Skip to content
View in the app
Armbian Community Forums
Featured Replies
Nice! I'll try that. Thank you for your help so far. Finding the right documentation has been a little tricky for me and I really appreciate the help.
Alright, I built the x96q-lpddr3 image using the patches suggested. It booted (partially). Nothing on the screen, but it is starting!
I chose that image because it is H313 and lpddr3 (the android uboot build that worked before detected it as such)
I attached the serial log. It's getting late here and I may not get much more done on this until Monday, but this is a good sign in my opinion.
uboot.txt
Hmm, according to the config, the X96q lpddr3 uses the AXP313 already. Maybe ram is wrong? Pretty sure it's lpddr3, if there is any way to check that, I can. Gonna do a little digging in android.
According to Android uboot, DRAM_VCC= 1200mv
DRAM CLK =648 MHZ
DRAM TYPE=7 (lpddr3)
DRAM SIZE =1536 MBytes, para1 = 30fa, para2 = 6001000, dram_tpr13 = 26061
gonna try some of this in the x96q image, see what happens
I did notice in the log:
INFO:    PMIC: Probing AXP305 on RSB
ERROR:   RSB: set run-time address: 0x10003
INFO:    Could not init RSB: -65539
/sunxi-fw info -v fulldisk.img
@     0: mbr: DOS MBR
    protective MBR, GPT used
    GPT version 00010000
    usable disk size: 7419 MB
    number of partition entries: 17
@   16: toc0: signed boot image
    2 items
@ 321: toc0: signed boot image
    2 items
@26812: fit: U-Boot FIT image
    fit:__overlay__: "<no description>"
    fit:fragment@2: "<no description>"
So I never dumped just boot0  (and no firmware update available), but I have full emmc dump named fulldisk.img.
I would assume it is the toc0?
Trying to extract does not work , however: (maybe because there are two?)
/sunxi-fw extract -v -n toc0 -o uboot0 /home/Tr/fulldisk.img
unknown image file
extracting the mbr works fine though.
Oh, so it is the devicetree of Linux we want. My bad. Here it is: devicetree.txt
FYI I was able to use binwalk -e on the boot partition dump, nice to see there is another way. Thanks for all the help
Edited by Randlin
Actually in that post it was about downloading the boot_a partition. Then extracting the dts.. you can skip the dts extraction part for now. We need your boot_a partition.
also that’s not the android dts you posted. It has some info but not all of it.
Edited by Nick A
Hmm, I used a different boot.img extractor before to try to get dts, but that spectacularly failed ( https://github.com/anestisb/android-unpackbootimg ). I do have a dump of each of the partitions from root, but there was no boot_a boot_b, just boot (not an a/b system). I'll try that extractor, hopefully that will be better.
everthing is here: https://archive.org/download/G96_Firmware_Dump/Dumped Partitions/
list of partitions dumped: (there are 17 listed in the emmc, but 18 in android for some reason, probably one is a duplicate)
Reserve
boot
bootloader
cache
empty
env
frp
media_data
metadata
misc
mmcblk0boot0
mmcblk0boot1
private
recovery
super
vbmeta
vbmeta_system
vbmeta_vendor
Edited by Randlin
Have you tried running sunxi-fw with the boot image you used to extract the dts? The boot image you posted is a U-Boot FIT image. It doesn't have the dram information we are looking for. I believe mmcblk0boot0 is the correct boot image but the one you uploaded didn't work with sunxi-fw.
