February 27, 20251 yr I have a NanoPi R2S Plus. If I boot the FriendlyElec Debian image both network ports work: LAN and WAN. If I boot the Armbian NanoPi R2S image, it boots OK and the LAN port works but the WAN port does not work. I believe the WAN port does not work because the NanoPi R2S has an RTL8211E chip but the NanoPi R2S Plus has an RTL8211F chip. I found some notes about problems with network on other boards that had the same change of chip (e.g. radxa RockpiE) and the device tree changes required to accommodate the new chip. So I tried to patch armbian/build to make the same changes for the NanoPi R2S Plus. I am not familiar with armbian/build or device trees. None the less, I seem to have made some progress. My latest image attempts to bring up the WAN port. It gets an IP address from dhcp server. But then it tries to get various files by TFTP and fails. It has no server IP and I have no TFTP server running. Part of the console logs: Quote scanning bus usb@ff5d0000 for devices... 1 USB Device(s) found scanning bus usb@ff580000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device Speed: 1000, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.1.156 (74 ms) *** ERROR: `serverip' not set Cannot autoload with TFTPGET missing environment variable: pxeuuid Retrieving file: pxelinux.cfg/01-72-bf-ff-86-49-5f Speed: 1000, full duplex *** ERROR: `serverip' not set Retrieving file: pxelinux.cfg/C0A8019C Speed: 1000, full duplex *** ERROR: `serverip' not set Retrieving file: pxelinux.cfg/C0A8019 ... Retrieving file: pxelinux.cfg/default Speed: 1000, full duplex *** ERROR: `serverip' not set Config file not found Speed: 1000, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.1.156 (71 ms) *** ERROR: `serverip' not set Cannot autoload with TFTPGET Speed: 1000, full duplex BOOTP broadcast 1 DHCP client bound to address 192.168.1.156 (73 ms) *** ERROR: `serverip' not set Cannot autoload with TFTPGET => Now I am lost. I don't understand why it is trying to load files by TFTPGET. Maybe I have something wrong in the device tree so it is loading an incorrect device driver. There is the line 'Device 0: unknown device'. The first file it attempts to retrieve appears to have the MAC address of the LAN port in the filename. It continues trying to load various files then fails and presents a prompt: '=> ' Can anyone give me pointers to where to look / what to read to understand what is going on? Is that a u-boot prompt? Any pointers would be much appreciated and, again, this is all new to me - I am blundering about in my ignorance.
February 27, 20251 yr Hi The logs you provided (besides that they're incomplete) are from u-boot and have nothing to do with OS level. it might be possible that u-boot supports the 2nd NIC but it is broken in kernel. Could be a device tree issue, could also be something else. I suggest to try the available kernel branches (legacy, current, edge) first to check if one of them works properly. You can use armbian-config to switch between kernels or swap sdcards with written Armbian images with various kernels beneath on. @jock has some insights in some older rockchips I think?
February 27, 20251 yr Author Thanks Werner. I have found some of the log message text in the u-boot source code. As you suggest, it seems to be stuck in u-boot and not getting to a Linux kernel at all. I'm guessing BOOTP is a fallback in case it can't find an image to load on any storage. 'scanning usb for storage devices... 0 Storage Device(s) found' doesn't look good. It should be booting from the SD card. It did, before I messed with the device tree. I think u-boot cannot find any image to load so it presents a prompt ('=> ') and waits for a command to tell it what to load. I will have to capture the whole log and see what other clues I can find. At the moment, I only have a bit of cut-and-paste of the end of it. I guess I broke the device tree so it can't find the image to load on the SD card. I really need to learn how to inspect the device tree generated by armbian/build when the system doesn't boot. I guess it's in the image somewhere. I'm hobbled by my ignorance but learn a little each day 😉
February 27, 20251 yr @Ian Goodacre yes I confirm you broke the dtb, and for that reason u-boot does not take the kernel from sdcard anymore, then tries other boot options (USB, PXE). You should recover the device tree to let linux boot again. Funnily enough, u-boot is able to pick up an IP address from DHCP 😅 This is the merge request where I fixed the Gigabit LAN port on RockPi-E, I understand that you already read about the merge request, perhaps the problem is similar to yours. BTW, the phy chip should be automatically recognized by the kernel code because each chip exposes some ID that can be picked up by the driver, so you should not worry about. If you still have issues, post the link returned by armbianmonitor -u or at least the dmesg log.
