Skip to content
View in the app
Armbian Community Forums
Armbian Bookworm OMV7 OdroidHC4
Featured Replies
I was running Armbian Bullseye for a while with OMV 6.  I happened to see OMV has gone to v7 and Armbian to bookworm.
I went here to get the SBC/IOT bare version of bookworm:  https://www.armbian.com/odroid-hc4/
Problem 1:  is it said: "You are using an automated version meant only for developers..."
Problem 2:  it did not come with Armbian-config which I had to install manually
Problem 3:  Armbian-config 'softy' refused to install OMV saying it can only be installed on Buster (OMV5) or Bullseye (OMV6)
Finally: https://wiki.omv-extras.org/doku.php?id=omv7:armbian_bookworm_install  states specifically not to use any developer versions of the OS.
Is there a stable version of the OS where it comes with Armbian-config and softy will install OMV-7?   (If so, url's please)
How do I proceed?  For now going back to Bullseye OMV6  :(
Much thanks in advance.
Solved by fscii
This board is community maintained, not by the Armbian team. Therefore only untested automated builds are provided. https://docs.armbian.com/Board_Maintainers_Procedures_and_Guidelines/
This is intended for a minimal image. https://docs.armbian.com/User-Guide_FAQ/#i-cannot-find-armbian-config-on-my-device
armbian-config did not receive much attention since it is undergoing a major rewrite. However at the bottom line it doesn't do much more than calling an official way of installing. https://forum.armbian.com/topic/40598-status-of-armbian-configng/
Most they can do if you ignore this advice is to refuse support if something goes wrong.
topic moved
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
