Skip to content
View in the app
Armbian Community Forums
Orange Pi Plus 2 Blocks Internet
Featured Replies
My Opi+2 somehow blocks internet when i turn it on. Even though it is not connected on ethernet port. Then i disabled wifi. Everything seemed fine at first, but as because of i need internet and the wifi is disabled, i had to use ethernet port. When i plug ethernet cable to the opi+2, the modem's internet connection drops. I don't have any ideas about why it is happening.  Here is the modem log:
Jan 1 00:00:08    syslog    emerg    BCM96345 started: BusyBox v1.17.2
Jan 1 00:00:08    daemon    notice    kernel: Linux version 2.6.30 (root@localhost.localdomain) (gcc version 4.4.2 (Buildroot 2010.02-git) ) #4 Wed Jun 15 15:00:07 CST 2016
Jan 1 00:00:08    daemon    warn    kernel: HS Serial flash device: name MX25L64, id 0xc217 size 8192KB
Jan 1 00:00:08    daemon    warn    kernel: 96318REF prom init
Jan 1 00:00:08    daemon    info    kernel: CPU revision is: 00029033 (Broadcom BCM3302)
Jan 1 00:00:08    daemon    warn    kernel: DSL SDRAM reserved: 0xc0000
Jan 1 00:00:08    daemon    info    kernel: Determined physical RAM map:
Jan 1 00:00:08    daemon    info    kernel: memory: 01f40000 @ 00000000 (usable)
Jan 1 00:00:08    daemon    warn    kernel: Zone PFN ranges:
Jan 1 00:00:08    daemon    warn    kernel: DMA 0x00000000 -> 0x00001000
Jan 1 00:00:08    daemon    warn    kernel: Normal 0x00001000 -> 0x00001f40
Jan 1 00:00:08    daemon    warn    kernel: Movable zone start PFN for each node
Jan 1 00:00:08    daemon    warn    kernel: early_node_map[1] active PFN ranges
Jan 1 00:00:08    daemon    warn    kernel: 0: 0x00000000 -> 0x00001f40
Jan 1 00:00:08    daemon    debug    kernel: On node 0 totalpages: 8000
Jan 1 00:00:08    daemon    debug    kernel: free_area_init_node: node 0, pgdat 8038f010, node_mem_map 81000000
Jan 1 00:00:08    daemon    debug    kernel: DMA zone: 32 pages used for memmap
Jan 1 00:00:08    daemon    debug    kernel: DMA zone: 0 pages reserved
Jan 1 00:00:08    daemon    debug    kernel: DMA zone: 4064 pages, LIFO batch:0
Jan 1 00:00:08    daemon    debug    kernel: Normal zone: 31 pages used for memmap
Jan 1 00:00:08    daemon    debug    kernel: Normal zone: 3873 pages, LIFO batch:0
Jan 1 00:00:08    daemon    warn    kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 7937
Jan 1 00:00:08    daemon    notice    kernel: Kernel command line: root=31:0 ro noinitrd console=ttyS0,115200
Jan 1 00:00:08    daemon    warn    kernel: Primary instruction cache 64kB, VIPT, 4-way, linesize 16 bytes.
Jan 1 00:00:08    daemon    warn    kernel: Primary data cache 32kB, 2-way, VIPT, cache aliases, linesize 16 bytes
Jan 1 00:00:08    daemon    info    kernel: NR_IRQS:128
Jan 1 00:00:08    daemon    warn    kernel: PID hash table entries: 128 (order: 7, 512 bytes)
Jan 1 00:00:08    daemon    info    kernel: console [ttyS0] enabled
Jan 1 00:00:08    daemon    info    kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:08    daemon    info    kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan 1 00:00:08    daemon    info    kernel: Memory: 27708k/32000k available (2869k kernel code, 4292k reserved, 716k data, 132k init, 0k highmem)
Jan 1 00:00:08    daemon    info    kernel: Calibrating delay loop... 331.77 BogoMIPS (lpj=165888)
Jan 1 00:00:08    daemon    warn    kernel: Mount-cache hash table entries: 512
Jan 1 00:00:08    daemon    info    kernel: --Kernel Config--
Jan 1 00:00:08    daemon    info    kernel: SMP=0
Jan 1 00:00:08    daemon    info    kernel: PREEMPT=0
Jan 1 00:00:08    daemon    info    kernel: DEBUG_SPINLOCK=0
Jan 1 00:00:08    daemon    info    kernel: DEBUG_MUTEXES=0
Jan 1 00:00:08    daemon    warn    kernel: Broadcom Logger v0.1 Oct 8 2015 19:01:17
Jan 1 00:00:08    daemon    info    kernel: net_namespace: 1128 bytes
Jan 1 00:00:08    daemon    info    kernel: NET: Registered protocol family 16
Jan 1 00:00:08    daemon    warn    kernel: Total Flash size: 8192K with 2048 sectors
Jan 1 00:00:08    daemon    warn    kernel: Flash not used for Auxillary File System
Jan 1 00:00:08    daemon    warn    kernel: registering PCI controller with io_map_base unset
Jan 1 00:00:08    daemon    warn    kernel: bio: create slab at 0
Jan 1 00:00:08    daemon    notice    kernel: SCSI subsystem initialized
Jan 1 00:00:08    daemon    info    kernel: usbcore: registered new interface driver usbfs
Jan 1 00:00:08    daemon    info    kernel: usbcore: registered new interface driver hub
Jan 1 00:00:08    daemon    info    kernel: usbcore: registered new device driver usb
Jan 1 00:00:08    daemon    debug    kernel: pci 0000:00:09.0: reg 10 32bit mmio: [0x10005100-0x100051ff]
Jan 1 00:00:08    daemon    debug    kernel: pci 0000:00:0a.0: reg 10 32bit mmio: [0x10005000-0x100050ff]
Jan 1 00:00:08    daemon    info    kernel: pci 0000:01:00.0: PME# supported from D0 D3hot
Jan 1 00:00:08    daemon    info    kernel: pci 0000:01:00.0: PME# disabled
Jan 1 00:00:08    daemon    debug    kernel: pci 0000:02:00.0: reg 10 64bit mmio: [0x000000-0x007fff]
Jan 1 00:00:08    daemon    debug    kernel: pci 0000:02:00.0: supports D1 D2
Jan 1 00:00:08    daemon    info    kernel: pci 0000:01:00.0: PCI bridge, secondary bus 0000:02
Jan 1 00:00:08    daemon    info    kernel: pci 0000:01:00.0: IO window: disabled
Jan 1 00:00:08    daemon    info    kernel: pci 0000:01:00.0: MEM window: 0xa0000000-0xa00fffff
Jan 1 00:00:08    daemon    info    kernel: pci 0000:01:00.0: PREFETCH window: disabled