Also, I found this in your dts. Maybe these settings will work. To make sure these settings are correct I prefer to get the dram settings using the sunxi-fw tool.
	dram {
		compatible = "allwinner,dram";
		clocks = <0xda>;
		clock-names = "pll_ddr";
		dram_clk = <0x288>;
		dram_type = <0x07>;
		dram_zq = <0x3f3fdd>;
		dram_odt_en = <0x9988eeee>;
		dram_para1 = <0x30fa>;
		dram_para2 = <0x1000>;
		dram_mr0 = <0x00>;
		dram_mr1 = <0xc3>;
		dram_mr2 = <0x06>;
		dram_mr3 = <0x01>;
		dram_tpr0 = <0x00>;
		dram_tpr1 = <0x00>;
		dram_tpr2 = <0x00>;
		dram_tpr3 = <0x00>;
		dram_tpr4 = <0x00>;
		dram_tpr5 = <0x00>;
		dram_tpr6 = <0x2fc08080>;
		dram_tpr7 = <0x00>;
		dram_tpr8 = <0x00>;
		dram_tpr9 = <0x00>;
		dram_tpr10 = <0x402f3379>;
		dram_tpr11 = <0xd100b0f>;
		dram_tpr12 = <0x11131113>;
		dram_tpr13 = <0x80060>;
		linux,phandle = <0x183>;
		phandle = <0x183>;
		device_type = "dram";
		dram_dx_odt = <0x6060606>;
		dram_dx_dri = <0xd0d0d0d>;
		dram_ca_dri = <0x1919>;
		dram_mr4 = <0x00>;
		dram_mr5 = <0x00>;
		dram_mr6 = <0x00>;
		dram_mr11 = <0x00>;
		dram_mr12 = <0x00>;
		dram_mr13 = <0x00>;
		dram_mr14 = <0x00>;
		dram_mr16 = <0x00>;
		dram_mr17 = <0x00>;
		dram_mr22 = <0x00>;
The dram clock is in hex you'll need to convert this value to decimal. https://www.rapidtables.com/convert/number/hex-to-decimal.html
Edited by Nick A
Hmm, I tried running it on both mmcblk0boot* and got no output. I'll try running it on the full dump with -a to see if anything comes up. I'll try adding it to the config and go from there, see if it works. I'm not familiar with memory config and a lot of this stuff, but I am trying to learn all kinds of low level stuff and welcome the challenge!
You can find the dram config options here.
https://elixir.bootlin.com/u-boot/v2025.07-rc2/source/arch/arm/mach-sunxi/Kconfig
if DRAM_SUN50I_H616
config DRAM_SUNXI_DX_ODT
	hex "DRAM DX ODT parameter"
	help
	  DX ODT value from vendor DRAM settings.
config DRAM_SUNXI_DX_DRI
	hex "DRAM DX DRI parameter"
	help
	  DX DRI value from vendor DRAM settings.
config DRAM_SUNXI_CA_DRI
	hex "DRAM CA DRI parameter"
	help
	  CA DRI value from vendor DRAM settings.
config DRAM_SUNXI_ODT_EN
	hex "DRAM ODT EN parameter"
	default 0x1
	help
	  ODT EN value from vendor DRAM settings.
config DRAM_SUNXI_TPR0
	hex "DRAM TPR0 parameter"
	default 0x0
	help
	  TPR0 value from vendor DRAM settings.
config DRAM_SUNXI_TPR2
	hex "DRAM TPR2 parameter"
	default 0x0
	help
	  TPR2 value from vendor DRAM settings.
config DRAM_SUNXI_TPR6
	hex "DRAM TPR6 parameter"
	default 0x3300c080
	help
	  TPR6 value from vendor DRAM settings.
config DRAM_SUNXI_TPR10
	hex "DRAM TPR10 parameter"
	help
	  TPR10 value from vendor DRAM settings. It tells which features
	  should be configured, like write leveling, read calibration, etc.
config DRAM_SUNXI_TPR11
	hex "DRAM TPR11 parameter"
	default 0x0
	help
	  TPR11 value from vendor DRAM settings.
config DRAM_SUNXI_TPR12
	hex "DRAM TPR12 parameter"
	default 0x0
	help
	  TPR12 value from vendor DRAM settings.
