Skip to content
View in the app
Armbian Community Forums
Orange Pi PC - USB Gadget - usb_f_uac1 playback/capture reversed?
Featured Replies
First time working with usb_f_uac1. Running buster image.
I have a configfs setup that hosts are able to enumerate but the attributes for capture (c_chmask, c_ssize, c_srate) and playback (p_chmask, p_ssize, p_srate) seem to be switched. i.e. c_chmask = 0x3f shows as a 6-channel capture endpoint on both Windows (ksstudio) and macOS (system information) hosts.
Is there something I’m misunderstanding here? Is there something I’m not doing correctly?
Edited by wraiths.patient
  • Author
@Gunjan Gupta good points...
Image:
Orange Pi PC 2.0.8 based on Debian Buster
Kernel:
root@orangepipc:~# uname -a
Linux orangepipc 5.4.65-sunxi #2.0.8 SMP Mon Oct 26 10:20:38 CST 2020 armv7l GNU/Linux
I'm new to armbian - experienced *NIX - I'm unfamiliar with armbianmonitor and which logs exactly would be most helpful here?
  • Author
Figured I'd checkout the actual armbian image using https://redirect.armbian.com/region/NA/orangepipc/Jammy_current
Just FYI, same thing hapeens on armbian... p_* and c_* settings are switched. e.g., setting the playback channel mask to 0x3f (5.1; 6 channels) actually sets the channel mask for what the host enumerates as the capture endpoint so you get a 6-channel microphone.
armbian-monitor -u
https://paste.armbian.com/yadagozohu
configfs configuration script
#!/bin/bash
set -x
# Set up the environment
modprobe libcomposite
cd /sys/kernel/config/usb_gadget/
# Create a new USB gadget
GADGET_DIR="g1"
mkdir -p $GADGET_DIR
cd $GADGET_DIR
# Set basic USB device settings
echo 0x1d6b > idVendor  # Linux Foundation
echo 0x0101 > idProduct # Multifunction Composite Gadget
echo 0x0100 > bcdDevice # v1.0.0
echo 0x0200 > bcdUSB    # USB2
mkdir -p strings/0x409
echo "serialnumber" > strings/0x409/serialnumber
echo "Me Ltd." > strings/0x409/manufacturer
echo "My UAC1 Gadget"      > strings/0x409/product
# Create a configuration
mkdir -p configs/c.1
mkdir -p configs/c.1/strings/0x409
echo "Configuration 1" > configs/c.1/strings/0x409/configuration
echo 250 > configs/c.1/MaxPower
# Add the UAC1 function with specific audio parameters
UAC1_DIR="functions/uac1.usb0"
mkdir -p $UAC1_DIR
echo 0x3f > $UAC1_DIR/p_chmask  # 1 for mono, 3 for stereo
echo 48000 > $UAC1_DIR/p_srate
echo 4 > $UAC1_DIR/p_ssize
# # Capture settings: Mono, 48000 Hz, 16-bit
echo 0x3 > $UAC1_DIR/c_chmask  # 1 for mono, 3 for stereo
echo 48000 > $UAC1_DIR/c_srate
echo 4 > $UAC1_DIR/c_ssize
# Bind the UAC1 function to the configuration
ln -s $UAC1_DIR configs/c.1/
# Enable the gadget
ls /sys/class/udc > UDC
echo "USB Gadget configured."