Jan 1 00:00:08    daemon    warn    kernel: PCI: Enabling device 0000:01:00.0 (0000 -> 0002)
Jan 1 00:00:08    daemon    debug    kernel: PCI: Setting latency timer of device 0000:01:00.0 to 64
Jan 1 00:00:08    daemon    warn    kernel: BLOG v3.0 Initialized
Jan 1 00:00:08    daemon    warn    kernel: BLOG Rule v1.0 Initialized
Jan 1 00:00:08    daemon    warn    kernel: Broadcom IQoS v0.1 Oct 8 2015 19:04:11 initialized
Jan 1 00:00:08    daemon    info    kernel: NET: Registered protocol family 8
Jan 1 00:00:08    daemon    info    kernel: NET: Registered protocol family 20
Jan 1 00:00:08    daemon    info    kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:08    daemon    info    kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Jan 1 00:00:08    daemon    info    kernel: TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:08    daemon    info    kernel: TCP: Hash tables configured (established 1024 bind 1024)
Jan 1 00:00:08    daemon    info    kernel: TCP reno registered
Jan 1 00:00:08    daemon    info    kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 1 00:00:08    daemon    info    kernel: squashfs: version 4.0 with LZMA457 ported by BRCM
Jan 1 00:00:08    daemon    info    kernel: fuse init (API version 7.11)
Jan 1 00:00:08    daemon    info    kernel: msgmni has been set to 54
Jan 1 00:00:08    daemon    info    kernel: io scheduler noop registered (default)
Jan 1 00:00:08    daemon    warn    kernel: pcieport-driver 0000:01:00.0: device [14e4:6318] has invalid IRQ; check vendor BIOS
Jan 1 00:00:08    daemon    warn    kernel: Driver 'sd' needs updating - please use bus_type methods
Jan 1 00:00:08    daemon    info    kernel: PPP generic driver version 2.4.2
Jan 1 00:00:08    daemon    info    kernel: PPP Deflate Compression module registered
Jan 1 00:00:08    daemon    info    kernel: PPP BSD Compression module registered
Jan 1 00:00:08    daemon    info    kernel: NET: Registered protocol family 24
Jan 1 00:00:08    daemon    info    kernel: usbcore: registered new interface driver cdc_ether
Jan 1 00:00:08    daemon    info    kernel: usbcore: registered new interface driver cdc_eem
Jan 1 00:00:08    daemon    info    kernel: usbcore: registered new interface driver smsc95xx
Jan 1 00:00:08    daemon    warn    kernel: bcm963xx_mtd driver v2.0
Jan 1 00:00:08    daemon    warn    kernel: File system address: 0xb8010100
Jan 1 00:00:08    daemon    warn    kernel: Registered device mtd[BCM63XX RootFS] dev[0] Flash[0xb8010100,5799936]
Jan 1 00:00:08    daemon    info    kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:08    daemon    info    kernel: usbcore: registered new interface driver usb-storage
Jan 1 00:00:08    daemon    info    kernel: USB Mass Storage support registered.
Jan 1 00:00:08    daemon    warn    kernel: brcmboard: brcm_board_init entry
Jan 1 00:00:08    daemon    warn    kernel: SES: Button Interrupt 0x1 is enabled
Jan 1 00:00:08    daemon    warn    kernel: sesBtn_mapIntr: is_sesBtn_irq_shared=0, sesBtn_irq=1
Jan 1 00:00:08    daemon    warn    kernel: SES: LED GPIO 0x8010 is enabled
Jan 1 00:00:08    daemon    warn    kernel: ---------boardUSBControl---------
Jan 1 00:00:08    daemon    warn    kernel: create our /proc/usb_control_file
Jan 1 00:00:08    daemon    warn    kernel: create usb_control_file success
Jan 1 00:00:08    daemon    warn    kernel: usb_control_gpio-----status=0
Jan 1 00:00:08    daemon    warn    kernel: brcm_board_init: isShared=0, rstToDflt_irq=1
Jan 1 00:00:08    daemon    info    kernel: Serial: BCM63XX driver $Revision: 3.00 $
Jan 1 00:00:08    daemon    info    kernel: Magic SysRq enabled (type ^ h for list of supported commands)
Jan 1 00:00:08    daemon    info    kernel: ttyS0 at MMIO 0xb0000100 (irq = 36) is a BCM63XX
Jan 1 00:00:08    daemon    warn    kernel: bcmPktDmaBds_init: Broadcom Packet DMA BDs initialized
Jan 1 00:00:08    daemon    warn    kernel: bcmxtmrt: Broadcom BCM6318B0 ATM/PTM Network Device v0.4 Jun 14 2016 15:17:48
Jan 1 00:00:08    daemon    warn    kernel: GACT probability NOT on
Jan 1 00:00:08    daemon    warn    kernel: Mirror/redirect action on
Jan 1 00:00:08    daemon    warn    kernel: u32 classifier
Jan 1 00:00:08    daemon    warn    kernel: input device check on
Jan 1 00:00:08    daemon    warn    kernel: Actions configured
Jan 1 00:00:08    daemon    info    kernel: TCP cubic registered
Jan 1 00:00:08    daemon    info    kernel: Initializing XFRM netlink socket
Jan 1 00:00:08    daemon    info    kernel: NET: Registered protocol family 10
Jan 1 00:00:08    daemon    info    kernel: IPv6 over IPv4 tunneling driver
Jan 1 00:00:08    daemon    info    kernel: NET: Registered protocol family 17
Jan 1 00:00:08    daemon    info    kernel: NET: Registered protocol family 15
Jan 1 00:00:08    daemon    info    kernel: Initializing MCPD Module
Jan 1 00:00:08    daemon    info    kernel: Ebtables v2.0 registered
Jan 1 00:00:08    daemon    info    kernel: ebt_time registered
Jan 1 00:00:08    daemon    info    kernel: ebt_ftos registered
Jan 1 00:00:08    daemon    info    kernel: ebt_wmm_mark registered
Jan 1 00:00:08    daemon    info    kernel: 802.1Q VLAN Support v1.8 Ben Greear
Jan 1 00:00:08    daemon    info    kernel: All bugs added by David S. Miller
Jan 1 00:00:08    daemon    warn    kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:0.
Jan 1 00:00:08    daemon    info    kernel: Freeing unused kernel memory: 132k freed
Jan 1 00:00:08    daemon    warn    kernel: chipinfo: module license 'proprietary' taints kernel.