March 3, 20251 yr Author @jock, @Werner: thanks for the guidance. I have recovered my system and learned enough about the basic boot process that I can now get back to modifying the device tree to make the RTL8211F based network interface work. I think I now have a much more solid foundation and hope I can progress by little steps. I'll post again when I have it working.
March 3, 20251 yr Author I have initial success: I have modified dts for nanopi-r2s-plus and now have my device with both LAN and WAN ports working with 6.12 kernel. I wonder about naming conventions. Existing dts files for nanopi-r2* seem to follow the naming conventions used by FriendlyElec. For the nanopi-r2s-plus, FriendlyElec added rk3328-nanopi-r2-rev24.dts. I added rk3328-nanopi-r2s-plus.dts instead, starting with a copy of rk3328-nanopi-r2-rev00.dts (used for NanoPi R2S). The names used by FriendlyElec seem arbitrary to me but maybe there is some bigger pattern that I am not yet seeing. Also, mainline kernel has rk3328-nanopi-r2s-plus.dts, rk3328-nanopi-r2s.dts and rk3328-nanopi-r2c.dts. Armbian has rk3328-nanopi-r2-rev00.dts and rk3328-nanopi-r2-rev06.dts for the latter two. I wonder why Armbian is not using those in the kernel. Maybe for historical reasons? I had tried to use rk3328-nanopi-r2s-plus.dts initially but WAN port didn't work and when I tried to 'fix' it, I ended up with the configuration that didn't boot. Maybe I should revisit the mainline dts, now that I have one working. In the meantime, I think the patch I have added to Armbian overwrites rk3328-nanopi-r2s-plus.dts from the kernel, which isn't ideal. But I am reluctant to add yet another name just to avoid conflicts with the names used by mainline and FriendlyElec. The names in mainline make more sense to me. Is there any guidance anywhere about coordination between FriendlyElec, Armbian and mainline kernel, as far as the dts files are concerned?
March 3, 20251 yr The first thing that pops in my mind is that if the dtb for a board has been introduced with a naming convention (whatever it is), if you change the naming convention, it will mostly break the user installations when they upgrade the kernel/dtbs.
March 3, 20251 yr Author I haven't thought so far as kernel updates. That's another puzzle to ponder 😉
March 4, 20251 yr Author Solution I have created an Armbian board config: nanopi-r2s-plus.csc, and a patch to the in kernel device tree rk3328-nanopi-r2s-plus.dts, to fix the WAN port. This avoids name collisions with both FriendlyElec and Linux kernel. The new patch is rk3328-nanopi-r2s-plus-a1.dts and it includes rk3328-nanopi-r2s-plus.dts, provided by the kernel. Working for me with the 6.12 kernel. What are the prospects for getting this into armbian/build? Should I just submit a pull request?
March 13, 20251 yr Author For whoever might be interested in NanoPi R2S Plus: I have built an image for my NanoPi R2S Plus that has the WAN port and eMMC working, so I am able to install and boot from eMMC with system on a USB attached disk drive, and with LAN and WAN ports both working. I haven't tested whether the WAN port works from u-boot (e.g. for booting via BOOTP) - the dts/dtb used by u-boot is different from that in the kernel. To achieve this, I have a new board configuration that uses v2025.01 u-boot and a dts that includes the dts for NanoPi R2S Plus in the kernel, with modification to make the WAN port work (eMMC works with the kernel dts as-is). Otherwise, it is a copy of the board configuration for NanoPi R2S, with the name changed. This is all done via configuration in my userpatches of Armbian build framework. If you're interested, you can get the configuration from my userpatches git repository: https://github.com/ig3/armbian-userpatches I have submitted a pull request to have these changes added to the Armbian build framework but it is not yet accepted.