USB Descriptors enumerated on Windows
    =========================== USB Port2 ===========================
Connection Status        : 0x01 (Device is connected)
Port Chain               : 2-4-2-2
      ========================== Summary =========================
Vendor ID                : 0x1D6B (The Linux Foundation)
Product ID               : 0x0101
USB Version              : 2.0
Port maximum Speed       : High-Speed
Device maximum Speed     : High-Speed
Device Connection Speed  : High-Speed
Self powered             : no
Demanded Current         : 250 mA
Used Endpoints           : 2
      ======================== USB Device ========================
        +++++++++++++++++ Device Information ++++++++++++++++++
Device Description       : USB Composite Device
Device Path              : \\?\USB#VID_1D6B&PID_0101#serialnumber#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Kernel Name              : \Device\USBPDO-16
Device ID                : USB\VID_1D6B&PID_0101\SERIALNUMBER
Hardware IDs             : USB\VID_1D6B&PID_0101&REV_0100 USB\VID_1D6B&PID_0101
Driver KeyName           : {36fc9e60-c465-11cf-8056-444553540000}\0042 (GUID_DEVCLASS_USB)
Driver                   : \SystemRoot\System32\drivers\usbccgp.sys (Version: 10.0.22621.1194  Date: 2023-02-16)
Driver Inf               : C:\Windows\inf\usb.inf
Legacy BusType           : PNPBus
Class                    : USB
Class GUID               : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Service                  : usbccgp
Enumerator               : USB
Location Info            : Port_#0002.Hub_#0005
Location IDs             : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(4)#USB(2)#USB(2), ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS04)#USB(2)#USB(2)
Container ID             : {4ce02247-74d0-5cd6-b2ee-4a880a757088}
Manufacturer Info        : (Standard USB Host Controller)
Capabilities             : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Status                   : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code             : 0
Address                  : 2
HcDisableSelectiveSuspend: 0
EnableSelectiveSuspend   : 0
SelectiveSuspendEnabled  : 0
EnhancedPowerMgmtEnabled : 0
IdleInWorkingState       : 0
WakeFromSleepState       : 0
Power State              : D0 (supported: D0, D2, D3, wake from D0, wake from D2)
 Child Device 1          : AC Interface (USB Audio Device)
  Device Path 1          : \\?\USB#VID_1D6B&PID_0101&MI_00#8&184ce4f3&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global (AM_KSCATEGORY_AUDIO)
  Device Path 2          : \\?\USB#VID_1D6B&PID_0101&MI_00#8&184ce4f3&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global (AM_KSCATEGORY_CAPTURE)
  Device Path 3          : \\?\USB#VID_1D6B&PID_0101&MI_00#8&184ce4f3&0&0000#{65e8773e-8f56-11d0-a3b9-00a0c9223196}\global (AM_KSCATEGORY_RENDER)
  Kernel Name            : \Device\00000dd9
  Device ID              : USB\VID_1D6B&PID_0101&MI_00\8&184CE4F3&0&0000
  Class                  : MEDIA
  Driver KeyName         : {4d36e96c-e325-11ce-bfc1-08002be10318}\0019 (GUID_DEVCLASS_MEDIA)
  Service                : usbaudio
  LocationPaths          : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(4)#USB(2)#USB(2)#USBMI(0)  PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(4)#USB(2)#USB(2)#USB(2)  ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS04)#USB(2)#USB(2)#USBMI(0)  ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS04)#USB(2)#USB(2)#USB(2)
   Child Device 1        : Speakers (5- AC Interface) (Audio Endpoint)
    Device ID            : SWD\MMDEVAPI\{0.0.0.00000000}.{CBD53598-1B0C-4348-A8DC-9D0E1E971B9E}
    Class                : AudioEndpoint
    Driver KeyName       : {c166523c-fe0c-4a94-a586-f1a80cfbbf3e}\0056 (AUDIOENDPOINT_CLASS_UUID)
   Child Device 2        : Capture Input terminal (5- AC Interface) (Audio Endpoint)
    Device ID            : SWD\MMDEVAPI\{0.0.1.00000000}.{5B1781AE-C053-4604-A488-8D1C3203C210}
    Driver KeyName       : {c166523c-fe0c-4a94-a586-f1a80cfbbf3e}\0055 (AUDIOENDPOINT_CLASS_UUID)
        +++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\1D6B01010100
 osvc                    : REG_BINARY 00 00
        ---------------- Connection Information ---------------
Connection Index         : 0x02 (Port 2)
Connection Status        : 0x01 (DeviceConnected)
Current Config Value     : 0x01 (Configuration 1)
Device Address           : 0x1C (28)
Is Hub                   : 0x00 (no)
Device Bus Speed         : 0x02 (High-Speed)
Number Of Open Pipes     : 0x01 (1 pipe to data endpoints)
Pipe[0]                  : EndpointID=1  Direction=IN   ScheduleOffset=0  Type=Interrupt  wMaxPacketSize=0x2     bInterval=4   -> 140 Bits/ms = 17500 Bytes/s
Data (HexDump)           : 02 00 00 00 12 01 00 02 00 00 00 40 6B 1D 01 01   ...........@k...
                           00 01 01 02 03 01 01 02 00 1C 00 01 00 00 00 01   ................
                           00 00 00 07 05 81 03 02 00 04 00 00 00 00         ..............
        --------------- Connection Information V2 -------------
Connection Index         : 0x02 (2)
Length                   : 0x10 (16 bytes)
SupportedUsbProtocols    : 0x03
 Usb110                  : 1 (yes, port supports USB 1.1)
 Usb200                  : 1 (yes, port supports USB 2.0)
 Usb300                  : 0 (no, port not supports USB 3.0)
 ReservedMBZ             : 0x00
Flags                    : 0x00
 DevIsOpAtSsOrHigher     : 0 (Device is not operating at SuperSpeed or higher)
 DevIsSsCapOrHigher      : 0 (Device is not SuperSpeed capable or higher)
 DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
 DevIsSsPlusCapOrHigher  : 0 (Device is not SuperSpeedPlus capable or higher)
 ReservedMBZ             : 0x00
Data (HexDump)           : 02 00 00 00 10 00 00 00 03 00 00 00 00 00 00 00   ................
