Skip to content
View in the app
Armbian Community Forums
OPI 4A - Allwinner T527
Featured Replies
Am 3.1.2026 um 22:15 schrieb L. Jorge Soares:
resetting ...
sunxi_set_gate: (CLK#35) unhandled
U-Boot SPL 2026.01-rc4_armbian-2026.01-rc4-S0e0a-P5fd4-H5aa4-Vd69a-B4d1d-R448a (Jan 03 2026 - 15:39:28 -0500)
DRAM: 4096 MiB
Failed to set core voltage! Can't set CPU frequency
Trying to boot from MMC1
NOTICE:  BL31: v2.12.0(debug):armbian
NOTICE:  BL31: Built : 14:33:47, Jan  3 2026
NOTICE:  BL31: Detected Allwinner A523 SoC (1890)
NOTICE:  BL31: Found U-Boot DTB at 0xa0a8d48, model: OrangePi 4A
INFO:    GICv3 without legacy support detected.
INFO:    ARM GICv3 driver initialized in EL3
INFO:    Maximum SPI INTID supported: 287
INFO:    Configuring SPC Controller
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a55: CPU workaround for erratum 1530923 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
ns16550_serial serial@2500000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2026.01-rc4_armbian-2026.01-rc4-S0e0a-P5fd4-H5aa4-Vd69a-B4d1d-R448a (Jan 03 2026 - 15:39:28 -0500) Allwinner Technology
CPU:   Allwinner A523 (SUN55I)
Model: OrangePi 4A
DRAM:  4 GiB
Core:  65 devices, 21 uclasses, devicetree: separate
WDT:   Not starting watchdog@2050000
MMC:   mmc@4020000: 0, mmc@4021000: 1, mmc@4022000: 2
Loading Environment from FAT... ** No valid partitions found **
In:    serial@2500000
Out:   serial@2500000
Err:   serial@2500000
Net:   No ethernet found.
Hit any key to stop autoboot: 0
PCIe: Acquiring resources...
PCIe: Failed to parse num-lanes, using default: 1
PCIe: Failed to get switch-sel GPIO: -2
PCIe: Hardware init failed with error -2
Device 0: unknown device
switch to partitions #0, OK
mmc0 is current device
** Invalid partition 1 **
Couldn't find partition mmc 0:1
No ethernet found.
missing environment variable: pxeuuid
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
Can you test these commands in u-boot?
mmc list
mmc info
mmc dev 0
mmc part
fatls mmc 0:1
ext4ls mmc0:2
mmc read 0x40000000 0 1
It seems like mega doesnt work anymore without login.
Here are the images on gdrive: https://drive.google.com/drive/folders/1jEIWmzZgT5t39jRz7GwZpFOAdjdQBLtG?usp=drive_link
Edited by Marvin-03
@Marvin-03
Here are the results of the commands provided, hope this help.  Thanks for the link of your image builds, will try them out.
Quote
=> mmc list
mmc@4020000: 0 (SD)
mmc@4021000: 1
mmc@4022000: 2
=> mmc info
Device: mmc@4020000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode: SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
=> mmc dev 0
=> mmc part
Partition Map for mmc device 0  --   Partition Type: EFI
=> fatls mmc 0:1
=> ext4ls mmc 0:2
** Invalid partition 2 **
Couldn't find partition mmc 0:2
=> fatls mmc0:1
** No device specified **
Couldn't find partition mmc0:1 <NULL>
=> ext4ls mmc0:2
Couldn't find partition mmc0:2 <NULL>
=> mmc read 0x40000000 0 1
MMC read: dev # 0, block # 0, count 1 ... 1 blocks read: OK
vor 15 Stunden schrieb L. Jorge Soares:
=> mmc list
mmc@4020000: 0 (SD)
mmc@4021000: 1
mmc@4022000: 2
=> mmc info
Device: mmc@4020000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
=> mmc dev 0
=> mmc part
=> fatls mmc 0:1
=> ext4ls mmc 0:2
=> fatls mmc0:1
=> ext4ls mmc0:2
Did you get an error when using balena etcher? I tried flashing the image myself and it wouldnt create any partitions.
I uploaded an image with a repaired partition table to gdrive and mega.
Alternatively, you can use gparted to repair the image yourself.
