Skip to content
View in the app
Armbian Community Forums
Getting stuck generating image
Featured Replies
Aside from the DNS resolution issue I am having (different thread), I am often getting stuck on the following:
Unpacking locales (from .../locales_2.13-38+deb7u8_all.deb) ...
Processing triggers for man-db ...
Setting up locales (2.13-38+deb7u8) ...
Generating locales (this might take a while)...
Generation complete.
  en_US.UTF-8... done
Generation complete.​
It just sits there and nothing further happens. I have left it for 30 minutes or more, and still nothing. I usually end up killing it... rebooting and then restarting. When it does get past this, I typically end up with the debian sources DNS resolution issue which I documented on a different thread.
Any idea what is causing it to get stuck here? I am wondering if this is somehow related to the DNS resolution issue I am having as well.
These problems only started occurring over the last couple days... I never had an issue with image generation before that. I did update to the latest libs a while ago, so I am not sure if something changed that is now contributing to this.
Thanks.
  • Author
I removed the cached root filesystem and got the latest libs files, and I am still getting the same error on the same 2 files viz.
[ error ] Installation failed
Failed to fetch http://httpredir.debian.org/debian/pool/main/libn/libnl/libnl1_1.1-7+b1_armhf.deb Could not resolve 'httpredir.debian.org'
Failed to fetch http://httpredir.debian.org/debian/pool/main/libn/libnl/libnl-dev_1.1-7+b1_armhf.deb Could not resolve 'httpredir.debian.org'
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?​
I noticed the fix you made is for Jessie.... I am running into this problem creating a Wheezy image.
OK, it looks like httpredir is not working well for all. Huh. I'll need to fix this somehow.
In the mean time, check this and manually revert changes to sources.list files before starting to build an image. (clean cache/rootfs)
Which fix do you mean?
  • Author
The fix you mentioned earlier in the thread earlier which shows a change to the debootstrap line.
I will try configuring my sources list manually and seeing how that works.
  • Author
I think I got to the bottom of the problem.... I don't believe it is related to Armbian at all or the httpredir URL.
I think the problem is related to my upgrading pfsense to the latest 2.3 Alpha and one of the firewall rules for DNS starting behaving strangely. I have removed the rule and the problems seemed to have gone away.
Just in case anyone else is running pfsense and running into similar issues....
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