    ---------------------- Device Descriptor ----------------------
bLength                  : 0x12 (18 bytes)
bDescriptorType          : 0x01 (Device Descriptor)
bcdUSB                   : 0x200 (USB Version 2.0)
bDeviceClass             : 0x00 (defined by the interface descriptors)
bDeviceSubClass          : 0x00
bDeviceProtocol          : 0x00
bMaxPacketSize0          : 0x40 (64 bytes)
idVendor                 : 0x1D6B (The Linux Foundation)
idProduct                : 0x0101
bcdDevice                : 0x0100
iManufacturer            : 0x01 (String Descriptor 1)
 Language 0x0409         : "Me Ltd."
iProduct                 : 0x02 (String Descriptor 2)
 Language 0x0409         : "My UAC1 Gadget"
iSerialNumber            : 0x03 (String Descriptor 3)
 Language 0x0409         : "serialnumber"
bNumConfigurations       : 0x01 (1 Configuration)
Data (HexDump)           : 12 01 00 02 00 00 00 40 6B 1D 01 01 00 01 01 02   .......@k.......
                           03 01                                             ..
    ------------------ Configuration Descriptor -------------------
bLength                  : 0x09 (9 bytes)
bDescriptorType          : 0x02 (Configuration Descriptor)
wTotalLength             : 0x00D7 (215 bytes)
bNumInterfaces           : 0x03 (3 Interfaces)
bConfigurationValue      : 0x01 (Configuration 1)
iConfiguration           : 0x04 (String Descriptor 4)
 Language 0x0409         : "Configuration 1"
bmAttributes             : 0x80
 D7: Reserved, set 1     : 0x01
 D6: Self Powered        : 0x00 (no)
 D5: Remote Wakeup       : 0x00 (no)
 D4..0: Reserved, set 0  : 0x00
MaxPower                 : 0x7D (250 mA)
Data (HexDump)           : 09 02 D7 00 03 01 04 80 7D 09 04 00 00 01 01 01   ........}.......
                           00 05 0A 24 01 00 01 56 00 02 01 02 0C 24 02 01   ...$...V.....$..
                           01 01 00 02 03 00 07 06 09 24 03 03 01 03 00 05   .........$......
                           08 0D 24 06 05 01 02 03 00 00 00 00 00 0D 0C 24   ..$............$
                           02 02 01 02 00 06 3F 00 0A 09 09 24 03 04 01 01   ......?....$....
                           00 06 0B 15 24 06 06 02 02 03 00 00 00 00 00 00   ....$...........
                           00 00 00 00 00 00 00 0C 07 05 81 03 02 00 04 09   ................
                           04 01 00 00 01 02 00 0E 09 04 01 01 01 01 02 00   ................
                           0F 07 24 01 01 01 01 00 0B 24 02 01 02 04 20 01   ..$......$.... .
                           80 BB 00 09 05 01 09 C8 00 04 00 00 07 25 01 01   .............%..
                           01 01 00 09 04 02 00 00 01 02 00 10 09 04 02 01   ................
                           01 01 02 00 11 07 24 01 04 01 01 00 0B 24 02 01   ......$......$..
                           06 04 20 01 80 BB 00 09 05 82 05 C8 00 04 00 00   .. .............
                           07 25 01 01 00 00 00                              .%.....
        ---------------- Interface Descriptor -----------------
bDescriptorType          : 0x04 (Interface Descriptor)
bInterfaceNumber         : 0x00 (Interface 0)
bAlternateSetting        : 0x00
bNumEndpoints            : 0x01 (1 Endpoint)
bInterfaceClass          : 0x01 (Audio)
bInterfaceSubClass       : 0x01 (Audio Control)
bInterfaceProtocol       : 0x00
iInterface               : 0x05 (String Descriptor 5)
 Language 0x0409         : "AC Interface"
Data (HexDump)           : 09 04 00 00 01 01 01 00 05                        .........
        ------ Audio Control Interface Header Descriptor ------
bLength                  : 0x0A (10 bytes)
bDescriptorType          : 0x24 (Audio Interface Descriptor)
bDescriptorSubtype       : 0x01 (Header)
bcdADC                   : 0x0100
wTotalLength             : 0x0056 (86 bytes)
bInCollection            : 0x02
baInterfaceNr[1]         : 0x01
baInterfaceNr[2]         : 0x02
Data (HexDump)           : 0A 24 01 00 01 56 00 02 01 02                     .$...V....