Just put:
sudo gdisk /path/to/Armbian-unofficial_26.02.0-trunk_Orangepi4a_trixie_edge_6.18.0.img
 r (recovery), then d (recreate primary header), then w (write) into wsl or linux.
I did get an alert from BalenaEtcher, when writting the IMG file to SD. It reported not having a BOOT partition.
I continued through the alert and the PI board did boot to the prompt results I originally reported.
I am going try you image now and will let you know.
@Marvin-03
** run the commands to fix partitions on my IMG build, just like you mentioned and it fixed it.**
Your Orangepi4a img is working, I am able to BOOT. But I am accessing the board through the console. Confirmation of the boot is below.
I also had a look at the partitions from the IMG created of the GIT build and your own image. See details below.
Quote
    _             _    _                             __  __ _    _      _
   /_\  _ _ _ __ | |__(_)__ _ _ _ ___ _  _ _ _  ___ / _|/ _(_)__(_)__ _| |
  / _ \| '_| '  \| '_ \ / _` | ' \___| || | ' \/ _ \  _|  _| / _| / _` | |
 /_/ \_\_| |_|_|_|_.__/_\__,_|_||_|   \_,_|_||_\___/_| |_| |_\__|_\__,_|_|
 v26.02 rolling for Orange Pi 4a running Armbian Linux 6.18.0-edge-sun55iw3
 Packages:     Debian stable (trixie)
 Support:      DIY (custom image)
 IPv4:         (LAN) 10.10.10.191 (WAN) ##.##.##.##
 Performance:
 Load:         14%               Uptime:       4 minutes
 Memory usage: 4% of 3.83G
 Usage of /:   7% of 29G
 Tips:
 Armbian config utility https://tinyurl.com/yc39n6m3
 Commands:
 Configuration : armbian-config
 Monitoring    : htop
root@orangepi4a:~#
This is the partitions list of the IMG build of GIT
Quote
Disk /dev/sdc: 29.72 GiB, 31914983424 bytes, 62333952 sectors
Disk model: MassStorageClass
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device     Boot Start      End  Sectors  Size Id Type
/dev/sdc1           1 62333951 62333951 29.7G ee GPT
This is the partition list of your IMG for comparison
Quote
Disklabel type: gpt
Disk identifier: 09A4CB82-9D1D-424A-BA48-7D406DF8EF24
Device       Start     End Sectors  Size Type
/dev/sdc1     8192 1056767 1048576  512M Linux extended boot
/dev/sdc2  1056768 5683199 4626432  2.2G Linux root (ARM-64)
Edited by L. Jorge Soares
Am 5.1.2026 um 22:26 schrieb L. Jorge Soares:
Looks like your GIT no longer has the changes for OrangePI4a board available.
I updated my patches to the new style (using series.conf) and that took some time. They are back online, as are some new images. I post more updates at the opi discord btw.
The image doesnt work stable atm.
Network works, pcie and spi flash doesnt.
Edited by Marvin-03
vor 19 Stunden schrieb Edmilson Santos:
Is possible first acces via SSH? no HDMI for me 😞 Just led of network activity. But no dhcp
Ethernet should be working (after rebooting), but wifi doesnt work out of the box.
Hi all, I've spend a few evenings playing with the Armbian build-system and OPI4a, mainly trying to get Ethernet working reliably. There are two issues I've found:
  • (almost) every second boot there are errors with PHY access (as if there was a race somewhere),
  • neither DHCP nor static IPs are working (in scnerios when there are no issues with PHY).
I've mainly focused on comparing Devicetrees to OrangePis' sources, and from newbie perspective, at least Ethernet part seems pretty complete.
The next logical step would be to focus on the driver, but I figured, I'd ask if maybe someone has also been trying to work it out, and proceeded further?
I'd appreciate any ideas of what I should check next.
Issues for the actual image (no UI): no HDMI; Ethernet got address with DHCP, but cannot connect with SSH, even ping (ICMP) is not stable. Wifi works fine. The board is OK - tested with official debian image.
was trying the Armbian Imager because i was searching for an image for OrangePI RV2 that is not in download but is in the imager utility...
And the RV2 image is marked of course as WorkInProgress...
But i saw that here there is also 2 image for 4a maked as community support.. (that should be better than WIP)
there is a command line trixie and a noble with XFCE (that let me think that HDMI works) somebody tried these images?