Sorry for the delay, was busy the last week. I applied the ram settings and did a couple of builds with different ones. Nothing has worked any better so far. Should I try more of the ram configs?
does not work, uboot bootloops: dram 7 in dts I extracted using dts-compiler (there are other dram definitions in there as well)
+CONFIG_DRAM_CLK=648
+CONFIG_DRAM_SUN50I_H616_DX_ODT=0x3030303
+CONFIG_DRAM_SUN50I_H616_DX_DRI=0xe0e0e0e
+CONFIG_DRAM_SUN50I_H616_CA_DRI=0x1f12
+CONFIG_DRAM_SUN50I_H616_ODT_EN=0x01
+CONFIG_DRAM_SUN50I_H616_TPR0=0xc0001002
+CONFIG_DRAM_SUN50I_H616_TPR6=0x33808080
+CONFIG_DRAM_SUN50I_H616_TPR10=0x2f1107
+CONFIG_DRAM_SUN50I_H616_TPR11=0xddddcccc
+CONFIG_DRAM_SUN50I_H616_TPR12=0xeddc7665
works the same as before, still gets stuck at same place (from binwalk dts):
+CONFIG_DRAM_SUN50I_H616_DX_ODT=0x06060606
+CONFIG_DRAM_SUN50I_H616_DX_DRI=0x0d0d0d0d
+CONFIG_DRAM_SUN50I_H616_CA_DRI=0x1919
+CONFIG_DRAM_SUN50I_H616_ODT_EN=0x9988eeee
+CONFIG_DRAM_SUN50I_H616_TPR0=0x00
+CONFIG_DRAM_SUN50I_H616_TPR6=0x2fc08080
+CONFIG_DRAM_SUN50I_H616_TPR10=0x402f3379
+CONFIG_DRAM_SUN50I_H616_TPR11=0xd100b0f
+CONFIG_DRAM_SUN50I_H616_TPR12=0x11131113
+CONFIG_DRAM_SUN50I_H616_TPR13=0x80000000
Is it possible this error may be an issue?
And the uboot serial log from the working one:
Spoiler
U-Boot SPL 2025.01-armbian-2025.01-S6d41-Pa844-H8869-V004f-Bb703-R448a-dirty (Aug 08 2025 - 16:31:45 +0000)
DRAM:testing 32-bit width, rank = 2
DRAM:Store cfg
DRAM:1st writing pattern
DRAM:detecting column address bits
detected 10 columns
DRAM:restore cfg
DRAM:reconfigure for all active rows
DRAM:store cfg
DRAM:2nd writing pattern
DRAM:detecting row address bits
detected 15 rows
DRAM:restoring cfg
DRAM:end of auto detect dram size
MBUS port 0 cfg0 0100000d cfg1 00640080
MBUS port 1 cfg0 06000009 cfg1 01000578
MBUS port 2 cfg0 0200000d cfg1 00600100
MBUS port 3 cfg0 01000009 cfg1 00500064
MBUS port 4 cfg0 20000209 cfg1 1388157c
MBUS port 5 cfg0 00640209 cfg1 00200040
MBUS port 6 cfg0 00640209 cfg1 00200040
MBUS port 8 cfg0 01000009 cfg1 00400080
MBUS port 11 cfg0 01000009 cfg1 00640080
MBUS port 14 cfg0 04000009 cfg1 00400100
MBUS port 16 cfg0 2000060d cfg1 09600af0
MBUS port 21 cfg0 0800060d cfg1 02000300
MBUS port 22 cfg0 01000009 cfg1 00640080
MBUS port 25 cfg0 0064000f cfg1 00200040
MBUS port 26 cfg0 20000209 cfg1 1388157c
MBUS port 37 cfg0 01000009 cfg1 00400080
MBUS port 38 cfg0 00640209 cfg1 00200040
MBUS port 39 cfg0 20000209 cfg1 1388157c
MBUS port 40 cfg0 00640209 cfg1 00200040
 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.10.14(debug):armbian
NOTICE:  BL31: Built : 20:20:28, Aug  7 2025
NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
NOTICE:  BL31: Found U-Boot DTB at 0x4a0b2520, model: hechuang,x96-q LPDDR3
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for erratum 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for erratum 1530924 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
INFO:    Changed devicetree.
ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2025.01-armbian-2025.01-S6d41-Pa844-H8869-V004f-Bb703-R448a-dirty (Aug 08 2025 - 16:31:45 +0000) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: hechuang,x96-q LPDDR3
DRAM:  2 GiB (effective 0 Bytes)
Hmm, in Android boot log I saw references to 1.5g ram, maybe this? https://github.com/johang/sd-card-images/issues/150
The spot in question:
[536]Actual DRAM SIZE =1536 M
[538]DRAM SIZE =1536 MBytes, para1 = 30fa, para2 = 6001000, dram_tpr13 = 26061
Android boot log in easier to read format:
Spoiler
[485]HELLO! SBOOT is starting!
[488]sboot commit : 749c1f9a
[491]set pll start
[494]periph0 has been enabled
[497]set pll end
[499]unknow PMU
[500]unknow PMU
[503]tPMU: 0x9c
[504]PMU: AXP1530
[506]dram return write ok
[509]board init ok
[510]try to probe rtc region
[513]DRAM BOOT DRIVE INFO: V0.651
[516]the chip id is 0x5c00
[519]chip id check OK
[522]DRAM_VCC set to 1200 mv
[525]DRAM CLK =648 MHZ
[527]DRAM Type =7 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[548]DRAM simple test OK.
[550]rtc standby flag is 0x0, super standby flag is 0x0
[555][mmc]: mmc driver ver 2021-10-12 13:56
[560][mmc]: b mmc 0 bias 4
[568][mmc]: Wrong media type 0x0
[571][mmc]: ***Try SD card 0***
[580][mmc]: HSSDR52/SDR25 4 bit
[583][mmc]: 50000000 Hz
[585][mmc]: 61056 MB
[587][mmc]: ***SD/MMC 0 init OK!!!***
[708]read toc1 from emmc 32800 sector
[712]OLD version: 0.0
[714]NEW version: 0.0
[790]load rotpk hash
[853]load monitor-key hash
[856]load monitor hash
[1061]load boot-key hash
[1064]load boot hash
[1130]load vbmeta-key hash
[1133]load vbmeta hash
[1200]load recovery-key hash
[1203]load recovery hash
[1207]monitor entry=0x48000000
[1210]uboot entry=0x4a000000
[1212]optee entry=0x48600000
[1218]run out of boot0
NOTICE:  BL3-1: v1.0(debug):05d6c57
NOTICE:  BL3-1: Built : 13:35:35, 2021-10-28
NOTICE:  BL3-1 commit: 8
NOTICE:  cpuidle init version V1.0
NOTICE:  secure os exist
MESSAGE: [0x0] TEE-CORE: OP-TEE version: 81ab7a47 #1 2020年 05月 06日 星期三 02:40:04 UTC arm
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05-g23fdfbb-dirty (Jul 27 2024 - 09:05:11 +0800) Allwinner Technology
[01.314]CPU:   Allwinner Family
[01.317]Model: sun50iw9
I2C:   ready
[01.321]DRAM:  1.5 GiB
[01.324]Relocation Offset is: 55ebf000
[01.366]secure enable bit: 1
[01.368]pmu_axp152_probe pmic_bus_read fail
[01.372]PMU: AXP1530
[01.378]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
[01.386]drv_disp_init
[01.416]__clk_enable: clk is null.
[01.422]drv_disp_init finish
[01.425]gic: sec monitor mode
[01.455]flash init start
[01.457]workmode = 0,storage type = 1
[01.460]MMC:     0
[01.462][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
[01.468][mmc]: get sdc_type fail and use default host:tm1.
