Hero Intelligent
  1. This is the output of my board: DDR version 1.16 20190528 ID:0x805 N In DDR4 333MHz Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15 CS=1 Die Bus-Width=16 Size=1024MB ddrconfig:14 OUT Boot1 Release Time: May 13 2019 17:34:36, version: 2.50 ChipType = 0x11, 248 mmc2:cmd1,20 emmc reinit mmc2:cmd1,20 emmc reinit mmc2:cmd1,20 SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=15216MB FwPartOffset=2000 , 0 StorageInit ok = 24008 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x337a9f0 signature is wrong recovery gpt... GPT 0x337a9f0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xb3690 RunBL31 0x40000 01INFO: Preloader serial: 2 NOTICE: BL31: v1.3(debug):403e0b816 NOTICE: BL31: Built : 14:13:08, Aug 11 2020 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2022.07-armbian (Jan 13 2024 - 14:06:57 +0000) Model: FriendlyElec NanoPi R2S DRAM: 1022 MiB PMIC: RK8050 (on=0x40, off=0x01) Core: 231 devices, 23 uclasses, devicetree: separate MMC: mmc@ff500000: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: FriendlyElec NanoPi R2S Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3548 bytes read in 8 ms (432.6 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1:1 176 bytes read in 7 ms (24.4 KiB/s) 196677074 bytes read in 8585 ms (21.8 MiB/s) 35713536 bytes read in 1561 ms (21.8 MiB/s) 64562 bytes read in 16 ms (3.8 MiB/s) 2698 bytes read in 13 ms (202.1 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=44b0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 196677010 Bytes = 187.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... Bad Data CRC Ramdisk image is corrupt or invalid SCRIPT FAILED: continuing... 1b7 1b[r 1b[999;999H 1b[6n 1b8No EFI system partition BootOrder not defined EFI boot manager: Cannot load any image MMC Device 0 not found no mmc device at slot 0 starting USB... Bus usb@ff5c0000: ehci_generic usb@ff5c0000: Failed to get clocks (ret=-19) Port not available. Bus usb@ff5d0000: USB OHCI 1.0 Bus usb@ff580000: USB DWC2 scanning bus usb@ff5d0000 for devices... 1 USB Device(s) found scanning bus usb@ff580000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 missing environment variable: pxeuuid Retrieving file: pxelinux.cfg/01-22-19-a0-37-f6-ff ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/00000000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/0000000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/000000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/00000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/0000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/00 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/0 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/default-arm-rk3328-evb_rk3328 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/default-arm-rk3328 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/default-arm ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Retrieving file: pxelinux.cfg/default ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 Config file not found ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 ethernet@ff540000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Could not initialize PHY ethernet@ff540000 =>
  2. I first made a self-built image for nanopi-r2s and everything is fine. But another self-built image of Nanopi-R2S seems refuse to boot after enabling these configurations: `DEBUG_INFO_DWARF_TOOLCHAIN_DEFAULT`, then `DEBUG_INFO_BTF` and `MODULE_ALLOW_BTF_MISMATCH` But the LED on RJ45 blinks, and I can ping the IP that I get from my router DHCP, but SSH connection refused. So I guess it may have booted, but refuse SSH connection. I have no TTL serial connections yet, I'll check it and post the logs here some time later. Can anybody help? How can I enable ssh with? Is it possible to enable it at build stage? Thanks.