If are usable i will plan to order a 4A that looks more interesting than RV2
  • Author
I am having issues with eMMC detection…
The kernel does not detect the eMMC, but apparently U-Boot does.
Attached are images.
Hello
I flashed Armbian 26.2.0-trunk.606 on a SD Card.
But my Orange pi 4a does not boot: only red led.
It boots well with the Orange image Orangepi4a_1.0.4_ubuntu_jammy_desktop_gnome_linux5.15.147.7
Any idea ? is there something to update ?
Thanks
Armbian_community 26.2.0-trunk.639 Trixie ttyS0
Ethernet is unstable, cannot connect with SSH, useDns, mtu change - did not help. WiFi is not initialized anymore.
Quote
Working FDT set to 4fa00000
Failed to load '/dtb/allwinner/overlay/sun55i-t527-fixup.scr'
I can confirm there is no file. I tried to fix it with AI help and did a lot of stuff, nothing worked.
Bu once decreasing speed to 100 ethtool -s end0 speed 100 duplex full autoneg on it started to work. Now I can connect via SSH and apt update work as well.
On 3/30/2026 at 8:34 AM, Werner said:
I suggest to try 7.0 kernel from "edge".
hello i try  image "Armbian-unofficial_26.05.0-trunk_Orangepi-4a_trixie_edge_7.0.0-rc5.img"
not detected emmc and wifi. ethernet crushed periodically
Spoiler
U-Boot SPL 2026.01_armbian-2026.01-S127a-P4a70-H560c-Vf757-B138f-R448a (Mar 30 2026 - 12:17:42 +0000)
DRAM: 4096 MiB
NOTICE:  BL31: v2.13.0(debug):armbian
NOTICE:  BL31: Built : 14:43:23, Jan 25 2026
NOTICE:  BL31: Found U-Boot DTB at 0xa0b8ac0, model: OrangePi 4A
INFO:    SPSR = 0x3c9
U-Boot 2026.01_armbian-2026.01-S127a-P4a70-H560c-Vf757-B138f-R448a (Mar 30 2026 - 12:17:42 +0000) Allwinner Technology
Model: OrangePi 4A
DRAM:  4 GiB
Core:  94 devices, 24 uclasses, devicetree: separate
MMC:   mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
In:    serial@2500000
Out:   serial@2500000
Err:   serial@2500000
starting USB...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Bus usb@4101000: 1 USB Device(s) found
Bus usb@4101400: 1 USB Device(s) found
Bus usb@4200000: 2 USB Device(s) found
Bus usb@4200400: 1 USB Device(s) found
Scanning mmc 0:1...
Found U-Boot script /boot.scr
4641 bytes read in 1 ms (4.4 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
241 bytes read in 0 ms
Load fdt: /dtb/allwinner/sun55i-t527-orangepi-4a.dtb
33383 bytes read in 4 ms (8 MiB/s)
24477048 bytes read in 1024 ms (22.8 MiB/s)
36383232 bytes read in 1522 ms (22.8 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x425a0000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    24476984 Bytes = 23.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 488a8000, end 49fffd38 ... OK
   Loading Device Tree to 0000000048837000, end 00000000488a7fff ... OK
Working FDT set to 48837000
Starting kernel ...
done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Will now check root file system ... fsck from util-linux 2.41
[/sbin/fsck.ext4 (1) -- /dev/mmcblk0p2] fsck.ext4 -a -C0 /dev/mmcblk0p2
armbi_root: clean, 43559/1825280 files, 580914/7531520 blocks
done.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
SELinux:  Could not open policy file <= /etc/selinux/default/policy/policy.35:  No such file or directory
Welcome to Armbian-unofficial 26.05.0-trunk trixie!
[  OK  ] Created slice system-getty.slice - Slice /system/getty.
[  OK  ] Created slice system-modprobe.slice - Slice /system/modprobe.
[  OK  ] Created slice system-serial\x2dget…slice - Slice /system/serial-getty.
[  OK  ] Created slice system-systemd\x2dfs…slice - Slice /system/systemd-fsck.
[  OK  ] Created slice user.slice - User and Session Slice.
[  OK  ] Started systemd-ask-password-wall.…d Requests to Wall Directory Watch.
