January 22, 20242 yr hi I've been using the flag compile.sh PREFER_DOCKER=no while building in a systemd-nspawn container: Building Armbian using Ubuntu (jammy) in a systemd-nspawn container This time I managed to make a complete successful build with my work arounds for loop devices in systemd nspawn. However, the flag PREFER_DOCKER=no Didn't seem to be documented in the build options https://docs.armbian.com/Developer-Guide_Build-Options/ can the documentation be updated to add PREFER_DOCKER=no flag (at least under 'advanced users') ? note that it isn't possible to run docker normally within systemd-nspawn or that it'd require all those workarounds such as patching and using the host docker server which defeats the purpose of using docker. rather systemd-nspawn is the container to at least decouple the build environment from the host os environment (which can be a different linux distribution, I'm doing so from OpenSuse https://www.opensuse.org/), with the unfortunate caveat that loop devices still requires a workaround.
January 22, 20242 yr Whole documentation is needs updates. Like all the build switches (kernel, kernel-config, uboot,...) are missing...
January 22, 20242 yr There is ongoing activity to set some top level re-design and prepare ground base. I doubt random person would start to do that, so this is what we have to do. I also already answered on similar topic in Documentation tickets: https://github.com/armbian/documentation/issues/390