Jan 1 00:00:08    daemon    warn    kernel: Disabling lock debugging due to kernel taint
Jan 1 00:00:08    daemon    warn    kernel: brcmchipinfo: brcm_chipinfo_init entry
Jan 1 00:00:08    daemon    warn    kernel: NBUFF v1.0 Initialized
Jan 1 00:00:08    daemon    warn    kernel: ^[[0;36;44mInitialized fcache state^[[0m
Jan 1 00:00:08    daemon    warn    kernel: Broadcom Packet Flow Cache Char Driver v2.2 Oct 8 2015 19:01:55 Registered<242>
Jan 1 00:00:08    daemon    warn    kernel: Created Proc FS /procfs/fcache
Jan 1 00:00:08    daemon    warn    kernel: Broadcom Packet Flow Cache registered with netdev chain
Jan 1 00:00:08    daemon    warn    kernel: ^[[0;36;44mBroadcom Packet Flow Cache learning via BLOG enabled.^[[0m
Jan 1 00:00:08    daemon    warn    kernel: Constructed Broadcom Packet Flow Cache v2.2 Oct 8 2015 19:01:55
Jan 1 00:00:08    daemon    warn    kernel: bcmxtmcfg: bcmxtmcfg_init entry
Jan 1 00:00:08    daemon    warn    kernel: adsl: adsl_init entry
Jan 1 00:00:08    daemon    warn    kernel: Broadcom BCM6318B0 Ethernet Network Device v0.1 Jun 14 2016 15:17:41
Jan 1 00:00:08    daemon    warn    kernel: ETH Init: Ch:0 - 200 tx BDs at 0xa1973000
Jan 1 00:00:08    daemon    warn    kernel: ETH Init: Ch:0 - 400 rx BDs at 0xa19e3000
Jan 1 00:00:08    daemon    warn    kernel: Read#1 : Port = 0 Phy_ID = 0x00000001 Phy_reg = 0x13 reg_val = 0x0000
Jan 1 00:00:08    daemon    warn    kernel: Read#2 : Port = 0 Phy_ID = 0x00000001 Phy_reg = 0x13 reg_val = 0x7555
Jan 1 00:00:08    daemon    warn    kernel: Read#1 : Port = 1 Phy_ID = 0x00000002 Phy_reg = 0x13 reg_val = 0x0000
Jan 1 00:00:08    daemon    warn    kernel: Read#2 : Port = 1 Phy_ID = 0x00000002 Phy_reg = 0x13 reg_val = 0x7555
Jan 1 00:00:08    daemon    warn    kernel: Read#1 : Port = 2 Phy_ID = 0x00000003 Phy_reg = 0x13 reg_val = 0x0000
Jan 1 00:00:08    daemon    warn    kernel: Read#2 : Port = 2 Phy_ID = 0x00000003 Phy_reg = 0x13 reg_val = 0x7555
Jan 1 00:00:08    daemon    warn    kernel: Read#1 : Port = 3 Phy_ID = 0x00000004 Phy_reg = 0x13 reg_val = 0x0000
Jan 1 00:00:08    daemon    warn    kernel: Read#2 : Port = 3 Phy_ID = 0x00000004 Phy_reg = 0x13 reg_val = 0x7555
Jan 1 00:00:08    daemon    warn    kernel: dgasp: kerSysRegisterDyingGaspHandler: bcmsw registered
Jan 1 00:00:08    daemon    warn    kernel: eth0: MAC Address: C8:3A:35:0F:0D:98
Jan 1 00:00:08    daemon    warn    kernel: eth1: MAC Address: C8:3A:35:0F:0D:98
Jan 1 00:00:08    daemon    warn    kernel: eth2: MAC Address: C8:3A:35:0F:0D:98
Jan 1 00:00:08    daemon    warn    kernel: eth3: MAC Address: C8:3A:35:0F:0D:98
Jan 1 00:00:08    daemon    warn    kernel: wl: dsl_tx_pkt_flush_len=338
Jan 1 00:00:08    daemon    warn    kernel: wl: high_wmark_tot=400
Jan 1 00:00:08    daemon    warn    kernel: PCI: Enabling device 0000:02:00.0 (0000 -> 0002)
Jan 1 00:00:08    daemon    debug    kernel: PCI: Setting latency timer of device 0000:02:00.0 to 64
Jan 1 00:00:08    daemon    warn    kernel: wl: passivemode=1
Jan 1 00:00:08    daemon    warn    kernel: wl: napimode=0
Jan 1 00:00:08    daemon    warn    kernel: wl0: allocskbmode=1 currallocskbsz=256
Jan 1 00:00:08    daemon    warn    kernel: Neither SPROM nor OTP has valid image
Jan 1 00:00:08    daemon    warn    kernel: wl:srom/otp not programmed, using main memory mapped srom info(wombo board)
Jan 1 00:00:08    daemon    warn    kernel: wl:loading /etc/wlan/bcm43217_map.bin
Jan 1 00:00:08    daemon    warn    kernel: srom rev:8
Jan 1 00:00:08    daemon    warn    kernel: wl: reading /etc/wlan/bcmcmn_nvramvars.bin, file size=32
Jan 1 00:00:08    daemon    warn    kernel: wl0: Broadcom BCMa8db 802.11 Wireless Controller 6.30.102.7.cpe4.12L08.4
Jan 1 00:00:08    daemon    warn    kernel: dgasp: kerSysRegisterDyingGaspHandler: wl0 registered
Jan 1 00:00:08    daemon    info    kernel: Broadcom 802.1Q VLAN Interface, v0.1
Jan 1 00:00:08    daemon    info    kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Jan 1 00:00:08    daemon    warn    kernel: PCI: Enabling device 0000:00:09.0 (0000 -> 0002)
Jan 1 00:00:08    daemon    debug    kernel: PCI: Setting latency timer of device 0000:00:09.0 to 64
Jan 1 00:00:08    daemon    info    kernel: ohci_hcd 0000:00:09.0: OHCI Host Controller
Jan 1 00:00:08    daemon    info    kernel: ohci_hcd 0000:00:09.0: new USB bus registered, assigned bus number 1
Jan 1 00:00:08    daemon    info    kernel: ohci_hcd 0000:00:09.0: irq 49, io mem 0x10005100
Jan 1 00:00:08    daemon    info    kernel: usb usb1: configuration #1 chosen from 1 choice
Jan 1 00:00:08    daemon    info    kernel: hub 1-0:1.0: USB hub found
Jan 1 00:00:08    daemon    info    kernel: hub 1-0:1.0: 1 port detected
Jan 1 00:00:08    daemon    info    kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 00:00:08    daemon    warn    kernel: Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
Jan 1 00:00:08    daemon    warn    kernel: PCI: Enabling device 0000:00:0a.0 (0000 -> 0002)
Jan 1 00:00:08    daemon    debug    kernel: PCI: Setting latency timer of device 0000:00:0a.0 to 64
Jan 1 00:00:08    daemon    info    kernel: ehci_hcd 0000:00:0a.0: EHCI Host Controller
Jan 1 00:00:08    daemon    info    kernel: ehci_hcd 0000:00:0a.0: new USB bus registered, assigned bus number 2
Jan 1 00:00:08    daemon    warn    kernel: ehci_hcd 0000:00:0a.0: Enabling legacy PCI PM
Jan 1 00:00:08    daemon    info    kernel: ehci_hcd 0000:00:0a.0: irq 50, io mem 0x10005000
Jan 1 00:00:08    daemon    info    kernel: ehci_hcd 0000:00:0a.0: USB f.f started, EHCI 1.00
Jan 1 00:00:08    daemon    info    kernel: usb usb2: configuration #1 chosen from 1 choice
Jan 1 00:00:08    daemon    info    kernel: hub 2-0:1.0: USB hub found
Jan 1 00:00:08    daemon    info    kernel: hub 2-0:1.0: 1 port detected
Jan 1 00:00:08    daemon    info    kernel: usbcore: registered new interface driver usblp
Jan 1 00:00:08    daemon    warn    kernel: ---------usbled_state_capture---------
Jan 1 00:00:08    daemon    warn    kernel: create /proc/usb_control_file success
Jan 1 00:00:08    daemon    notice    syslog: Dns up.
Jan 1 00:00:09    daemon    warn    kernel: Netfilter messages via NETLINK v0.30.
Jan 1 00:00:09    daemon    info    kernel: device eth0 entered promiscuous mode
Jan 1 00:00:10    daemon    info    kernel: ADDRCONF(NETDEV_UP): eth0: link is not ready
Jan 1 00:00:10    daemon    info    kernel: device eth1 entered promiscuous mode
Jan 1 00:00:10    daemon    warn    radvd[383]: Exiting, sigterm received.
