Skip to content
View in the app
Armbian Community Forums
use push button on orange pi, via GPIO
Featured Replies
Hy guys
i want to use a push button on my orange pi.
if i press the button, the orange pi should run a script.
i only use esp8266 with arduino tu create some interactive tools.
does anybody know, how it works on the orange pi and which cheapy button you would prefer?
i only want to run sh script, when the button will be press.
thank you a lot!
Solved by usual user
  • Solution
How to wait for a button press is outlined here.
If you want to be able to write code that is device-agnostic, you'll need to set up generic gpio-line-names.
See here for reference.
With that in place e.g.:
gpiomon --num-events=1 con1-08 && my-script
will be able to run on any device that has the gpio-line-names set up in the same way.
I.e. will wait at pin 8 of the first extention connector for an event.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
