Skip to content
View in the app
Armbian Community Forums
Armbian update && upgrade -y for users located in RU site
Featured Replies
Hi Arambian support team,
I have a problem with "sudo apt update && apt upgrade -y" of my Nano Pi R4S
1) if i use ru_RU.UTF-8 and RU timezone than i have:
W: Не удалось получить http://apt.armbian.com/dists/bookworm/InRelease 502  Bad Gateway [my_ru_ip_addres]:[Port_80]
W: Некоторые индексные файлы скачать не удалось. Они были проигнорированы, или вместо них были использованы старые версии.
Translations:
W: Failed to get http://apt.armbian.com/dists/bookworm/InRelease 502 Bad Gateway [my_ru_ip_addres]:[Port_80]
W: Some index files could not be downloaded. They were ignored or old versions were used instead.
2) if i use US locations and RU timezone than i have:
Err:7 http://fastmirror.pp.ua/armbian bookworm/main arm64 armbian-bsp-cli-nanopi-r4s-current arm64 24.11.1
  Cannot initiate the connection to fastmirror.pp.ua:80 (2a01:d0:fa02:5555:6829:17ff:fe25:da0c). - connect (101: Network is unreachable) Could not connect to fastmirror.pp.ua:80 (93.126.105.202), connection timed out
Err:9 http://fastmirror.pp.ua/armbian bookworm/main arm64 linux-dtb-current-rockchip64 arm64 25.2.1
Fetched 159 MB in 1min 58s (1,341 kB/s)
E: Failed to fetch http://fastmirror.pp.ua/armbian/pool/main/a/armbian-bsp-cli-nanopi-r4s-current/armbian-bsp-cli-nanopi-r4s-current_24.11.1_arm64__1-PC980a-V0406-H3400-B6e44-R7697.deb Cannot initiate the connection to fastmirror.pp.ua:80 (2a01:d0:fa02:5555:6829:17ff:fe25:da0c). - connect (101: Network is unreachable) Could not connect to fastmirror.pp.ua:80 (93.126.105.202), connection timed out
E: Failed to fetch http://fastmirror.pp.ua/armbian/pool/main/l/linux-dtb-current-rockchip64/linux-dtb-current-rockchip64_25.2.1_arm64__6.12.12-Sd914-D7b0b-P083d-C67e9Heb51-HK01ba-Vc222-B8de6-R448a.deb  Cannot initiate the connection to fastmirror.pp.ua:80 (2a01:d0:fa02:5555:6829:17ff:fe25:da0c). - connect (101: Network is unreachable)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I mean connection failed
As for accessibility you can use free hosting for the Arambian repository for users located in Russia.
@Igor @Werner could you pls to change for RU users arambian repo, for example, it may be https://sourceforge.net/ servers by default update and upgrade, and problem with Arambian update and upgrade will be sloved for RU users
I mean https://sourceforge.net/
Because they provide free hosting and free repository hosting for OpenSource projects
For example, if you know VPN PassWall/PassWall2 uses https://sourceforge.net/ for repository hosting.
Connection to http://apt.armbian.com/ servers is not available in Russia right now or it may be my provider problems.
Connection to http://fastmirror.pp.ua/ servers is not available in Russia right now or it may be my provider problems.
Connection to https://sourceforge.net/ servers is available in Russia right now. <-:thumbup:
Or could you pls advise how i can fix the problem ?
Edited by Superuser
Solved by Igor
  • Werner changed the title to Armbian update && upgrade -y for users located in RU site
Redirector works on your IP address location, not timezone.
We are aware of the problem and we are somewhere in the middle of solving it. Support for "don't use these mirrors for this country" was added to the code https://github.com/armbian/armbian-router (actually quite some time ago) but this was not yet pushed to production. Low resources / no time, there is always something more urgent ... @Efe Çetin started working on redeployment and re-configuring about a week ago and re-deployment of paste.bin server (which is also in bad shape). I would estimate task completion of this transition in about a week. Can only apologize for troubles and ask for patience. We do what we can.
We have two fast mirrors in Russia:
https://mirror.yandex.ru/mirrors/armbian/(Moscow)
https://stpete-mirror.armbian.com/ (St. Petersburg)
but if Ukrainian are closer, you will get those ...
Other mirrors: https://docs.armbian.com/Mirrors/
This is re-director entry point, located in USA, Chicago. This should always work.
https://whatismyipaddress.com/ip/130.185.239.78
This is also getting moved to another ISP, but will stay in USA.
