July 13, 20233 yr Can you include the wireguard module in the kernel, please? It's missing from Armbian 23.05.0-trunk Bullseye with Linux 5.4.239-odroidxu4. This is a required module for the Openmediavault Wireguard Plugin to install correctly (using OMV 6.4.9-1 (Shaitan)) However I'm told that omv 6 requires Debian 11 Bullseye so, if there's an existing Armbian build with it, can you let me know, please?
July 16, 20233 yr I think I have a very similar issue. Unable to get Wireguard running on an odroid hc2. Trying to install wireguard-dkms yields to the following output (After pinning debian 11 debs): user@device:~$ sudo apt install wireguard-dkms --reinstall Reading package lists... Done Building dependency tree... Done Reading state information... Done 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded. Need to get 255 kB of archives. After this operation, 0 B of additional disk space will be used. Get:1 http://deb.debian.org/debian bullseye/main armhf wireguard-dkms all 1.0.20210219-1 [255 kB] Fetched 255 kB in 0s (2,296 kB/s) (Reading database ... 68021 files and directories currently installed.) Preparing to unpack .../wireguard-dkms_1.0.20210219-1_all.deb ... Deleting module wireguard-1.0.20210219 completely from the DKMS tree. Unpacking wireguard-dkms (1.0.20210219-1) over (1.0.20210219-1) ... Setting up wireguard-dkms (1.0.20210219-1) ... Loading new wireguard-1.0.20210219 DKMS files... Building for 5.4.243-odroidxu4 6.1.0-10-rt-armmp Module build for kernel 5.4.243-odroidxu4 was skipped since the kernel headers for this kernel do not seem to be installed. Module build for kernel 6.1.0-10-rt-armmp was skipped since the kernel headers for this kernel do not seem to be installed. The reason why it is unable to build the module seems to be a mismatch between the linux image and linux headers: user@device:~$ sudo apt install linux-image-current-odroidxu4 Reading package lists... Done Building dependency tree... Done Reading state information... Done linux-image-current-odroidxu4 is already the newest version (23.05.1--Sf984-Db165-P49bd-C3969H6842-HK01ba-V014b-B9c18). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. user@device:~$ sudo apt install linux-headers-current-odroidxu4 Reading package lists... Done Building dependency tree... Done Reading state information... Done linux-headers-current-odroidxu4 is already the newest version (23.02.2). user@device:~$ uname -a Linux device 5.4.243-odroidxu4 #1 SMP PREEMPT Mon May 22 13:57:29 UTC 2023 armv7l GNU/Linux Any idea how to fix this? Edited July 18, 20233 yr by kbch
July 18, 20233 yr Try using the armbian build script to configure the Linux kernel the way you need it. One of the kernel configurations is "Add wireguard" Here are general instructions on how to recompile the kernel and rebuild the OS image in your PC https://github.com/robertojguerra/orangepi-zero-full-setup/blob/main/README2.md From the wireguard website: https://www.wireguard.com/compilation/ In the linux menuconfig, find: [*] Networking support --> Networking options --> [*] TCP/IP networking [*] IP: WireGuard secure network tunnel [ ] Debugging checks and verbose messages And select "M" for kernel module