[  OK  ] Set up automount proc-sys-fs-binfm…ormats File System Automount Point.
         Expecting device dev-disk-by\x2duu…ce - /dev/disk/by-uuid/A9C5-5D8E...
         Expecting device dev-ttyS0.device - /dev/ttyS0...
[  OK  ] Reached target slices.target - Slice Units.
[  OK  ] Reached target swap.target - Swaps.
[  OK  ] Listening on rpcbind.socket - RPCbind Server Activation Socket.
[  OK  ] Listening on syslog.socket - Syslog Socket.
[  OK  ] Listening on systemd-creds.socket - Credential Encryption/Decryption.
[  OK  ] Listening on systemd-initctl.socke…- initctl Compatibility Named Pipe.
[  OK  ] Listening on systemd-journald-dev-…socket - Journal Socket (/dev/log).
[  OK  ] Listening on systemd-journald.socket - Journal Sockets.
[  OK  ] Listening on systemd-udevd-control.socket - udev Control Socket.
[  OK  ] Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
         Mounting dev-mqueue.mount - POSIX Message Queue File System...
         Mounting run-lock.mount - Legacy Locks Directory /run/lock...
         Mounting sys-kernel-debug.mount - Kernel Debug File System...
         Mounting sys-kernel-tracing.mount - Kernel Trace File System...
         Starting fake-hwclock-load.service - Restore the current clock...
         Starting keyboard-setup.service - Set the console keyboard layout...
         Starting kmod-static-nodes.service…eate List of Static Device Nodes...
         Starting modprobe@configfs.service - Load Kernel Module configfs...
         Starting modprobe@drm.service - Load Kernel Module drm...
         Starting modprobe@efi_pstore.servi… - Load Kernel Module efi_pstore...
         Starting modprobe@fuse.service - Load Kernel Module fuse...
         Starting systemd-modules-load.service - Load Kernel Modules...
         Starting systemd-udev-load-credent…Load udev Rules from Credentials...
         Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[  OK  ] Mounted dev-mqueue.mount - POSIX Message Queue File System.
[  OK  ] Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[  OK  ] Mounted sys-kernel-debug.mount - Kernel Debug File System.
[  OK  ] Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[  OK  ] Finished kmod-static-nodes.service…Create List of Static Device Nodes.
[  OK  ] Finished fake-hwclock-load.service - Restore the current clock.
[  OK  ] Finished modprobe@configfs.service - Load Kernel Module configfs.
[  OK  ] Finished modprobe@drm.service - Load Kernel Module drm.
[  OK  ] Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
         Mounting sys-kernel-config.mount - Kernel Configuration File System...
         Starting systemd-remount-fs.servic…unt Root and Kernel File Systems...
         Starting systemd-tmpfiles-setup-de… Device Nodes in /dev gracefully...
[  OK  ] Finished modprobe@fuse.service - Load Kernel Module fuse.
[  OK  ] Finished systemd-modules-load.service - Load Kernel Modules.
         Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
         Starting systemd-sysctl.service - Apply Kernel Variables...
[  OK  ] Mounted sys-kernel-config.mount - Kernel Configuration File System.
[  OK  ] Finished systemd-udev-load-credent…- Load udev Rules from Credentials.
[  OK  ] Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[  OK  ] Finished systemd-sysctl.service - Apply Kernel Variables.
[  OK  ] Finished systemd-remount-fs.servic…mount Root and Kernel File Systems.
         Starting systemd-random-seed.service - Load/Save OS Random Seed...
[  OK  ] Finished systemd-tmpfiles-setup-de…ic Device Nodes in /dev gracefully.
         Starting systemd-resolved.service - Network Name Resolution...
         Starting systemd-tmpfiles-setup-de…eate Static Device Nodes in /dev...
[  OK  ] Finished systemd-tmpfiles-setup-de…Create Static Device Nodes in /dev.
         Starting systemd-udevd.service - R…ager for Device Events and Files...
[  OK  ] Finished keyboard-setup.service - Set the console keyboard layout.
[  OK  ] Reached target local-fs-pre.target…Preparation for Local File Systems.
[  OK  ] Started systemd-udevd.service - Ru…anager for Device Events and Files.
[  OK  ] Finished systemd-udev-trigger.service - Coldplug All udev Devices.
         Starting plymouth-start.service - Show Plymouth Boot Screen...