[01.479][mmc]: Using default timing para
[01.482][mmc]: SUNXI SDMMC Controller Version:0x40200
[01.500][mmc]: card_caps:0x3000000a
[01.503][mmc]: host_caps:0x3000003f
[01.506]sunxi flash init ok
[01.510]Loading Environment from SUNXI_FLASH... OK
secure storage read hdcpkey fail
[01.528]secure storage read hdcpkey fail with:-1
secure storage read widevine fail
[01.535]secure storage read widevine fail with:-1
[01.541]usb burn from boot
delay time 0
weak:otg_phy_config
[01.554]usb prepare ok
[01.890]usb sof ok
[01.892]usb probe ok
[01.894]usb setup ok
set address 0x7
set address 0x7 ok
[04.900]do_burn_from_boot usb : have no handshake
[04.904]boot_gui_init:start
FAT: Misaligned buffer address (9be7b6d8)
32 bytes read in 4 ms (7.8 KiB/s)
tcon_de_attach:de=0,tcon=2[05.049]boot_gui_init:finish
2764854 bytes read in 116 ms (22.7 MiB/s)
[05.190]name in map device_unlock
[05.193]name in map fastboot_status_flag
[05.197]find fastboot unlock flag
[05.204]update dts
** Unrecognized filesystem type **
[05.223]load file(ULI/factory/rootwait init.txt) error.
[05.245]load file(ULI/factory/snum.txt) error.
[05.249]name in map mac
[05.269]load file(ULI/factory/wifi_mac.txt) error.
[05.291]load file(ULI/factory/bt_mac.txt) error.
[05.312]load file(ULI/factory/selinux.txt) error.
[05.334]load file(ULI/factory/specialstr.txt) error.
[05.356]update part info
[05.403]update bootcmd
[05.405]No ethernet found.
Hit any key to stop autoboot:  0
** Unable to read file orange_warning.bmp **
[06.246]sunxi bmp info error : unable to open logo file orange_warning.bmp
2764854 bytes read in 117 ms (22.5 MiB/s)
[11.557]Starting kernel ...
[11.559][mmc]: MMC Device 2 not found
[11.563][mmc]: mmc 2 not find, so not exit
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.170 (cmj@a-X11DPi-N-T) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #1 SMP PREEMPT Sat Jul 27 09:06:28 CST 2024
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] bootconsole [earlycon0] enabled
[    0.027907] BOOTEVENT:        27.891082: ON
[    0.255636] sunxi_i2c_probe()2209 - [i2c3] warning: failed to get regulator id
[    0.256679] sunxi_i2c_probe()2209 - [i2c5] warning: failed to get regulator id
[    0.258075] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[    0.258160] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[    0.293257] [ac200] get ave_regulator_name failed!
[    0.293779] [ac200] pwm enable
[    0.355541] failed to get standby led pin assign
[    0.35▒[    0.362340] uart uart1: get regulator failed
[    0.395506] [NAND][NE] Not found valid nand node on dts
[    0.404195] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
[    0.411131] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
[    0.540734] hci: request ohci1-controller gpio:232
[    0.732636] axp2101_pek: axp2101-pek can not register without irq
[    0.743174] sunxi_ir_startup: get ir protocol failed
[    0.751638] VE: get debugfs_mpp_root is NULL, please check mpp
[    0.751638]
[    0.759986] VE: sunxi ve debug register driver failed!
[    0.759986]
[    0.817925] mmc:failed to get gpios
[    0.855700] FD655: Fd655 Driver init.
[    0.855817] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
[    0.860715] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
[    0.871095] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[    0.877107] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[    0.883019] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[    0.888919] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[    0.901113] FD655: fd655_driver_probe
[    0.905332] FD655: fd655_driver_probe
[    0.909948] FD655: register_fd655_driver: Successed to add fd655  module
[    0.917931] FD655: ====================Command opne in probe=============
[    0.927083] FD655: ====================Display boot in probe=============
[    0.934930] gpio user platform_driver_register  sucess
[    0.951935] failed get gpio-spdif gpio from dts,spdif_gpio:-2
[    0.961697] [audio-codec]dachpf_cfg configurations missing or invalid.