Jan 1 00:00:10    daemon    info    kernel: ADDRCONF(NETDEV_UP): eth1: link is not ready
Jan 1 00:00:10    daemon    info    kernel: device eth2 entered promiscuous mode
Jan 1 00:00:10    daemon    warn    radvd[396]: Exiting, sigterm received.
Jan 1 00:00:10    daemon    info    kernel: ADDRCONF(NETDEV_UP): eth2: link is not ready
Jan 1 00:00:10    daemon    info    kernel: device eth3 entered promiscuous mode
Jan 1 00:00:10    daemon    warn    radvd[409]: Exiting, sigterm received.
Jan 1 00:00:10    daemon    info    kernel: ADDRCONF(NETDEV_UP): eth3: link is not ready
Jan 1 00:00:11    daemon    info    kernel: device wl0 entered promiscuous mode
Jan 1 00:00:11    daemon    warn    radvd[422]: Exiting, sigterm received.
Jan 1 00:00:11    daemon    info    kernel: br0: port 5(wl0) entering forwarding state
Jan 1 00:00:11    daemon    warn    kernel: BcmAdsl_Initialize=0xC00D6060, g_pFnNotifyCallback=0xC010A674
Jan 1 00:00:11    daemon    warn    kernel: pSdramPHY=0xA1FFFFF8, 0xCC33CC32 0x8C33CC33
Jan 1 00:00:11    daemon    warn    kernel: *** XfaceOffset: 0x1C790 => 0x1C790 ***
Jan 1 00:00:12    daemon    warn    kernel: *** PhySdramSize got adjusted: 0x91330 => 0xA73FC ***
Jan 1 00:00:12    daemon    warn    kernel: AdslCoreSharedMemInit: shareMemSize=101341(101344)
Jan 1 00:00:12    daemon    warn    kernel: AdslCoreHwReset: pLocSbSta=808a0000 bkupThreshold=1600
Jan 1 00:00:12    daemon    warn    kernel: AdslCoreHwReset: AdslOemDataAddr = 0xA1FC5DDC
Jan 1 00:00:12    daemon    warn    kernel: ***BcmDiagsMgrRegisterClient: 0 ***
Jan 1 00:00:12    daemon    warn    kernel: dgasp: kerSysRegisterDyingGaspHandler: dsl0 registered
Jan 1 00:00:12    daemon    warn    kernel: bcmxtmrt: PTM/ATM Non-Bonding Mode configured in system
Jan 1 00:00:12    daemon    info    kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:12    daemon    warn    kernel: nf_conntrack version 0.5.0 (500 buckets, 2000 max)
Jan 1 00:00:14    daemon    crit    kernel: Line 0: xDSL G.994 training
Jan 1 00:00:14    daemon    info    kernel: message received before monitor task is initialized kerSysSendtoMonitorTask
Jan 1 00:00:17    daemon    info    kernel: monitor task is initialized pid= 295
Jan 1 00:00:18    daemon    warn    kernel: copy 2 byte, bigbuf=1
Jan 1 00:00:18    daemon    warn    kernel: usb_control_gpio-----status=1
Jan 1 00:00:19    daemon    info    kernel: br0: port 5(wl0) entering disabled state
Jan 1 00:00:19    daemon    info    kernel: device wl0 left promiscuous mode
Jan 1 00:00:20    daemon    info    kernel: device wl0 entered promiscuous mode
Jan 1 00:00:20    daemon    warn    radvd[436]: Exiting, sigterm received.
Jan 1 00:00:20    daemon    info    kernel: br0: port 5(wl0) entering forwarding state
Jan 1 00:00:21    daemon    info    kernel: br0: port 5(wl0) entering disabled state
Jan 1 00:00:21    daemon    info    kernel: device wl0 left promiscuous mode
Jan 1 00:00:21    daemon    info    kernel: device wl0 entered promiscuous mode
Jan 1 00:00:21    daemon    warn    radvd[654]: Exiting, sigterm received.
Jan 1 00:00:21    daemon    info    kernel: br0: port 5(wl0) entering forwarding state
Jan 1 00:00:28    daemon    info    syslog: received REQUEST!
Jan 1 00:00:29    daemon    crit    kernel: Line 0: ADSL G.992 started
Jan 1 00:00:29    daemon    info    syslog: received DISCOVER!
Jan 1 00:00:30    daemon    warn    radvd[716]: received RS from fe80::ba98:f7ff:fe70:950d
Jan 1 00:00:31    daemon    info    syslog: sending OFFER of 192.168.1.2
Jan 1 00:00:31    daemon    info    syslog: received REQUEST!
Jan 1 00:00:31    daemon    info    syslog: sending ACK to 192.168.1.2
Jan 1 00:00:34    daemon    crit    kernel: Line 0: ADSL G.992 channel analysis
Jan 1 00:00:35    daemon    info    syslog: received REQUEST!
Jan 1 00:00:36    daemon    info    syslog: received DISCOVER!
Jan 1 00:00:36    daemon    warn    radvd[716]: received RS from fe80::ba98:f7ff:fea8:95e7
Jan 1 00:00:38    daemon    info    syslog: sending OFFER of 192.168.1.3
Jan 1 00:00:38    daemon    info    syslog: received REQUEST!
Jan 1 00:00:38    daemon    info    syslog: sending ACK to 192.168.1.3
Jan 1 00:00:40    daemon    crit    kernel: Line 0: ADSL G.992 message exchange
Jan 1 00:00:41    daemon    crit    kernel: Line 0: ADSL link up, Bearer 0, us=797, ds=16383
Jan 1 00:00:41    daemon    warn    kernel: bcmxtmcfg: XTM Link Information, port = 0, State = UP, Service Support = ATM
Jan 1 00:00:41    daemon    warn    kernel: bcmxtmcfg: ReconfigureSAR port 0 traffictype 1
Jan 1 00:00:41    daemon    warn    kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
Jan 1 00:00:41    daemon    warn    kernel: TxLineRateTimer=66524
Jan 1 00:00:41    daemon    warn    kernel: atm0.1 MAC address set to C8:3A:35:0F:0D:9B
Jan 1 00:00:41    daemon    warn    kernel: netdev path : atm0.1 -> atm0
Jan 1 00:00:41    daemon    warn    kernel: BCMVLAN : atm0 mode was set to RG
Jan 1 00:00:41    daemon    info    kernel: device atm0 entered promiscuous mode
Jan 1 00:00:41    daemon    notice    syslog: pppd 2.4.1 started by admin, uid 0
Jan 1 00:00:41    daemon    notice    syslog: PPP: Start to connect ...
Jan 1 00:00:48    daemon    info    syslog: received REQUEST!
Jan 1 00:00:48    daemon    info    syslog: received DISCOVER!
Jan 1 00:00:48    daemon    warn    radvd[716]: received RS from fe80::a924:add:8be3:2030
Jan 1 00:00:50    daemon    info    syslog: sending OFFER of 192.168.1.4
Jan 1 00:00:50    daemon    info    syslog: received REQUEST!
