Efe Çetin
Administrators
  1. Do you see anything on UART log in case you connect OPi to PC with USB-TTL converter?
  2. Interesting, will try to reproduce it after getting DP-capable type-c cable, will let you know the results with different RK3588S boards.
  3. It is not early fix, but now it should work as expected on non-vendor kernels https://github.com/armbian/build/pull/10289 Also it works flawlessly on vendor kernel with previous overlay
  4. Will check it when i back to PC, will be away from pc for around a week
  5. Choose install/update bootloader on spi flash option on armbian-install. Some uart logs could be useful if you have usb-ttl converter stuff
  6. Could you try to write SPI image to spi flash manually? (not the sata one) Also, can you send the content of /boot/armbianEnv.txt which is located in the ssd.
  7. Can you send dmesg lsusb and lsmod outputs using paste.armbian.com
  8. The image from https://dl.armbian.com/orangepi5/Noble_vendor_gnome works well for me. It might be good to see some GDM logs as i am not sure where the problem arises from.
  9. @Egertcan you send inxi -G output
  10. What if you clear SPI Flash and then try to boot emmc?
  11. Yes it's not supported by mainline kernels yet. Perhaps it might be worth to try to backport wacom drivers to 6.1 kernel.
  12. It is fixed now. It should work if you update kernel from beta repo
  13. I will check it to find what's wrong. Unfortunately it might take some time since i don't have any 2k screen
  14. Which resolution are they working at? And does it work with Khadas images
