Skip to content
View in the app
Armbian Community Forums
Efforts to develop firmware for Transpeed 8K Ultra HD MX10 RK3528 BOX
Featured Replies
Purchase Link
This should be a fun one.
Bought the 4GB/128GB variant.
AP6330 Wifi
Stock software is a really, really bad Android TV port.  Looks like a Google Pixel 5 image that has had RK3528 support hacked into it.  Some parts report the device as Pixel 5, others MX10.
RKdumper wouldn't work.
Wifi is hardcoded to China region in the kernel commandline, so wifi doesn't work in North America.  Boots into a setup wizard that can't be closed, and forces an internet connection.  Since wifi is broken out of the box, had to use ethernet to get past the setup wizard.
Transpeed does not have a website or offer stock firmware.  The vendor I purchased it from refused to supply a stock image.
Image was pre-rooted, so used ethernet+adb to adb pull the entire flash chip.  Unfortunately the Android partitions appear to be encrypted and only show gibberish directory names.  Was able to use extract-dtb on one of the raw binary partitions to get the stock DTB, which is all I cared about anyway.  It is pretty close to an existing one in Armbian (rk3528-demo1-lp4-v10)
Located and soldered the tiny UART pads without destroying the box.
Tried my different garbage clone USB UART adapters to find one that could handle RockChip 1.5 megabit over serial, fake CH340G did the job, fake CP2102 would not.  May the best fake product win!
Followed @Hqnicolas guidance from this thread and used the hinlink-h28k trunk release with 5.10 kernel as a base, and changed the dtb referenced in armbianenv to the stock android DTB extracted from the device, and of course it would not boot.  Lots of errors, kernel panics on UART, errors from SD reader.
Changed to Kernel 6.1 base hinlink-h28k image, and tried rk3528-demo1-lp4-v10.dtb, that one almost boots but doesn't see the SD card so can't mount root filesystem.
Began DTB surgery, added pieces of the SD card initialization from the factory DTB to the rk3528-demo1-lp4-v10.dtb, got it to boot.  Black USB port dead, Blue USB port working.  No HDMI output on console (only UART)  but does load XFCE when the GUI autostarts.
Will keep slicing and dicing DTB to gain functions.  Will need to drop in proper NVRAM file to get AP6330 working as I've had to do on other boards.
	//rk3528-demo1-lp4-v10.dts  SD Not Detected
	mmc@ffc30000 {
		compatible = "rockchip,rk3528-dw-mshc\0rockchip,rk3288-dw-mshc";
		reg = <0x00 0xffc30000 0x00 0x4000>;
		interrupts = <0x00 0x85 0x04>;
		max-frequency = <0x8f0d180>;
		clocks = <0x02 0x198 0x02 0x197 0x7a 0x01 0x7a 0x02>;
		clock-names = "biu\0ciu\0ciu-drive\0ciu-sample";
		fifo-depth = <0x100>;
		resets = <0x02 0x2a9>;
		reset-names = "reset";
		rockchip,use-v2-tuning;
		status = "disabled";
		phandle = <0x10e>;
//Factory DTB - SD reader stuck Busy, can't select voltage etc.
	mmc@ffc30000 {
		clocks = <0x02 0x198 0x02 0x197 0x68 0x01 0x68 0x02>;
        //status = "disabled"
		status = "okay";
		bus-width = <0x04>;
		cap-mmc-highspeed;
		cap-sd-highspeed;
		disable-wp;
		pinctrl-names = "default";
		pinctrl-0 = <0x6d 0x6e 0x6f 0x70>;
		rockchip,default-sample-phase = <0x5a>;
		supports-sd;
		sd-uhs-sdr12;
		sd-uhs-sdr25;
		sd-uhs-sdr50;
		sd-uhs-sdr104;
		phandle = <0xff>;
//Combo that works enough to boot
	mmc@ffc30000 {
		//clocks = <0x02 0x198 0x02 0x197 0x7a 0x01 0x7a 0x02>;
		//status = "disabled";
		//from stock dtb
		status = "okay";
		bus-width = <0x04>;
		//cap-mmc-highspeed;
		//cap-sd-highspeed;
		disable-wp;
		//rockchip,default-sample-phase = <0x5a>;
		supports-sd;
		//sd-uhs-sdr12;
		//sd-uhs-sdr25;
		//sd-uhs-sdr50;
		//sd-uhs-sdr104;
		//end from stock dtb
		phandle = <0x10e>;
rk3528-transpeed-8k-ultra-hd-mx10.dts
  • Author
wifi operational with:
ln -sf /lib/firmware/brcm/brcmfmac4330.bin /lib/firmware/brcm/brcmfmac4330-sdio.rockchip,rk3528-demo1-lp4-v10.bin
ln -sf /lib/firmware/brcm/brcmfmac-ap6330-sdio.txt /lib/firmware/brcm/brcmfmac4330-sdio.rockchip,rk3528-demo1-lp4-v10.txt
and a reboot, then nmtui to set up a connection
Nice!