Jan 1 00:00:50    daemon    info    syslog: sending ACK to 192.168.1.4
Jan 1 00:00:50    daemon    info    syslog: received DISCOVER!
Jan 1 00:00:50    daemon    warn    radvd[716]: received RS from fe80::3d21:7d64:3e41:1b04
Jan 1 00:00:51    daemon    warn    radvd[716]: received RS from fe80::3d21:7d64:3e41:1b04
Jan 1 00:00:52    daemon    debug    kernel: atm0.1: no IPv6 routers present
Jan 1 00:00:52    daemon    info    syslog: sending OFFER of 192.168.1.5
Jan 1 00:00:52    daemon    info    syslog: received REQUEST!
Jan 1 00:00:52    daemon    info    syslog: sending ACK to 192.168.1.5
Jan 1 00:01:07    daemon    notice    syslog: PPP: Start to connect ...
Jan 1 00:01:07    daemon    crit    syslog: PPP server detected.
Jan 1 00:01:08    daemon    crit    syslog: PPP session established.
Jan 1 00:01:08    daemon    warn    kernel: netdev path : ppp0.1 -> atm0.1 -> atm0
Jan 1 00:01:08    daemon    crit    syslog: PPP LCP UP.
Jan 1 00:01:11    daemon    crit    syslog: Received valid IP address from server. Connection UP.
Jun 17 03:25:34    daemon    info    syslog: sntp: synchronize time Sat Jun 17 03:25:34 2017 .
Jun 17 03:25:57    daemon    info    syslog: ip:192.168.1.4 login success!
Jun 17 03:26:09    daemon    crit    kernel: eth0 Link UP 100 mbps full duplex
Jun 17 03:26:09    daemon    info    kernel: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jun 17 03:26:09    daemon    info    kernel: br0: port 1(eth0) entering forwarding state
Jun 17 03:26:11    daemon    info    syslog: received REQUEST!
Jun 17 03:26:11    daemon    info    syslog: received DISCOVER!
Jun 17 03:26:13    daemon    info    syslog: sending OFFER of 192.168.1.6
Jun 17 03:26:13    daemon    info    syslog: received REQUEST!
Jun 17 03:26:13    daemon    info    syslog: sending ACK to 192.168.1.6
Jun 17 03:26:21    daemon    crit    kernel: eth0 Link DOWN.
Jun 17 03:26:21    daemon    info    kernel: br0: port 1(eth0) entering disabled state
Jun 17 03:27:25    daemon    alert    kernel: Intrusion -> IN=ppp0.1 OUT= MAC= SRC=192.155.82.12 DST=88.242.138.81 LEN=40 TOS=0x00 PREC=0x00 TTL=244 ID=54321 PROTO=TCP SPT=33917 DPT=10809 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Jun 17 03:28:42    daemon    alert    kernel: Intrusion -> IN=ppp0.1 OUT= MAC= SRC=31.170.237.205 DST=88.242.138.81 LEN=52 TOS=0x02 PREC=0x00 TTL=114 ID=5147 DF PROTO=TCP SPT=53829 DPT=3389 WINDOW=8192 RES=0x00 CWR ECE SYN URGP=0 MARK=0x8000000
Jun 17 03:28:43    daemon    alert    kernel: Intrusion -> IN=ppp0.1 OUT= MAC= SRC=31.170.237.205 DST=88.242.138.81 LEN=52 TOS=0x02 PREC=0x00 TTL=115 ID=6587 DF PROTO=TCP SPT=55230 DPT=3389 WINDOW=8192 RES=0x00 CWR ECE SYN URGP=0 MARK=0x8000000
Jun 17 03:28:57    daemon    alert    kernel: Intrusion -> IN=ppp0.1 OUT= MAC= SRC=122.114.91.127 DST=88.242.138.81 LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=6936 PROTO=TCP SPT=50905 DPT=1433 WINDOW=1024 RES=0x00 SYN URGP=0 MARK=0x8000000
Jun 17 03:29:02    daemon    alert    kernel: Intrusion -> IN=ppp0.1 OUT= MAC= SRC=62.210.151.148 DST=88.242.138.81 LEN=40 TOS=0x00 PREC=0x00 TTL=243 ID=31088 DF PROTO=TCP SPT=130 DPT=8045 WINDOW=512 RES=0x00 SYN URGP=0 MARK=0x8000000
Jun 17 03:30:30    daemon    crit    kernel: Line 0: ADSL link down
Jun 17 03:30:30    daemon    warn    kernel: bcmxtmcfg: XTM Link Information, port = 0, State = DOWN, Service Support = ATM
Jun 17 03:30:30    daemon    warn    kernel: TxLineRateTimer=0
Jun 17 03:30:30    daemon    warn    kernel: bcmxtmcfg: ReconfigureSAR port 0 traffictype 0
Jun 17 03:30:30    daemon    warn    kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
Jun 17 03:30:30    daemon    warn    kernel: Warning: xtm channel 0 rx bogus packet
Jun 17 03:30:30    daemon    warn    kernel: Warning: xtm channel 1 rx bogus packet
Jun 17 03:30:30    daemon    crit    kernel: Line 0: xDSL G.994 training
Jun 17 03:30:36    daemon    crit    syslog: Clear IP addresses. PPP connection DOWN.
Jun 17 03:30:36    daemon    crit    syslog: Clear IP addresses. Connection DOWN.
Jun 17 03:30:41    daemon    info    kernel: device atm0 left promiscuous mode
Jun 17 03:30:41    daemon    info    kernel: device atm0 entered promiscuous mode
Jun 17 03:30:46    daemon    crit    kernel: Line 0: ADSL G.992 started
Jun 17 03:30:50    daemon    crit    kernel: Line 0: ADSL G.992 channel analysis
Jun 17 03:30:57    daemon    crit    kernel: Line 0: ADSL G.992 message exchange
Jun 17 03:30:58    daemon    crit    kernel: Line 0: ADSL link up, Bearer 0, us=797, ds=14111
Jun 17 03:30:58    daemon    warn    kernel: bcmxtmcfg: XTM Link Information, port = 0, State = UP, Service Support = ATM
Jun 17 03:30:58    daemon    warn    kernel: bcmxtmcfg: ReconfigureSAR port 0 traffictype 1
Jun 17 03:30:58    daemon    warn    kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
Jun 17 03:30:58    daemon    warn    kernel: TxLineRateTimer=66524
Jun 17 03:30:58    daemon    warn    kernel: atm0.1 MAC address set to C8:3A:35:0F:0D:9B
Jun 17 03:30:58    daemon    warn    kernel: netdev path : atm0.1 -> atm0
Jun 17 03:30:58    daemon    warn    kernel: BCMVLAN : atm0 mode was set to RG
Jun 17 03:30:58    daemon    info    kernel: device atm0 entered promiscuous mode
Jun 17 03:30:58    daemon    notice    syslog: pppd 2.4.1 started by admin, uid 0
Jun 17 03:30:58    daemon    notice    syslog: PPP: Start to connect ...
Jun 17 03:31:01    daemon    crit    syslog: PPP server detected.
Jun 17 03:31:01    daemon    crit    syslog: PPP session established.
Jun 17 03:31:01    daemon    warn    kernel: netdev path : ppp0.1 -> atm0.1 -> atm0
Jun 17 03:31:01    daemon    crit    syslog: PPP LCP UP.
