/dtb: sudo mv /boot/dtb/rockchip/rk3588s-nanopi-r6c.dtb /boot/dtb/rockchip/rk3588s-nanopi-r6c.dtb.bak sudo cp rk3588s-nanopi-r6c.dtb /boot/dtb/rockchip/rk3588s-nanopi-r6c.dtb /proc/cpuinfo and /sys/firmware/devicetree/base/serial-number still show the original serial. Maybe someone smarter can pick this up Edited June 10, 20233 yr by Dantes
June 19, 20233 yr Author I found out that OpenWRT does not have this (at least the mj82 build), so I asked there if we could be enlightened: https://forum.openwrt.org/t/nanopi-r6s-linux-6-3-arm-soc-updates/153072/28 Edited June 19, 20233 yr by Dantes
June 20, 20233 yr Author found serial in: /proc/cpuinfo /proc/device-tree/serial-number /sys/firmware/devicetree/base/serial-number https://community.toradex.com/t/cpu-serial-in-proc-cpuinfo-on-imx7/6390 The serial number available in cpuinfo is set by U-Boot from the data available in config block. https://elixir.free-electrons.com/linux/v6.4-rc7/source/arch/arm/kernel/setup.c function that passes serial number to kernel some more info i could find: https://forums.raspberrypi.com/viewtopic.php?t=183474
June 30, 20233 yr Author Booted into u-boot via the usb-c console. I have some issues with the serial setup running minicom/screen. Used the basic settings: 1500000 8N1 and disabled hard/soft flow. But when I dump out with 'printenv' half of the settings appear. Back to the topic. I tried to overwrite the serial to see if it could be done, but no setenv serial# 0000000000000000 I got an error that read-only variables could not be overwritten.