Enable SDHCI + emmc1 + emmc2 + emmc3
on DTS and recompile
Check if usb*_dphy it's OTG or HOST on DTS
Edited by Hqnicolas
Hi Pessimism,
I have  this box ( purchased from same vendor) it worked well for me,.....since I've mistakenly deleted the build.prop file in root/system. Would you mind to send me the file?
Tks for your help.
Regards Pietro
Olà Farlei,
Thanks for your prompt reply. I do not need the complete archive .If you have the TV box , then you can copy the bulid.prop file( it's a text file) from root/system with ES explorer or any other file management apk.
Thanks again
  • Author
Updated wireless enablement, use ap6330 files for both firmware and nvram, I goofed and didn't see it before:
mv ./brcmfmac4330-sdio.bin ./brcmfmac4330-sdio.bin.org
ln -sf ./brcmfmac-ap6330-sdio.bin brcmfmac4330-sdio.bin
ln -sf ./brcmfmac-ap6330-sdio.bin brcmfmac4330-sdio.rockchip,rk3528-demo1-lp4-v10.bin
ln -sf ./brcmfmac-ap6330-sdio.txt brcmfmac4330-sdio.rockchip,rk3528-demo1-lp4-v10.txt
Performance is still quite slow.  May be more DTB work needed for it.  Though it is only an SDIO connected single-stream, single-band 2.4/5.8 wireless N adapter with a top speed of 72 megabit, so we can't be asking for miracles here.  The internal antenna is also just a tiny piece of stamped steel soldered to the PCB.
Also edit the NVRAM file (brcmfmac-ap6330-sdio.txt) and change ccode=ALL to your country code
Edited by pessimism
I think this is the top performance.
you can swap to android and benchmark VPU, GPU, WIFI, LAN, CPU.
and bring this tests to the forum.
after that. you can compare if you reach 100% of performance
  • Author
I think you're right.  I can't easily test using the factory image as its wifi was hardcoded to China region in the kernel commandline so the channels don't work in north america, i had to string a 50 foot ethernet cable just to sign into the thing
hilarious they put 8K on the case of this thing, I doubt the wifi would stream 720P stably let alone 8K
I think the wifi component may be used and salvaged, the RF shielding over it is discolored and has dents in it, like it was heated and pulled off another device
Edited by pessimism
Hello, unfortunately I bought the same box, I would like to test armbian.
Could you give me more hint for downloading and starting the image?
I think I can manage the dts and links thing.
Many thanks
Riccardo
On 5/23/2024 at 2:16 AM, pessimism said:
I had the same issue, but after that I download DQ08 android tv box firmware from china gadget review and uploaded to my transpeed 8k android box via factory driver tool. Now the problem is solved and everything is working much better than previous.
@pessimism want are the PINouts of this board? I see you have connected to it with UART. Can you please map RX/TX/GND to GREY/WHITE/BLACK based on you photo.
I have tried CP2102 usb adaptor, looks like same case as you had - no transmission on 1.5Mb speed. Meanwhile ordered CH340G.
I'm using debian, no access to windows. with RX-TX locked adapter sends echos, but no data from box. will tryCH340G once it arrives, cause I saw in this post was same issue.
Meanwhile, I have enabled ADB and debugging over wifi, and have connected to cli:
127|rk3528_box:/ $ uname -a
Linux localhost 5.10.157-ab10 #319 SMP PREEMPT Sat Nov 11 21:49:28 CST 2023 aarch64 Toybox
I think it is possible to copy firmware image from ADB session. If someone did/have instructions please point here.
kernel_ramfs is located at /dev/block/mmcblk2p6
Have extracted with dd and copying through wifi adb.
Interesting usb debugging is enabled in tvbox, but when connecting usb v3 cable to tvbox, host machine does not see the 'adb device', adb connection over wifi is ok.
Has anybody used USB adb on this device?
Hello, finally CH340G usb-uart has arrived - I have checked it performs data transfer on 1.5M speed in RX/TX loop normally.
But when connecting to board - there is no output to console at all. Have tried RX/TX changing still no output, just regular start of android TV box.