[  OK  ] Found device dev-ttyS0.device - /dev/ttyS0.
[  OK  ] Finished systemd-random-seed.service - Load/Save OS Random Seed.
         Mounting tmp.mount - /tmp...
[  OK  ] Mounted tmp.mount - /tmp.
[  OK  ] Started plymouth-start.service - Show Plymouth Boot Screen.
[  OK  ] Started systemd-resolved.service - Network Name Resolution.
[  OK  ] Started systemd-ask-password-plymo…quests to Plymouth Directory Watch.
[  OK  ] Reached target nss-lookup.target - Host and Network Name Lookups.
[  OK  ] Reached target paths.target - Path Units.
[  OK  ] Listening on systemd-rfkill.socket…ll Switch Status /dev/rfkill Watch.
[  OK  ] Found device dev-disk-by\x2duuid-A…vice - /dev/disk/by-uuid/A9C5-5D8E.
         Starting systemd-fsck@dev-disk-by\…k on /dev/disk/by-uuid/A9C5-5D8E...
         Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
[  OK  ] Reached target bluetooth.target - Bluetooth Support.
[  OK  ] Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
[  OK  ] Finished systemd-fsck@dev-disk-by\…eck on /dev/disk/by-uuid/A9C5-5D8E.
         Mounting boot.mount - /boot...
[  OK  ] Mounted boot.mount - /boot.
[  OK  ] Reached target local-fs.target - Local File Systems.
[  OK  ] Listening on systemd-sysext.socket… System Extension Image Management.
         Starting armbian-zram-config.service - Armbian ZRAM config...
         Starting console-setup.service - Set console font and keymap...
         Starting plymouth-read-write.servi…ymouth To Write Out Runtime Data...
         Starting systemd-binfmt.service - Set Up Additional Binary Formats...
[  OK  ] Finished console-setup.service - Set console font and keymap.
[  OK  ] Finished plymouth-read-write.servi…Plymouth To Write Out Runtime Data.
         Mounting proc-sys-fs-binfmt_misc.m…cutable File Formats File System...
[  OK  ] Mounted proc-sys-fs-binfmt_misc.mo…xecutable File Formats File System.
[  OK  ] Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[  OK  ] Finished armbian-zram-config.service - Armbian ZRAM config.
         Starting armbian-ramlog.service - Armbian memory supported logging...
[  OK  ] Finished armbian-ramlog.service - Armbian memory supported logging.
         Starting systemd-journald.service - Journal Service...
[  OK  ] Started systemd-journald.service - Journal Service.
         Starting systemd-journal-flush.ser…sh Journal to Persistent Storage...
[  OK  ] Finished systemd-journal-flush.ser…lush Journal to Persistent Storage.
         Starting systemd-tmpfiles-setup.se…ate System Files and Directories...
[  OK  ] Finished systemd-tmpfiles-setup.se…reate System Files and Directories.
         Mounting run-rpc_pipefs.mount - RPC Pipe File System...
         Starting rpcbind.service - RPC bind portmap service...
[  OK  ] Reached target sysinit.target - System Initialization.
[  OK  ] Started apt-daily.timer - Daily apt download activities.
[  OK  ] Started apt-daily-upgrade.timer - …y apt upgrade and clean activities.
[  OK  ] Started dpkg-db-backup.timer - Daily dpkg database backup timer.
[  OK  ] Started e2scrub_all.timer - Period…Metadata Check for All Filesystems.
[  OK  ] Started fake-hwclock-save.timer - Periodically save current clock.
[  OK  ] Started fstrim.timer - Discard unused filesystem blocks once a week.
[  OK  ] Started logrotate.timer - Daily rotation of log files.
[  OK  ] Started man-db.timer - Daily man-db regeneration.
[  OK  ] Started systemd-tmpfiles-clean.tim…y Cleanup of Temporary Directories.
[  OK  ] Reached target timers.target - Timer Units.
[  OK  ] Listening on dbus.socket - D-Bus System Message Bus Socket.
[  OK  ] Listening on sshd-unix-local.socke…temd-ssh-generator, AF_UNIX Local).
[  OK  ] Listening on systemd-hostnamed.socket - Hostname Service Socket.
[  OK  ] Reached target sockets.target - Socket Units.
