September 9, 20242 yr My system: armbian Ubuntu jammy 22.04 LTS (arrch64) ~/box86$ steam bin_steam.sh[3598]: Setting up Steam content in /home/john/.local/share/Steam steam.sh[3598]: Running Steam on ubuntu 22.04 64-bit steam.sh[3598]: STEAM_RUNTIME is enabled by the user setup.sh[3670]: Updating Steam runtime environment... /home/john/.local/share/Steam/ubuntu12_32/steam-runtime/run.sh: line 85: steam-runtime-identify-library-abi: command not found run.sh[9880]: steam-runtime-identify-library-abi --ldconfig-paths failed, falling back to ldconfig steam.sh[3598]: Couldn't find /home/john/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/usr/bin/srt-logger, logging to console-linux.txt steam.sh[3598]: Can't find 'steam-runtime-check-requirements', continuing anyway /home/john/.local/share/Steam/steam.sh: line 862: /home/john/.local/share/Steam/ubuntu12_32/steam: cannot execute binary file: Exec format error
September 9, 20242 yr Solution My system: armbian Ubuntu jammy 22.04 LTS (arrch64) ~/box86$ steam bin_steam.sh[3598]: Setting up Steam content in /home/john/.local/share/Steam steam.sh[3598]: Running Steam on ubuntu 22.04 64-bit steam.sh[3598]: STEAM_RUNTIME is enabled by the user setup.sh[3670]: Updating Steam runtime environment... /home/john/.local/share/Steam/ubuntu12_32/steam-runtime/run.sh: line 85: steam-runtime-identify-library-abi: command not found run.sh[9880]: steam-runtime-identify-library-abi --ldconfig-paths failed, falling back to ldconfig steam.sh[3598]: Couldn't find /home/john/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/usr/bin/srt-logger, logging to console-linux.txt steam.sh[3598]: Can't find 'steam-runtime-check-requirements', continuing anyway /home/john/.local/share/Steam/steam.sh: line 862: /home/john/.local/share/Steam/ubuntu12_32/steam: cannot execute binary file: Exec format errorhttps://github.com/NicoD-SBC/armbian-gaming/issues/13Probably worth googling and asking in the gaming GitHub repo.AFIAK gaming audience on this forum is rather small if any.