Please suggest does UART needs to be enabled in some screen/menu?
update: if disconnect TX from USB-UART adaptor - then there is infinite output that changes every microsecond with more strings:
ESC[1;47rESC[46;1H[   45.827723][    Tible6] [dhd-wlan0] w l_ext_iapsta_evefs.readdy=1 (/system/etcb/init/hw/init.uo sr not foun db^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1Hnt : [S] Link UP with c8::ca:98^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1HESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H[   45.827747][    T6] [dhd-wlan0] wconsole:/ $ ^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1Hl_notify_connect_status : wl_bss_conn.127^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1Hect_done succeeded with c8:ca:98 ^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H[   45.843270][    T6] [dhd-wlan0] wl_notify_connect_sonso le:/ $ c^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1Htatus : wl_bss_connect_done succeeded127|^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H with c8:7f:54:e0:ca:98 vndr_oui: 00-90-127|^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H4C 00-0C-43 00-0C-E7 ^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H[   45.881840][  T165] type=1400 audit(1699712132.610:14conssole:/ $ ^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H4): avc: denied { open } for comm="FD655_Demo" path="/sys/class/fd655/fd65console:/ $ ^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H5_vpause_127|y^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1Hflag" dev="s127fig=|^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1Hysfs" ino=19647 sc[   82.040633][  T386] read descriptors^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H[   82.040698][  T386] read strings^MESC[1;46rESC[46;1H
ESC[1;47rESC[46;1H[   82.043097][    T1] init: processing action (sys.usb.config=adb && sys.usb.configfs=1 && sys.usb.ffs.ready=1) f82.045159][    T1] init: Co
mmand 'symlink /coESC[46;159HnESC[46;159HfESC[46;159HiESC[46;159HgESC[46;159H
But still no active shell session
I have resolved the problem with UART communication - was soldering point between TX and capacitor on board, so after desoldering connection through UART works.
Armbian does not boot from USB via flash-drive, but when writing it to SDCard - I see start of the system, but it hungs on "Starting kernel"
Adding boot logs:
DDR V1.05 4bit PCB 2eef4a672d huan.he 23/04/14-10:58:56
LP4/4x derate disable, other dram:1x trefi
ddrconfig:15
DDR3, 324MHz
BW=32 Col=11 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: 626ps, dqs1: 482ps, dqs2: 723ps, dqs3: 723ps,
change to: 324MHz
clk skew:0x64
change to: 528MHz
clk skew:0x64
change to: 666MHz
clk skew:0x64
change to: 786MHz(final freq)
clk skew:0x64
PHY drv:clk:50,ca:28,DQ:40,odt:145
vrefinner:50%, vrefout:50%
dram drv:34,odt:60
cs 0:
the read training result:
DQS0:0x5b, DQS1:0x51, DQS2:0x53, DQS3:0x53,
min  : 0x6 0x13 0x10 0x10 0x10  0x2  0x1  0x6 , 0x8  0x8  0x4  0x3  0x5  0x4  0x2  0x2 ,
       0x7   0x5  0x1  0x6 , 0x2 0x10 0x10  0x3 0x13  0x5 0x12  0x6 ,
mid 0x2f 0x2f 0x29 0x29 0x2b 0x2a 0x29 0x27 ,
      0x2a 0x32 0x2e  0x29 0x3b 0x2c 0x39 0x2d ,
max  :0x56 0x65 0x60 0x5f 0x62 0x52x50 0x50 0x4d ,
      0x4d 0x5a 0x54 0x56 0x57 0x4c 0x4f 0x54 ,,
range:0x50 0x52 0x50 0x4f 0x52 0x50 0x50 0x4e ,0x4e 0x4e 0x4b0x50 0x4c 0x51 0x4f 0x47 0x4e 0x4e ,0x4c 0x4f 0x50 0x4c 0x51 0x4:
DQS0:0xa2, DQS1:0x94, DQS2:0xac, DQS3:0xac,
min  :0x83 0x8ab 0x7a 0x79 0x78 0x74 0x73 0x73 0x73 0x79 ,
      0x8f 0x96 0x95 0x96 0x8d 0x98 0x90 0x97 0x92 0x93 ,
mid  :0x9d 0xa5 0xa2 0xax94 0x92 0x90 0x8e 0x8d 0x8c 0x95 ,
      0xa8 0xaf 0xab 0xac 0xa9 0xb4 0xab 0xb1 0xad 0xb0 ,
max  :0xb8 0xc1 0xbb 0xbb 0xbd 0 0xac 0xa9 0xa8 0xa6 0xb1 ,
      0xc1 0xc9 0xc4 0xc7 0xc6 0xbdd0 0xc6 0xcc 0xc9 0xce ,
range:0x35 0x37 0x31 0x32 0x35 0x36 0x0x36 0x35 0x33 0x38 ,
      0x32 0x33 0x31 0x36 0x32 0x2f 0x37 0x35 0x37 0x3b ,
out
U-Boot SPL board init
U-Boot SPL 2017.09-g0fbedd0675-230404 #zyf (Apr 11 2023 - 09:25:18)
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
No misc partition
spl: partition error
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00080000 ... sha256(2493d19c1e...) + OK
## Checking uboot 0x00200000 ... sha256(01c15fcf12...) + OK
## Checking fdt 0x00308958 ... sha256(2867f75977...) + OK
## Checking atf-2 0xfe48d000 ... sha256(8ce3689111...) + OK
## Checking atf-3 0xfe490000 ... sha256(bc35c9ef85...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00080000)
Total: 334.426 ms
INFO:    Preloader serial: 0
NOTICE:  BL31: v2.3():v2.3-679-geda1f5ce4:cl, fwver: v1.17
NOTICE:  BL31: Built : 23:57:18, Dec 20 2023
INFO:    rk_otp_init finish!