19 часов назад, Superuser сказал:
leo@bananapim64:~$ sudo nano /etc/apt/sources.list.d/armbian.list
http://apt.armbian.com =>> https://stpete-mirror.armbian.com/apt
leo@bananapim64:~$ cat /etc/apt/sources.list.d/armbian.list
deb [signed-by=/usr/share/keyrings/armbian.gpg] https://stpete-mirror.armbian.com/apt bookworm main bookworm-utils bookworm-desktop
leo@bananapim64:~$ sudo apt update
Сущ:1 http://deb.debian.org/debian bookworm InRelease
Сущ:2 http://security.debian.org bookworm-security InRelease
Сущ:3 http://deb.debian.org/debian bookworm-updates InRelease
Сущ:4 http://deb.debian.org/debian bookworm-backports InRelease
Сущ:5 https://github.armbian.com/configng stable InRelease
Пол:6 https://stpete-mirror.armbian.com/apt bookworm InRelease [53,3 kB]
Пол:7 https://stpete-mirror.armbian.com/apt bookworm/main all Packages [17,5 kB]
Пол:8 https://stpete-mirror.armbian.com/apt bookworm/bookworm-utils arm64 Packages [37,4 kB]
Пол:9 https://stpete-mirror.armbian.com/apt bookworm/bookworm-desktop all Packages [7 526 B]
Пол:10 https://stpete-mirror.armbian.com/apt bookworm/main arm64 Packages [1 168 kB]
Пол:11 https://stpete-mirror.armbian.com/apt bookworm/bookworm-desktop arm64 Packages [15,9 kB]
Пол:12 https://stpete-mirror.armbian.com/apt bookworm/bookworm-utils all Packages [3 965 B]
Получено 1 304 kB за 9с (149 kB/s)
Чтение списков пакетов… Готово
Построение дерева зависимостей… Готово
Чтение информации о состоянии… Готово
Может быть обновлено 4 пакета. Запустите «apt list --upgradable» для их показа.
12.02.2025 в 08:56, Igor сказал:
https://stpete-mirror.armbian.com/ (St. Petersburg) This mirror works well in the Russian Federation.
But how do I make sure that this mirror is automatically selected in the build system itself at the image creation stage?
I mean the phase of installing packages in a future image.
[🔨]   Err:5 http://mirror.hostiko.network/armbian bookworm InRelease
[🔨]   Err:5 http://fastmirror.pp.ua/armbian bookworm InRelease
  • Solution
  # Europe/Moscow - 2000 Mbit/s
  - server: stpete-mirror.armbian.com/beta/
    rules:
      - field: location.country.iso_code
        not_in:
          - UA
    latitude: 59.9417
    longitude: 30.3096
    weight: 10
  # Europe/Kiev - 1000 Mbit/s
  - server: fastmirror.pp.ua/armbian/
    rules:
        not_in:
          - RU
    latitude: 50.458
    longitude: 30.5303
    weight: 10
After this change, our redirector blocks access to Russian mirrors for users in Ukraine and vice versa. Hopefully, this feature will become obsolete soon.
Hi! Now https://github.armbian.com/configng not working from RU.
W: Не удалось получить https://github.armbian.com/configng/dists/stable/InRelease
Невозможно инициализировать соединение с github.armbian.com:443 (2606:50c0:8001::153). - connect (101: Сеть недоступна)
Невозможно инициализировать соединение с github.armbian.com:443 (2606:50c0:8000::153). - connect (101: Сеть недоступна)
Невозможно инициализировать соединение с github.armbian.com:443 (2606:50c0:8003::153). - connect (101: Сеть недоступна)
Невозможно инициализировать соединение с github.armbian.com:443 (2606:50c0:8002::153). - connect (101: Сеть недоступна)
Не удалось соединиться с github.armbian.com:443 (185.199.111.153): время ожидания для соединения истекло
Не удалось соединиться с github.armbian.com:443 (185.199.110.153): время ожидания для соединения истекло
Не удалось соединиться с github.armbian.com:443 (185.199.108.153): время ожидания для соединения истекло
Не удалось соединиться с github.armbian.com:443 (185.199.109.153): время ожидания для соединения истекло
Upgrade armbian-config is not possible. Is there any mirror of this repo?
Edited by Виктор Хомченко
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
