Skip to content
View in the app
Armbian Community Forums
Odroid C4 is using HC4 dtb and odroidhc4 packages
Featured Replies
Hello
I'm running debian bullseye on an Odroid C4 since quite some time now and decided it was a good time to upgrade to bookworm.
When I first installed armbian on this board, I remember that I had to install the Odroid HC4 image. If I'm not mistaking, there were no C4 image at the time.
After upgrading my current bullseye firmware with armbian-config ( and by passing the SSD issue described in this armbian forum post by hot plugging it ), I noticed that /boot/armbianEnv.txt had this line:
fdtfile=amlogic/meson-sm1-odroid-hc4.dtb
whereas the amlogic/meson-sm1-odroid-c4.dtb file exists in the /boot/dtb directory.
Despite having read that HC4 and C4 were the same board with few differences, dtdiff shows a lot of settings differ between the dtb of the two boards.
Similarly, I notice that a bunch of *odroidc4 packages are now present in the repository that I don't remember having seen when I first installed armbian.
So before upgrading to bookworm, I was wondering if it would be a good or bad idea to modify the armbianEnv.txt in order to use the C4 dtb, and replace the *odroidhc4 packages by their *odroidc4 equivalents.
Did someone already try these changes ?
Does someone see any issue with applying this changes ?
Will there be other changes to apply in order to fully migrate from the initial HC4 configuration to a possibly more appropriate C4 configuration ?
Thanks for your time and answers.
Solved by spleeth
  • Author
  • Solution
To anyone this may help, removing hc4 related packages and replacing them with c4 packages did the job.
Only to discover that, for whatever reason, I actually had an HC4 board and convince myself that it was a C4 ...
Anyway, the reverse process also worked as expected and my board is now running 25.051.1 happily, except for the samsung SSD not recognized at boot, and requires to be hot plugged just after the linux kernel starts in order to be seen by the system, as it is described in other threads.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