         Starting armbian-hardware-monitor.…ce - Armbian hardware monitoring...
         Starting armbian-hardware-optimize… - Armbian hardware optimization...
         Starting armbian-led-state.service - Armbian leds state...
[  OK  ] Finished armbian-hardware-monitor.…vice - Armbian hardware monitoring.
[  OK  ] Finished armbian-led-state.service - Armbian leds state.
[  OK  ] Mounted run-rpc_pipefs.mount - RPC Pipe File System.
[  OK  ] Reached target rpc_pipefs.target.
         Starting nfs-blkmap.service - pNFS block layout mapping daemon...
[  OK  ] Reached target nfs-client.target - NFS client services.
[  OK  ] Started rpcbind.service - RPC bind portmap service.
[  OK  ] Finished armbian-hardware-optimize…ce - Armbian hardware optimization.
[  OK  ] Reached target basic.target - Basic System.
[  OK  ] Reached target remote-fs-pre.targe…reparation for Remote File Systems.
[  OK  ] Reached target remote-fs.target - Remote File Systems.
[  OK  ] Reached target rpcbind.target - RPC Port Mapper.
         Starting chrony.service - chrony, an NTP client/server...
[  OK  ] Started cron.service - Regular background program processing daemon.
         Starting dbus.service - D-Bus System Message Bus...
         Starting e2scrub_reap.service - Re…ne ext4 Metadata Check Snapshots...
         Starting rng-tools-debian.service …gatherer daemon (Debian variant)...
         Starting rsyslog.service - System Logging Service...
         Starting systemd-logind.service - User Login Management...
[  OK  ] Started nfs-blkmap.service - pNFS block layout mapping daemon.
[  OK  ] Finished e2scrub_reap.service - Re…line ext4 Metadata Check Snapshots.
[  OK  ] Started systemd-logind.service - User Login Management.
[  OK  ] Started dbus.service - D-Bus System Message Bus.
         Starting NetworkManager.service - Network Manager...
         Starting wpa_supplicant.service - WPA supplicant...
[  OK  ] Started rsyslog.service - System Logging Service.
[  OK  ] Started chrony.service - chrony, an NTP client/server.
[  OK  ] Started wpa_supplicant.service - WPA supplicant.
         Starting systemd-hostnamed.service - Hostname Service...
[  OK  ] Started systemd-hostnamed.service - Hostname Service.
         Starting NetworkManager-dispatcher…anager Script Dispatcher Service...
[  OK  ] Started NetworkManager.service - Network Manager.
[  OK  ] Reached target network.target - Network.
         Starting NetworkManager-wait-onlin…ce - Network Manager Wait Online...
         Starting openvpn.service - OpenVPN service...
         Starting ssh.service - OpenBSD Secure Shell server...
         Starting systemd-user-sessions.service - Permit User Sessions...
[  OK  ] Started unattended-upgrades.service - Unattended Upgrades Shutdown.
[  OK  ] Started vnstat.service - vnStat network traffic monitor.
[  OK  ] Started NetworkManager-dispatcher.… Manager Script Dispatcher Service.
[  OK  ] Finished openvpn.service - OpenVPN service.
[  OK  ] Finished systemd-user-sessions.service - Permit User Sessions.
[  OK  ] Started ssh.service - OpenBSD Secure Shell server.
[  OK  ] Finished NetworkManager-wait-onlin…vice - Network Manager Wait Online.
[  OK  ] Reached target network-online.target - Network is Online.
         Starting rc-local.service - /etc/rc.local Compatibility...
         Starting rpc-statd-notify.service - Notify NFS peers of a restart...
[  OK  ] Started rc-local.service - /etc/rc.local Compatibility.
         Starting plymouth-quit-wait.servic…d until boot process finishes up...
         Starting plymouth-quit.service - Terminate Plymouth Boot Screen...
[  OK  ] Started rpc-statd-notify.service - Notify NFS peers of a restart.
Armbian-unofficial 26.05.0-trunk Trixie ttyS0
Edited by Nick_Sl
I'd like to add my observations. The current version is 7.0.0-rc6-edge-sunxi64. The wireless interface is available, but if Ethernet is connected, it's impossible to connect to either interface via SSH. However, as soon as the Ethernet speed is set to 100, both interfaces become operational. Maybe this will help revive the hardware.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
