September 24, 20242 yr Which version to install ARMBIAN on mxq pro 4K 5g with AllWinner H3 processor (N8050BA 96T4)?
September 24, 20242 yr Try my image https://github.com/sicXnull/armbian-build/releases/download/v24.8.0-trunk.425/Armbian-unofficial_24.11.0-trunk_X96q_bookworm_current_6.6.44_mate_desktop.img.xz I bought one of these too, it was advertised as a RK3228 on amazon but came with H313. iirc my x96q image booted right up on it. Edited September 24, 20242 yr by sicxnull
September 24, 20242 yr Author Use this from Sunvell R69. Works perfectly. HDMI Sound must enable I2C in dtb file [R69](https://mega.nz/file/V3QQyBaY#Y332sD2oa36L5BZa0xtANx1O6QrS_903Qj1RHg1vuy8)
September 27, 20242 yr Author [Desktop images with Armbian Linux](https://www.armbian.com/orange-pi-pc/) wifi not working, how to solve?
September 29, 20242 yr On 9/27/2024 at 3:22 PM, Bigal Linux said: [Desktop images with Armbian Linux](https://www.armbian.com/orange-pi-pc/) wifi not working, how to solve? Did you try my image that I linked you? Wifi should work
September 30, 20242 yr Hello, thanks sicxnull for the image. It served me well as I tried it on a tvbox of brand "Tourobox". However the Wi-Fi problem also happened to me and for what I can tell, it's because of lack of compatible drivers for the network module. As said by Devmfc, Quote Especially the wifi modules are a lottery On my perspective, Bigal Linux would need to identify the network module ( I think it's the one between the PPT and SKhynix that I couldnt identify) and search for the driver corresponding the chipset on /lib/modules/$(uname -r)/kernel/drivers/net/wireless. If found, then it should be loaded as a kernel module with "sudo insmod <driver.ko>". After that, if the "wlan0" interface is visible as an output of the command "ip a", then it worked. If the driver can't be found on the path given, maybe the only two possible ways of getting WiFi to work are: 1. Being lucky finding an image file with the driver you just need, or 2. finding the driver on the Internet (some github repo) , compiling it yourself and then loading it as a kernel module (nice and friendly) or recompiling the kernel (very nice, but kinda hard). Nevertheless, I sure wish luck on Bigal Linux journey to thrive upon the problems of his cursed hardware. I will be doing it myself for the Tourobox.
October 6, 20242 yr sicxnull: very kind for publishing that compilation. It worked for me on an h313, it started immediately and everything works. I would like to know if you don't have a "minimal" compilation
December 19, 20241 yr Hey! @sicxnull I flashed your image on an SD card using balenaEtcher and I'm trying to boot it from a similar board as our friend here. Allwinner H3. Problem is that it doesn't boot from the SD card, it keeps booting from the current image. I have tried some images of LibreElec (https://libreelec.tv/downloads/allwinner/) and the board actually tries to boot from the SD (though it gets stuck into "Loading Kernel..."). Am I missing something with your image booting process? Thanks!
January 14, 20251 yr @radzki While not an allwinner H3 box, I had an Amlogic box that I used libreelec on, and after that booting from Armbian kept failing. You could try a factory reset from the "current image" presumably android and see if that changes your experience. Bit more detail at
July 24, 20251 yr I need a Linux image for this model that works with Wi-Fi and internal memory. No graphical interface.
October 22, 2025Oct 22 Hello, everyone! I have this same exact model, however, when I tried to boot it from the SD card it does nothing, I tried to hold the reset button and it seems to be stuck on boot. I used etcher to image the file shared by sicxnull, do I need to edit anything else? Am I míssing something? Thanks in advance for the help.
October 22, 2025Oct 22 my tv box: MXQ pro 4K 5G, Q44_V5.1_20210118, PROCESSOR: ALLWINNER TECH H3 LC267BA 91F2. I recorded the image on a 32gb sd card, but it doesn't boot. Has anyone solved it?
November 29, 2025Nov 29 can this SoC boot from a USB drive? i've tried it multiple times and it didnt work.
January 13Jan 13 Hello!! I am looking for help to boot Armbian on a generic TV Box sold as "MXQ Pro 4K 5G". I have tried multiple images (including official and community builds from sicXnull), but I only get a black screen or signal loss immediately after the boot attempt. Device Specifications: Model on case: MXQ Pro 4K 5G Board ID: IK316Q-EMCP_V4.1 SoC: Allwinner H313 (identified as sun50iw9p1 in Android) RAM: 1GB (Single chip configuration) Storage: 8GB eMMC Current Status: I am able to boot into the stock Android. To attempt the Armbian boot, I've tryed the Power up method, the power up pressing the hidden AV switch, using the reboot update command from a terminal emulator within Android. The issue: Upon executing the reboot command, the Android system shuts down, the display signal cuts off (or stays black), and the device never initializes Armbian (no HDMI output, no LEDs blinking differently). What I have tried:
January 18Jan 18 Hi, how are you? Well, I don't know English very well, so this text will be translated using Google Translate since I'm Brazilian. Anyway. I found a way to boot the SD card with Linux on the Allwinner H3 chip, using a Chinese MXQ 4K 5G TV box. I booted Android normally and, using the remote control, pressed the power button and then confirmed. After shutting down, I booted with the remote control and Linux started normally. After that, every time I booted with the SD card, it booted perfectly. Another thing I did before, but I believe it doesn't affect this, was to enable USB0 device mode in developer mode. I hope this information helps with your Linux projects! Edited January 18Jan 18 by jolodro
March 16Mar 16 Dear Sir/Madam, I am writing to request the official firmware for my Trenspeed H616 device. I accidentally installed an Orange Pi firmware, which caused my device to lose the Google Play Store and essential services. Device specifications: Board: T98_616_LP3_210222 Memory: 4GB RAM / 32GB storage Current version: Android 10 I would greatly appreciate it if you could provide a link to the official firmware or instructions for the correct update, ensuring that it includes Google Play Store and core services. Thank you very much for your assistance.
March 16Mar 16 @naceur abdelkader Your post has nothing to do with Armbian. Please find a more appropriate site to ask your question. This site is for Armbian linux.
March 18Mar 18 Hi all, For whom who are looking for the image to be installed on this box: I have the same mxq box with H3 SoC and I flashed the Tritium H3 (libre) armbian image successfully and playing with it for year. Wifi not working, not sure about Bluetooth because I don't use them at all. Currently it works as my cups printer server for my brother usb printer. Edited March 18Mar 18 by quan Typo