INFO:    ARM GICv2 driver initialized
INFO:    nonboot_cpus_off: clst_st=0xc0e, core_st=0xe1e0 boot_cpu=0
INFO:    dfs].freq_mhz= 786MHz
INFO:    dfs DDR fsp_param[1].freq_mhz= 324MDR fsp_param[3].freq_mhz= 666MHz
INFO:    idle_st=0x0, pd_st=0xask: 1
INFO:    RK3528 SoC (0x101)
INFO:    BL31: Initializing runtime services
WARNING: No OPTE provided by BL2 boot loader, Booting device without OPTEE init Error initializing runtime service opteed_fast
INFO:    BL31: dress = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-armbian-2017.09-S3264-Pda90-H7573-V3999-Bb703-R448a (May 13 2025 - 12:27:23 +0300)
Model: Rockchip RK3528 Evaluation Board
MPIDR: 0x80000000
PreSerial: 0, raw, 0xff9f003.9 GiB
Sysmem: init
Relocation Offset: f9a58000
Relocation fdt: f79fa630 - f79fecd8
CR: M/C/I
Using default environment
DM: v2
no mmc device at slot 1
mmc@ffbf0000: 0, mmc@ffc30000: 1 (SD)
Bootdev(atags): mmc 1
MMC1: Legacy, 52Mhz
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
Failed to load DTB, ret=-19
No valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
MPIDR: 0x80000000
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 600000 KHz, init 1200000 KHz, kernel 0N/A)
  apll 600000 KHz
  gpll 1188000 KHz
  cpll 996000 KHz
  dpll 393000 KHz
  ppll 10KHz
  clk_100m 99600 KHz
  clk_150m 148500 KHz
  clk_200m 198KHz
  clk_400m 396000 KHz
  clk_500m 498000 KHz
  clk_600m 59clk_ppll_125m 125000 KHz
No misc partition
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
Could not find misc partition
ANDROID: reboot reason: "(none)"
Not AVB images, AVB skip
android_image_load_by_partname: Can't find part: boot
Android image load failed
Android boot failed, error -1.
## Booting FITFIT: No boot partition
FIT: No fit blob
FIT: No FIT image
Unknown command 'bootrkp' - try 'help'
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot.scr
3906 bytes read in 23 ms (165 KiB/s)
## Executing script at 00c00000
Boot script loaded from mmc 1:1
176 bytes read in 18 ms (8.8 KiB/s)
6460789 bytes read in 563 ms (10.9 MiB/s)
28610568 bytes read in 2345 ms (11.6 MiB/s)
102238 bytes read in 289 ms (344.7 KiB/s)
Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards.
Unknown command 'kaslrseed' - try 'help'
Fdt Ramdisk skip relocation
No misc partition
## Loading init Ramdisk from Legacy Image at 0a200000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Imagd)
   Data Size:    6460725 Bytes = 6.2 MiB
   Load Address: 0OK
## Flattened Device Tree blob at 0x08300000
   Booting using the fdt blob at 0x08300000
   reserving fdt memory region: addr=8300000 size=7f000
   Using Device Tree in place at 0000000008300000, end 0000000008381fff
WARNING: could not set reg FDT_ERR_BADOFFSET.
## reserved-memory:
  ramoops@110000: addr=110000 size=e0000
Adding bank: 0x00200000 - 0xfc000000 (size: 0xfbe00000)
Total: 4660.229/5052.326 ms
Starting kernel ...
I think that MMC1 is sdcard, MMC2 is internal EMMC, so uboot is loaded from MMC1 sdcard (it has different version compared to standard boot), but the output is different compared to standard boot:
Some suspicious data in log:
MMC1: Legacy, 52Mhz PartType: EFI No misc partition
I have full access to EMMC with all partitions and initial data to extract if needed.
Will appreciate if someone could point me to custom armbian build steps for this board and suggest next steps.
(https://gist.github.com/fensoft/1ff3ef81ab2bd9ed9364a564aa2cbcd5?permalink_comment_id=5576642#file-build-sh is what I tried and it does not work)
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
