lay
  1. ubuntu22 desktop Why does the system restart trigger at 3:30 every day?? I used 'uptime'to check the changes in running time! How to turn off the trigger! sudo grep "3:3[0-9]" /var/log/syslog | grep -i "unattended\|reboot" Sep 19 03:30:53 armbian-ramlog[451]: unattended-upgrades/ Sep 19 03:30:53 armbian-ramlog[451]: unattended-upgrades/unattended-upgrades-dpkg.log Sep 19 03:30:53 armbian-ramlog[451]: unattended-upgrades/unattended-upgrades-shutdown.log Sep 19 03:30:53 armbian-ramlog[451]: unattended-upgrades/unattended-upgrades.log Sep 19 03:30:53 cron[604]: (CRON) INFO (Running @reboot jobs) Sep 19 03:30:54 systemd[1]: Started Unattended Upgrades Shutdown. I have tried to experiment, but it still doesn't work: 50unattended-upgrades " Unattended-Upgrade::Automatic-Reboot "false"; " Please help help Thank you.
  2. The apt source is always overwritten by the cache source when modified. How can I modify this cache source. How can I modify this cache source?? help help
  3. I have resolved it, modified in the driver.
  4. hi, ubuntu22 gome desktop How to fix USB sound card with card1 identifier 1
  5. Kind people: How to modify the default swap partition size in the configuration file and compile the firmware?? help help
  6. Ubuntu 22 gnome desktop compilation encounters' Configuring Locales' exception: bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8) setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 [🔨] setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 [🔨] setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 [🔨] setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 [🔨] setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 [🔨] setfont: ERROR kdfontop.c:285 put_font_piofont: PIO_FONT: unsupported font height: 16 [🔨] The keyboard is in some unknown mode I'm trying: functions/configuration/main-config.sh Pre set the value of 'DEST_LANG' It can't change either! help
  7. I want to pre place the img image in the file system. How do I burn it to the system?
  8. How to reset the armbian system and restore the initial configuration operation
  9. I am Wayland Gnome Ubuntu 22 I executed the command you gave me, but it didn't work sudo gsettings set org.gnome.desktop.session idle-delay 0 (process:36816): dconf-WARNING **: 12:28:47.991: failed to commit changes to dconf: Cannot autolaunch D-Bus without X11 $DISPLAY
  10. Thank you for your support. but, Where is the file configured? I want to pre-set it in advance
  11. hi,Kind hearted people ubuntu22 gome desktop How to configure the default settings of non-stop screen and non automatic screen lock?? I tried to execute: sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target it can only solve the problem of not entering sleep mode!!! But the screen will still go black, So how to set the default black screen never??? help ,help
  12. How to use 'armbianmonitor-u'?? But in order for Google Chrome to run hardware encoding and decoding, which system configuration needs to be checked????
  13. I am particularly concerned about this: Video Acceleration Information ============================== Decoding: Encoding:
