September 10, 20251 yr For this board https://www.olimex.com/Products/SOM/NXP-iMX8/iMX8MP-SOM-4GB-IND/open-source-hardware It looks like Olimex have forked Armbian-build and done the board bringup: https://github.com/OLIMEX/imx8mp-build/commit/a3cb5ad2710cd3edf6a4c6c067b049af48b03fa5#diff-1b53368896f4902ddbb5db1fa206835ccbb04445cd8bcaa5fef353655794665a How could I bring that code back into the main https://github.com/armbian/build/tree/main I think I need to rebase the Olimex fork back to the main Armbian Repo? Or should I fork the Armbian repo and then re-apply the Olimex changes to the fork?
September 10, 20251 yr 1 hour ago, Sam Rossiter said: I think I need to rebase the Olimex fork back to the main Armbian Repo? Recommended. It looks like its not that far away. 1 hour ago, Sam Rossiter said: Or should I fork the Armbian repo and then re-apply the Olimex changes to the fork? With rebase you will see the diff and if this is all you need to apply.
September 10, 20251 yr Author I looked at this for an hour and unfortunately can't figure it out. It seems that Olimex didn't 'fork' from Armbian, instead did something else to make their clone of your code. Edited September 10, 20251 yr by Sam Rossiter typo
September 17, 20251 yr They certainly did fork armbian, apparently at tag v24.11.1 AKA dd379da888f7d114f9f954d94a7ebcf261d179e5 $ git merge-base dd379da888f7d114f9f954d94a7ebcf261d179e5 main 017549347bb8c278a067d1be14c2f1b3538690c2 Add the Olimex repo as a remote and then rebase the latest armbian/build HEAD to their HEAD.
September 17, 20251 yr Something like git clone https://github.com/armbian/build.git -b main cd build git remote add -f imx8mp-build https://github.com/OLIMEX/imx8mp-build.git git remote update git fetch origin git fetch imx8mp-build git checkout main git rebase imx8mp-build/bookworm # fix conflict vi VERSION git add VERSION git rebase --continue # fix conflict vi .github/dependabot.yml git add .github/dependabot.yml git rebase --continue git log
March 19Mar 19 hi all. any hints to merge olimex imx8 board and compile armbian kernel 6.x and deb12 ?
March 20Mar 20 22 hours ago, vk vk said: any hints https://docs.armbian.com/Process_Contribute/#adding-a-new-board