        ------- Audio Control Input Terminal Descriptor -------
bLength                  : 0x0C (12 bytes)
bDescriptorSubtype       : 0x02 (Input Terminal)
bTerminalID              : 0x01
wTerminalType            : 0x0101 (USB Streaming)
bAssocTerminal           : 0x00
bNrChannels              : 0x02 (2 channels)
wChannelConfig           : 0x0003 (L, R)
iChannelNames            : 0x07 (String Descriptor 7)
 Language 0x0409         : "Playback Channels"
iTerminal                : 0x06 (String Descriptor 6)
 Language 0x0409         : "Playback Input terminal"
Data (HexDump)           : 0C 24 02 01 01 01 00 02 03 00 07 06               .$..........
        ------- Audio Control Output Terminal Descriptor ------
bDescriptorSubtype       : 0x03 (Output Terminal)
bTerminalID              : 0x03
wTerminalType            : 0x0301 (Speaker)
bAssocTerminal           : 0x00 (0)
bSourceID                : 0x05 (5)
iTerminal                : 0x08 (String Descriptor 8)
 Language 0x0409         : "Playback Output terminal"
Data (HexDump)           : 09 24 03 03 01 03 00 05 08                        .$.......
        -------- Audio Control Feature Unit Descriptor --------
bLength                  : 0x0D (13 bytes)
bDescriptorSubtype       : 0x06 (Feature Unit)
bUnitID                  : 0x05 (5)
bSourceID                : 0x01 (1)
bControlSize             : 0x02 (2 bytes per control)
bmaControls[0]           : 0x03, 0x00
 D0: Mute                : 1
 D1: Volume              : 1
 D2: Bass                : 0
 D3: Mid                 : 0
 D4: Treble              : 0
 D5: Graphic Equalizer   : 0
 D6: Automatic Gain      : 0
 D7: Delay               : 0
 D8: Bass Boost          : 0
 D9: Loudness            : 0
 D10: Reserved           : 0
 D11: Reserved           : 0
 D12: Reserved           : 0
 D13: Reserved           : 0
 D14: Reserved           : 0
 D15: Reserved           : 0
bmaControls[1]           : 0x00, 0x00
 D0: Mute                : 0
 D1: Volume              : 0
 D2: Bass                : 0
 D3: Mid                 : 0
 D4: Treble              : 0
 D7: Delay               : 0
 D8: Bass Boost          : 0
 D9: Loudness            : 0
 D10: Reserved           : 0
 D11: Reserved           : 0
 D12: Reserved           : 0
 D13: Reserved           : 0
 D14: Reserved           : 0
 D15: Reserved           : 0
bmaControls[2]           : 0x00, 0x00
 D0: Mute                : 0
 D1: Volume              : 0
 D2: Bass                : 0
 D3: Mid                 : 0
 D4: Treble              : 0
 D7: Delay               : 0
 D8: Bass Boost          : 0
 D9: Loudness            : 0
 D10: Reserved           : 0
 D11: Reserved           : 0
 D12: Reserved           : 0
 D13: Reserved           : 0
 D14: Reserved           : 0
 D15: Reserved           : 0
iFeature                 : 0x0D (String Descriptor 13)
 Language 0x0409         : "Playback Volume"
Data (HexDump)           : 0D 24 06 05 01 02 03 00 00 00 00 00 0D            .$...........
bTerminalID              : 0x02
wTerminalType            : 0x0201 (Microphone)
bNrChannels              : 0x06 (6 channels)
wChannelConfig           : 0x003F (L, R, C, LFE, LS, RS)
iChannelNames            : 0x0A (String Descriptor 10)
 Language 0x0409         : "Capture Channels"
iTerminal                : 0x09 (String Descriptor 9)
 Language 0x0409         : "Capture Input terminal"
Data (HexDump)           : 0C 24 02 02 01 02 00 06 3F 00 0A 09               .$......?...
bTerminalID              : 0x04
bSourceID                : 0x06 (6)
iTerminal                : 0x0B (String Descriptor 11)
 Language 0x0409         : "Capture Output terminal"
Data (HexDump)           : 09 24 03 04 01 01 00 06 0B                        .$.......
USB Descriptors enumerated on macOS
Playback Inactive:
  Default Output Device:	Yes
  Default System Output Device:	Yes
  Manufacturer:	Me Ltd.
  Output Channels:	2
  Current SampleRate:	48000
  Transport:	USB
  Output Source:	Default
Capture Inactive:
  Input Channels:	6
  Transport:	USB
  Input Source:	Default
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
