Skip to content
View in the app
Armbian Community Forums
fonts-liberation missing on Armbian 24.8.1 Orangepi5-plus noble
Featured Replies
Hi
I got ugly fonts in chromium. It seems the package fonts-liberation was missing.
I did not have the issue with the Uefi-x86 version.
Kind regards
Philippe
sudo apt install fonts-liberation
will fix that of course. You dont say what desktop you are using, but current armbian-build does have this package in desktop base packages for noble kde-plasma and i3-wm desktops
but not cinnamon/gnome.
  • Author
I would vote to include it anyway, it's not like a service like samba, nextcloud or whatever service. When you use the chromium browser you will notice it soon there is something odd about the fonts, spacing is very big. The info of the packages says this:
Quote
ii  fonts-liberation 1:2.1.5-3    all          fonts with the same metrics as Times, Arial and Courier
These are everyday fonts.
Edited by phiser678
  • Author
Hello Igor
Thank you for looking into this minor issue.
I noticed it when using Syncthing. The first image shows the page without fonts-liberation, the second after installing  the necessary fonts.
I wanted to change the title of this topic, because it seems not limited to Orange Pi 5 only.
PS. Another surprise was there is no chromium installed in the Raspberry Pi 3 & 4 Armbian 24.8.1 Noble Gnome version.  Will I make a new issue?
Perfect example to explain how anyone can fix such trivial problems without involving me. Which is essential for the project to survive. There are and always will be way too many problems for too little maintainers ... Bug is here, yes, and can be easily fixed, especially if you already have a solution. I am happier to provide guidance then doing this on my own (which takes a lot less efforts).
Solution is adding a package here:
https://github.com/armbian/build/blob/main/config/desktop/jammy/environments/gnome/config_base/packages
(jammy has same packages as noble and is symlinked).
Every contribution counts, even this banal.
We have different Chromium versions, patched for this and that, then with and without snap ... It is a surprise that we can provide a desktop where accelerated video playback works on Rockchip RK35xx platform, which we support better then Rpi. Where all this probably just works if you download any Chromium?
  • Author
Thanks Igor, I can agree, the experience with Armbian on Orange Pi 5 plus is amazing.
Because you have mentioned the URL, I should do a pull request instead?
It's a bit strange i thought I did not encounter this problem on the  Uefi-x86 version. The different platforms do not share the same build packages blob?
So, for raspi 3 & 4 I would suggest to have the chromium package, these are by default in Orange Pi 5 and  Uefi-x86 builds and then the experience is the same (except for the hardware accelerated video playback that you mentioned, 480p works ok though).
I guess the fonts-liberation package should work with the snap versions  and will solve this issue.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