[    0.969362] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:160, pa_ctl_level:0, gpio-spk:0
[    0.993459] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
[    1.000309] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
[    1.013836] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
[    1.047779] ERROR: pinctrl_get for HDMI2.0 DDC fail
[    1.061846] tv_probe()1435 - of_property_read_string tv_power failed!
[    1.144198] cpu cpu1: opp_list_debug_create_link: Failed to create link
[    1.151683] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
[    1.159287] cpu cpu2: opp_list_debug_create_link: Failed to create link
[    1.166743] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
[    1.174333] cpu cpu3: opp_list_debug_create_link: Failed to create link
[    1.181800] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
[    1.527125] [HDMI2 error]: sink do not support this mode:16
[    3.345120] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=1
[    3.345120]
[    3.363036] selinux: avc:  denied  { set } for  scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=1
[    3.363036]
[    3.588102] libprocessgroup: Failed to mount blkio cgroup: No such file or directory
[    3.599356] libprocessgroup: Failed to mount cpuset cgroup: No such device
[    3.608821] libprocessgroup: Failed to mount schedtune cgroup: No such file or directory
[    4.225999] init: property 'ro.bionic.2nd_arch' doesn't exist while expanding '/dev/cpu_variant:${ro.bionic.2nd_arch}'
[    4.238250] init: property 'ro.bionic.2nd_arch' doesn't exist while expanding '/dev/cpu_variant:${ro.bionic.2nd_arch}'
[    4.311347] FAT-fs (mmcblk0p15): bogus number of reserved sectors
[    4.764747] init: setpgid failed for console: Operation not permitted
console:/ $ [    5.595752] apexd: Failed to walk /product/apex : Can't open /product/apex for reading : No such file or directory
[    5.622440] apexd: Failed to activate packages from /product/apex : Failed to scan /product/apex : Can't open /product/apex for reading : No such file or directory
[    7.615609] init: Init cannot set 'dev.mnt.blk.sbin..magisk.worker.system.bin.bootstrap' to 'dm-0': Illegal property name
[    7.644380] init: Init cannot set 'dev.mnt.blk.sbin..magisk.worker.system.bin.hw' to 'dm-0': Illegal property name
[    7.718771] init: Init cannot set 'dev.mnt.blk.sbin..magisk.worker.system.etc.preferred-apps' to 'dm-0': Illegal property name
[    7.731862] init: Init cannot set 'dev.mnt.blk.sbin..magisk.worker.system.etc.selinux' to 'dm-0': Illegal property name
[    7.744060] init: Init cannot set 'dev.mnt.blk.sbin..magisk.worker.system.etc.permissions' to 'dm-0': Illegal property name
^C
130|console:/ $ [    8.140926] init: property 'dev.mnt.blk.data' doesn't exist while expanding '/sys/fs/f2fs/${dev.mnt.blk.data}/cp_interval'
[    8.191185] init: couldn't write 2178 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[    8.336691] init: Failed to bind socket 'pdx/system/vr/display/client': No such file or directory
[    8.413112] init: Failed to bind socket 'pdx/system/vr/display/manager': No such file or directory
[    8.452550] init: Failed to bind socket 'pdx/system/vr/display/vsync': No such file or directory
Gatekeeper_TA_CreateEntryPoint
^C
130|console:/ $ ^C
130|console:/ $ [    8.939412] selinux: avc:  denied  { set } for property=sys.sensors pid=2187 uid=1000 gid=1000 scontext=u:r:hal_sensors_default:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=1
[    8.939412]
[    9.104904] init: couldn't write 2260 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[    9.318897] init: Failed to open file '/d/mmc0/mmc0:0001/ext_csd': No such file or directory
Edited by Randlin
Hi everyone. This is my X96-Q mainboard running H313 and AXP313A. I'm new, I want to install Armbian light server version to run embedded linux (Just need network port, wifi, usb) which version can I use? And how to install on emmc? Thanks everyone!
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
