June 20, 20233 yr Hi. I am working with an Olinuxino A20 micro, but I have issues with the SPI bus. I hope somebody can help me to find a solution. I used Armbian 23.5 Bookworm with kernel 6.1 In sclk signal i have a pulse before to start the data transmission, I required the SPI to communicate a LoRa module but the pulse before of data generate that doesn´t work the LoRa module. I attached the signals.
June 21, 20233 yr On 6/20/2023 at 8:02 PM, Marco Antonio Carbajal said: I used Armbian 23.5 Bookworm with kernel 6.1 Did you try legacy kernel (5.15.y). With 6.1.y many things are wrong ...
