March 11, 20242 yr Hi Folks, I have a NanoPi NEO Air with Armbian Bookworm. Previously I was running Armbian 23.11.1 Bookworm with Linux 6.1.63-current-sunxi, but after an apt upgrade I am now with Armbian 24.2.1 Bookworm with Linux 6.6.16-current-sunxi. With this latest upgrade I completely lost the USB console feature which for my application is a MUST. How can I fix it? Have a nice day, Mattia
March 11, 20242 yr I have same problem, when i solder usb-uart external (by ft232) i can see that my nano still working.... I try find it in armbian-config but but any sucsess....
March 11, 20242 yr Author Luckly I'm still able to connect to the nanopi over wifi ssh otherwise I could be totally lost. I hope some Developer have an idea on what's going on.
March 11, 20242 yr 9 hours ago, Mattia Giurato said: How can I fix it? The quick fix is to use armbian-config to go back to the older working kernel, and then freeze kernel updates.
March 12, 20242 yr Oк, thnx, i try to do this.... So usb work fine, but i have error in armbian-config - install/update bootloader. i cant enter to this menu, something going wrong arfer update . So i steel doing to 23+ version, and wait when it fix ) Edited March 12, 20242 yr by Aknot
