Skip to content
View in the app
Armbian Community Forums
boot + system incl. OMV from eMMC - howto transfer existing system from ssd to eMMC incl. configuration?
Featured Replies
Actual booting from eMMC and system including OMV from Sata SSD. Running boot & system from eMMC should be possible now and I would like to transfer system from SSD to eMMC without losing my config and starting from scratch again. That way I'll have a sdd beside the hdd for OMV.
How can I manually transfer the system including OMV from SSD to eMMC and what configuration files need to be altered?
  • Author
Dear Werner,
I am booting without a sd-card and can use armbian-install with just an option transfering system from ssd to emmc and emmc won't be formatted?
Which option should I chose? boot frm emmc / system on emmc?
https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb
Armbian Installer support those storage scenarios:
boot from SD, system on SATA / USB
boot from eMMC / NAND, system on eMMC/NAND
boot from eMMC / NAND, system on SATA / USB / NVME
Boot from SPI - system on SATA, USB or NVMe
Install/Update the bootloader on SD/eMMC
Install/Update the bootloader on special eMMC partition
Install/Update the bootloader on SPI Flash
Install system to UEFI disk
thank you for clarification!
  • Author
I backuped the boot dir.
So I don't need booting from Sd-card, armbian-install will format emmc and copy from where the boot dir?
Afterward it moves the system to emmc.
If I am running armbian-config there's a message "Warning: The current OS (bookworm) is not supported or not listed"
it's the latest version
"Armbian 21.02.1 stable 6.12.32-current-rockchip64 (Debian bookworm)"
apt-get install armbian-config
armbian-config is already the newest version (25.8.0-trunk.330.0708.120916)
I can't see any option to install/update system
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
