August 28, 20233 yr Hello! I have an issue with my hk1 box. I cannot connect to WiFi. I see a lot of networks but when I trying to connect it says “couldn’t find <BSSID>”. Tried to set static & DHCP IP, factory reset the box and rebooted the router. When I use the LAN cable it works. does anyone have any idea how to further troubleshoot this or have some knowledge or experience?
August 29, 20233 yr There are a lot of tv boxes called hk1. What cpu does your box contain? And what build of armbian are you using?