Jun 17 03:31:04    daemon    crit    syslog: Received valid IP address from server. Connection UP.
Jun 17 03:31:08    daemon    debug    kernel: atm0.1: no IPv6 routers present
Jun 17 03:32:01    daemon    crit    kernel: Line 0: ADSL link down
Jun 17 03:32:01    daemon    warn    kernel: bcmxtmcfg: XTM Link Information, port = 0, State = DOWN, Service Support = ATM
Jun 17 03:32:01    daemon    warn    kernel: TxLineRateTimer=0
Jun 17 03:32:01    daemon    warn    kernel: bcmxtmcfg: ReconfigureSAR port 0 traffictype 0
Jun 17 03:32:01    daemon    warn    kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
Jun 17 03:32:01    daemon    warn    kernel: Warning: xtm channel 0 rx bogus packet
Jun 17 03:32:01    daemon    warn    kernel: Warning: xtm channel 1 rx bogus packet
Jun 17 03:32:01    daemon    crit    kernel: Line 0: xDSL G.994 training
Jun 17 03:32:01    daemon    crit    syslog: Clear IP addresses. PPP connection DOWN.
Jun 17 03:32:01    daemon    crit    syslog: Clear IP addresses. Connection DOWN.
Jun 17 03:32:04    daemon    crit    kernel: eth0 Link UP 100 mbps full duplex
Jun 17 03:32:04    daemon    info    kernel: br0: port 1(eth0) entering forwarding state
Jun 17 03:32:06    daemon    info    kernel: device atm0 left promiscuous mode
Jun 17 03:32:06    daemon    info    kernel: device atm0 entered promiscuous mode
Jun 17 03:32:17    daemon    crit    kernel: Line 0: ADSL G.992 started
Jun 17 03:32:22    daemon    crit    kernel: Line 0: ADSL G.992 channel analysis
Jun 17 03:32:28    daemon    crit    kernel: Line 0: ADSL G.992 message exchange
Jun 17 03:32:29    daemon    crit    kernel: Line 0: ADSL link up, Bearer 0, us=797, ds=13559
Jun 17 03:32:29    daemon    warn    kernel: bcmxtmcfg: XTM Link Information, port = 0, State = UP, Service Support = ATM
Jun 17 03:32:29    daemon    warn    kernel: bcmxtmcfg: ReconfigureSAR port 0 traffictype 1
Jun 17 03:32:29    daemon    warn    kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
Jun 17 03:32:29    daemon    warn    kernel: TxLineRateTimer=66524
Jun 17 03:32:29    daemon    warn    kernel: atm0.1 MAC address set to C8:3A:35:0F:0D:9B
Jun 17 03:32:29    daemon    warn    kernel: netdev path : atm0.1 -> atm0
Jun 17 03:32:29    daemon    warn    kernel: BCMVLAN : atm0 mode was set to RG
Jun 17 03:32:29    daemon    info    kernel: device atm0 entered promiscuous mode
Jun 17 03:32:29    daemon    notice    syslog: pppd 2.4.1 started by admin, uid 0
Jun 17 03:32:29    daemon    notice    syslog: PPP: Start to connect ...
Jun 17 03:32:30    daemon    crit    syslog: PPP server detected.
Jun 17 03:32:30    daemon    crit    syslog: PPP session established.
Jun 17 03:32:30    daemon    warn    kernel: netdev path : ppp0.1 -> atm0.1 -> atm0
Jun 17 03:32:30    daemon    crit    syslog: PPP LCP UP.
Jun 17 03:32:33    daemon    crit    syslog: Received valid IP address from server. Connection UP.
Jun 17 03:32:39    daemon    debug    kernel: atm0.1: no IPv6 routers present
Jun 17 03:33:08    daemon    crit    kernel: eth0 Link DOWN.
Jun 17 03:33:08    daemon    info    kernel: br0: port 1(eth0) entering disabled state
Jun 17 03:33:13    daemon    crit    kernel: Line 0: ADSL link down
Jun 17 03:33:13    daemon    warn    kernel: bcmxtmcfg: XTM Link Information, port = 0, State = DOWN, Service Support = ATM
Jun 17 03:33:13    daemon    warn    kernel: TxLineRateTimer=0
Jun 17 03:33:13    daemon    warn    kernel: bcmxtmcfg: ReconfigureSAR port 0 traffictype 0
Jun 17 03:33:13    daemon    warn    kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
Jun 17 03:33:13    daemon    warn    kernel: Warning: xtm channel 0 rx bogus packet
Jun 17 03:33:13    daemon    warn    kernel: Warning: xtm channel 1 rx bogus packet
Jun 17 03:33:13    daemon    crit    kernel: Line 0: xDSL G.994 training
Jun 17 03:33:13    daemon    crit    kernel: eth0 Link UP 100 mbps full duplex
Jun 17 03:33:13    daemon    info    kernel: br0: port 1(eth0) entering forwarding state
Jun 17 03:33:13    daemon    crit    syslog: Clear IP addresses. PPP connection DOWN.
Jun 17 03:33:13    daemon    crit    syslog: Clear IP addresses. Connection DOWN.
Jun 17 03:33:18    daemon    info    kernel: device atm0 left promiscuous mode
Jun 17 03:33:18    daemon    info    kernel: device atm0 entered promiscuous mode
Jun 17 03:33:29    daemon    crit    kernel: Line 0: ADSL G.992 started
Jun 17 03:33:34    daemon    crit    kernel: Line 0: ADSL G.992 channel analysis
Jun 17 03:33:37    daemon    crit    kernel: eth0 Link DOWN.
Jun 17 03:33:37    daemon    info    kernel: br0: port 1(eth0) entering disabled state
Jun 17 03:33:40    daemon    crit    kernel: Line 0: ADSL G.992 message exchange
Jun 17 03:33:40    daemon    crit    kernel: eth0 Link UP 100 mbps full duplex
Jun 17 03:33:40    daemon    info    kernel: br0: port 1(eth0) entering forwarding state
Jun 17 03:33:41    daemon    crit    kernel: Line 0: ADSL link down
Jun 17 03:33:42    daemon    crit    kernel: Line 0: xDSL G.994 training
Jun 17 03:33:45    daemon    info    syslog: received REQUEST!
Jun 17 03:33:45    daemon    info    syslog: received DISCOVER!
Jun 17 03:33:47    daemon    info    syslog: sending OFFER of 192.168.1.7
Jun 17 03:33:47    daemon    info    syslog: received REQUEST!
Jun 17 03:33:47    daemon    info    syslog: sending ACK to 192.168.1.7
Jun 17 03:33:47    daemon    info    syslog: received DISCOVER!
