October 6, 20251 yr at the first launch, I ran into the problem that the board cannot connect to the lan Internet via cable, it writes permanent connection and disconnection in the admin console. therefore, I cannot find out the ip address and understand what to connect to. Please help me if someone knows or has solved this problem.
October 7, 20251 yr 6 hours ago, Mikhail M said: it writes permanent connection and disconnection in the admin console Armbian does not come with some sort of admin console. Please elaborate. Try different patch cable. moved
October 7, 20251 yr Author I use ubunta jammy 1.0.8 for desktop, a 32 GB sd drive, and I was able to achieve a new result: the image was recorded (there were problems with the sd card) and now I just have a red light on all the time, and the operating system does not boot, so the image is not displayed on the monitor, no
October 8, 20251 yr 4 hours ago, Mikhail M said: jammy 1.0.8 Not an Armbian image. If you want to use this one, try to get support from where you got the image from.