Jun 17 03:33:48    daemon    warn    radvd[716]: received RS from fe80::e422:5cff:fedf:f4ad
Jun 17 03:33:58    daemon    crit    kernel: Line 0: ADSL G.992 started
Jun 17 03:34:02    daemon    crit    kernel: Line 0: ADSL G.992 channel analysis
Jun 17 03:34:09    daemon    crit    kernel: Line 0: ADSL G.992 message exchange
Jun 17 03:34:09    daemon    crit    kernel: Line 0: ADSL link up, Bearer 0, us=797, ds=10691
Jun 17 03:34:09    daemon    warn    kernel: bcmxtmcfg: XTM Link Information, port = 0, State = UP, Service Support = ATM
Jun 17 03:34:09    daemon    warn    kernel: bcmxtmcfg: ReconfigureSAR port 0 traffictype 1
Jun 17 03:34:09    daemon    warn    kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
Jun 17 03:34:09    daemon    warn    kernel: TxLineRateTimer=66524
Jun 17 03:34:10    daemon    warn    kernel: atm0.1 MAC address set to C8:3A:35:0F:0D:9B
Jun 17 03:34:10    daemon    warn    kernel: netdev path : atm0.1 -> atm0
Jun 17 03:34:10    daemon    warn    kernel: BCMVLAN : atm0 mode was set to RG
Jun 17 03:34:10    daemon    info    kernel: device atm0 entered promiscuous mode
Jun 17 03:34:10    daemon    notice    syslog: pppd 2.4.1 started by admin, uid 0
Jun 17 03:34:10    daemon    notice    syslog: PPP: Start to connect ...
Jun 17 03:34:10    daemon    crit    syslog: PPP server detected.
Jun 17 03:34:11    daemon    crit    syslog: PPP session established.
Jun 17 03:34:11    daemon    warn    kernel: netdev path : ppp0.1 -> atm0.1 -> atm0
Jun 17 03:34:11    daemon    crit    syslog: PPP LCP UP.
Jun 17 03:34:17    daemon    notice    syslog: PPP: Start to connect ...
Jun 17 03:34:18    daemon    crit    syslog: PPP server detected.
Jun 17 03:34:18    daemon    crit    syslog: PPP session established.
Jun 17 03:34:18    daemon    warn    kernel: netdev path : ppp0.1 -> atm0.1 -> atm0
Jun 17 03:34:18    daemon    crit    syslog: PPP LCP UP.
Jun 17 03:34:21    daemon    debug    kernel: atm0.1: no IPv6 routers present
Jun 17 03:34:22    daemon    crit    syslog: Received valid IP address from server. Connection UP.
Jun 17 03:34:43    daemon    crit    kernel: Line 0: ADSL link down
Jun 17 03:34:43    daemon    warn    kernel: bcmxtmcfg: XTM Link Information, port = 0, State = DOWN, Service Support = ATM
Jun 17 03:34:43    daemon    warn    kernel: TxLineRateTimer=0
Jun 17 03:34:43    daemon    warn    kernel: bcmxtmcfg: ReconfigureSAR port 0 traffictype 0
Jun 17 03:34:43    daemon    warn    kernel: bcmxtmcfg: Normal(XTM/PTM) Mode enabled
Jun 17 03:34:43    daemon    warn    kernel: Warning: xtm channel 0 rx bogus packet
Jun 17 03:34:43    daemon    warn    kernel: Warning: xtm channel 1 rx bogus packet
Jun 17 03:34:43    daemon    crit    kernel: Line 0: xDSL G.994 training
Jun 17 03:34:43    daemon    crit    syslog: Clear IP addresses. PPP connection DOWN.
Jun 17 03:34:43    daemon    crit    syslog: Clear IP addresses. Connection DOWN.
Jun 17 03:34:48    daemon    info    kernel: device atm0 left promiscuous mode
Jun 17 03:34:48    daemon    info    kernel: device atm0 entered promiscuous mode
Jun 17 03:34:59    daemon    crit    kernel: Line 0: ADSL G.992 started
And here is the opi+2 syslog:
Jun 17 00:44:30 localhost dnsmasq[892]: setting upstream servers from DBus
Jun 17 00:44:30 localhost NetworkManager[655]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf
Jun 17 00:44:30 localhost dbus[637]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Jun 17 00:44:30 localhost systemd[1]: Starting Network Manager Script Dispatcher Service...
Jun 17 00:44:30 localhost dbus[637]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 17 00:44:30 localhost systemd[1]: Started Network Manager Script Dispatcher Service.
Jun 17 00:44:30 localhost nm-dispatcher: req:1 'down' [eth0]: new request (1 scripts)
Jun 17 00:44:30 localhost nm-dispatcher: req:1 'down' [eth0]: start running ordered scripts...
Jun 17 00:45:01 localhost rsyslogd-2007: action 'action 9' suspended, next retry is Sat Jun 17 00:45:31 2017 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jun 17 00:45:01 localhost CRON[2170]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.0601] device (eth0): link connected
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.0649] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed') [20 30 40]
Jun 17 00:45:17 localhost kernel: [  721.700390] PHY: gmac0-0:00 - Link is Up - 100/Full
Jun 17 00:45:17 localhost kernel: [  721.701974] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.0711] policy: auto-activating connection 'Ifupdown (eth0)'
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.0891] device (eth0): Activation: starting connection 'Ifupdown (eth0)' (681b428f-beaf-8932-dce4-687ed5bae28e)
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.0915] device (eth0): state change: disconnected -> prepare (reason 'none') [30 40 0]
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.0986] device (eth0): state change: prepare -> config (reason 'none') [40 50 0]
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.1038] device (eth0): state change: config -> ip-config (reason 'none') [50 70 0]
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.1089] dhcp4 (eth0): activation: beginning transaction (timeout in 45 seconds)
Jun 17 00:45:17 localhost NetworkManager[655]: <info>  [1497660317.1195] dhcp4 (eth0): dhclient started with pid 2194
Jun 17 00:45:17 localhost NetworkManager[655]: <warn>  [1497660317.1218] device (eth0): The kernel does not support extended IFA_FLAGS needed by NM for IPv6 private addresses. This feature is not available
Jun 17 00:45:17 localhost dhclient[2194]: DHCPREQUEST of 192.168.1.7 on eth0 to 255.255.255.255 port 67 (xid=0x778c5870)
Jun 17 00:45:18 localhost avahi-daemon[654]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::e422:5cff:fedf:f4ad.
Jun 17 00:45:18 localhost avahi-daemon[654]: New relevant interface eth0.IPv6 for mDNS.
Jun 17 00:45:18 localhost avahi-daemon[654]: Registering new address record for fe80::e422:5cff:fedf:f4ad on eth0.*.
Jun 17 00:45:18 localhost NetworkManager[655]: <error> [1497660318.1310] platform-linux: do-add-ip6-address[2: fe80::e422:5cff:fedf:f4ad]: failure 22 (Invalid argument)
Jun 17 00:45:19 localhost ntpd[1083]: Listen normally on 8 eth0 [fe80::e422:5cff:fedf:f4ad%2]:123
Jun 17 00:45:19 localhost ntpd[1083]: new interface(s) found: waking up resolver
Jun 17 00:45:19 localhost NetworkManager[655]: <info>  [1497660319.9340] dhcp6 (eth0): activation: beginning transaction (timeout in 45 seconds)
Jun 17 00:45:19 localhost NetworkManager[655]: <info>  [1497660319.9453] dhcp6 (eth0): dhclient started with pid 2211
Jun 17 00:45:19 localhost NetworkManager[655]: <error> [1497660319.9482] platform-linux: do-add-ip6-address[2: fe80::e422:5cff:fedf:f4ad]: failure 22 (Invalid argument)
Jun 17 00:45:20 localhost dhclient[2211]: XMT: Info-Request on eth0, interval 940ms.
Jun 17 00:45:20 localhost dhclient[2194]: DHCPREQUEST of 192.168.1.7 on eth0 to 255.255.255.255 port 67 (xid=0x778c5870)
Jun 17 00:45:20 localhost dhclient[2194]: DHCPACK of 192.168.1.7 from 192.168.1.1
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8117]   address 192.168.1.7
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8120]   plen 24 (255.255.255.0)
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8122]   gateway 192.168.1.1
Jun 17 00:45:20 localhost dhclient[2194]: bound to 192.168.1.7 -- renewal in 33274 seconds.
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8124]   server identifier 192.168.1.1
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8125]   lease time 86400
Jun 17 00:45:20 localhost avahi-daemon[654]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.7.
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8128]   nameserver '192.168.1.1'
Jun 17 00:45:20 localhost avahi-daemon[654]: New relevant interface eth0.IPv4 for mDNS.
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8131]   domain name 'Home'
Jun 17 00:45:20 localhost avahi-daemon[654]: Registering new address record for 192.168.1.7 on eth0.IPv4.
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8133] dhcp4 (eth0): state changed unknown -> bound
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8384] device (eth0): state change: ip-config -> ip-check (reason 'none') [70 80 0]
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8445] device (eth0): state change: ip-check -> secondaries (reason 'none') [80 90 0]
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8471] device (eth0): state change: secondaries -> activated (reason 'none') [90 100 0]
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8549] policy: set 'Ifupdown (eth0)' (eth0) as default for IPv4 routing and DNS
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8554] policy: set 'Ifupdown (eth0)' (eth0) as default for IPv6 routing and DNS
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.8565] dns-mgr: Writing DNS information to /sbin/resolvconf
Jun 17 00:45:20 localhost dnsmasq[892]: setting upstream servers from DBus
Jun 17 00:45:20 localhost dnsmasq[892]: using nameserver 192.168.1.1#53(via eth0)
Jun 17 00:45:20 localhost NetworkManager[655]: /etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /run/resolvconf/resolv.conf
Jun 17 00:45:20 localhost NetworkManager[655]: <info>  [1497660320.9894] device (eth0): Activation: successful, device activated.
Jun 17 00:45:20 localhost dbus[637]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Jun 17 00:45:21 localhost systemd[1]: Starting Network Manager Script Dispatcher Service...
Jun 17 00:45:21 localhost dbus[637]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 17 00:45:21 localhost systemd[1]: Started Network Manager Script Dispatcher Service.
Jun 17 00:45:21 localhost nm-dispatcher: req:1 'up' [eth0]: new request (1 scripts)
Jun 17 00:45:21 localhost nm-dispatcher: req:1 'up' [eth0]: start running ordered scripts...
Jun 17 00:45:21 localhost dhclient[2211]: XMT: Info-Request on eth0, interval 1970ms.
Jun 17 00:45:22 localhost ntpd[1083]: Listen normally on 9 eth0 192.168.1.7:123
Jun 17 00:45:22 localhost ntpd[1083]: new interface(s) found: waking up resolver
Jun 17 00:45:23 localhost dhclient[2211]: XMT: Info-Request on eth0, interval 4040ms.
Jun 17 00:45:23 localhost ntpd[1083]: 199.182.221.110 local addr 192.168.1.7 -> <null>
Jun 17 00:45:24 localhost ntpd[1083]: Soliciting pool server 139.59.199.215
Jun 17 00:45:25 localhost ntpd[1083]: Soliciting pool server 2001:67c:1560:8003::c8
Jun 17 00:45:26 localhost systemd[1]: Reloading OpenBSD Secure Shell server.
Jun 17 00:45:26 localhost systemd[1]: Reloaded OpenBSD Secure Shell server.
Jun 17 00:45:27 localhost dhclient[2211]: XMT: Info-Request on eth0, interval 7980ms.
Jun 17 00:45:35 localhost dhclient[2211]: XMT: Info-Request on eth0, interval 16390ms.
Jun 17 00:45:35 localhost rsyslogd-2007: action 'action 9' suspended, next retry is Sat Jun 17 00:46:05 2017 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jun 17 00:45:37 localhost systemd[1]: Reloading OpenBSD Secure Shell server.
Jun 17 00:45:37 localhost systemd[1]: Reloaded OpenBSD Secure Shell server.
Jun 17 00:45:51 localhost dhclient[2211]: XMT: Info-Request on eth0, interval 32540ms.
Jun 17 00:45:59 localhost systemd[1]: Created slice User Slice of root.
Jun 17 00:45:59 localhost systemd[1]: Starting User Manager for UID 0...
Jun 17 00:46:00 localhost systemd[2438]: Reached target Timers.
Jun 17 00:46:00 localhost systemd[2438]: Reached target Sockets.
Jun 17 00:46:00 localhost systemd[2438]: Reached target Paths.
Jun 17 00:46:00 localhost systemd[2438]: Reached target Basic System.
Jun 17 00:46:00 localhost systemd[2438]: Reached target Default.
Jun 17 00:46:00 localhost systemd[2438]: Startup finished in 398ms.
Jun 17 00:46:00 localhost systemd[1]: Started Session 7 of user root.
Jun 17 00:46:00 localhost systemd[1]: Started User Manager for UID 0.
Jun 17 00:46:02 localhost ntpd[1083]: Soliciting pool server 2001:440:1880:5555::2
Jun 17 00:46:05 localhost NetworkManager[655]: <warn>  [1497660365.3598] dhcp6 (eth0): request timed out
Jun 17 00:46:05 localhost rsyslogd-2007: action 'action 9' suspended, next retry is Sat Jun 17 00:47:05 2017 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Jun 17 00:46:05 localhost NetworkManager[655]: <info>  [1497660365.3601] dhcp6 (eth0): state changed unknown -> timeout
Jun 17 00:46:05 localhost NetworkManager[655]: <info>  [1497660365.3638] dhcp6 (eth0): canceled DHCP transaction, DHCP client pid 2211
Jun 17 00:46:05 localhost NetworkManager[655]: <info>  [1497660365.3640] dhcp6 (eth0): state changed timeout -> done
Jun 17 00:46:05 localhost NetworkManager[655]: <error> [1497660365.3715] platform-linux: do-add-ip6-address[2: fe80::e422:5cff:fedf:f4ad]: failure 22 (Invalid argument)
  • Author
The problem is, when i power the Opi+2, somehow it makes the modem disconnect from the internet. The DSL connection drops. I added wifi chip driver to "blacklist" but it didn't work.  The modem is: https://www.google.com.tr/search?q=vmg3312+b10b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiTvfblzsXUAhVKUlAKHZCOAeoQ_AUIBigB&biw=1366&bih=662#imgrc=IE2PwhVsI5KYcM:
And I also tried to use a different modem which is "Airties Air 5440" but it didn't work too.
If you think you can help, you can keep asking more questions.
It seems my opi has been turned to a DSL jammer.
  • Author
Hi, i have freshly installed the newest Armbian again and it seems the problem is fixed. But i am not really sure yet, please wait for my incoming reply.
BTW i can send you any file you want to investigate what caused this problem. And it was veery quirky.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
