Skip to content
View in the app
Armbian Community Forums
KickPi K2B not booting up: DRAM setup not supported
Featured Replies
I am using this version "Armbian_community_25.11.0-trunk.334_Kickpik2b_trixie_current_6.12.47_minimal.img".
It shows
U-Boot SPL 2025.07 (Oct 20 2025 - 18:19:29 +0800)
DRAM:This DRAM setup is currently not supported.
resetting ...
resetting ...
resetting ...
resetting ...
The system just loops this message and never proceeds.
Has anyone encountered this issue before? Any suggestions or solutions would be greatly appreciated.
Thanks in advance!
Solved by c0rnelius
@chuanzz
345032 -rw-rw-r--  1 patrick patrick 353310884 Oct 23 11:00 Armbian_community_25.11.0-trunk.334_Kickpik2b_trixie_current_6.12.47_minimal.img.xz
U-Boot SPL 2025.07 (Sep 24 2025 - 18:40:04 -0400)
DRAM: 2048 MiB
Trying to boot from MMC2
NOTICE:  BL31: v2.12.5(debug):lts-v2.12.5
NOTICE:  BL31: Built : 11:56:13, Sep 10 2025
NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
NOTICE:  BL31: Found U-Boot DTB at 0x4a0cd800, model: KickPi K2B
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    Probing for PMIC on I2C:
INFO:    PMIC: found AXP313
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for erratum 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for erratum 1530924 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
INFO:    Changed devicetree.
U-Boot SPL 2025.07-armbian-2025.07-Se37d-Pe61e-H8869-Vbdbf-Bb703-R448a (Oct 16 2025 - 02:34:23 +0000)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.12.5(debug):armbian
NOTICE:  BL31: Built : 03:03:57, Oct  1 2025
NOTICE:  BL31: Found U-Boot DTB at 0x4a0b7550, model: KickPi K2B
INFO:    SPSR = 0x3c9
ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2025.07-armbian-2025.07-Se37d-Pe61e-H8869-Vbdbf-Bb703-R448a (Oct 16 2025 - 02:34:23 +0000) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: KickPi K2B
DRAM:  2 GiB
Core:  74 devices, 23 uclasses, devicetree: separate
WDT:   Not starting watchdog@30090a0
MMC:   mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Allwinner mUSB OTG (Peripheral)
Net:   eth0: ethernet@5020000using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC de:ad:be:ef:00:01
HOST MAC de:ad:be:ef:00:00
RNDIS ready
, eth1: usb_ether
starting USB...
sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Bus usb@5101000: 1 USB Device(s) found
Bus usb@5101400: 1 USB Device(s) found
Bus usb@5200000: 1 USB Device(s) found
Bus usb@5200400: 1 USB Device(s) found
Bus usb@5310000: 1 USB Device(s) found
Bus usb@5310400: 1 USB Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
4641 bytes read in 2 ms (2.2 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
191 bytes read in 1 ms (186.5 KiB/s)
Load fdt: /boot/dtb/allwinner/sun50i-h618-kickpi-k2b.dtb
43768 bytes read in 5 ms (8.3 MiB/s)
Working FDT set to 4fa00000
4203 bytes read in 4 ms (1 MiB/s)
Applying kernel provided DT fixup script (sun50i-h616-fixup.scr)
## Executing script at 45000000
17093884 bytes read in 707 ms (23.1 MiB/s)
37613576 bytes read in 1554 ms (23.1 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x426d0000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    17093820 Bytes = 16.3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 48fb2000, end 49fff4bc ... OK
   Loading Device Tree to 0000000048f3e000, end 0000000048fb1fff ... OK
Working FDT set to 48f3e000
Starting kernel ...
Does the PSU have enough juice and is the SD card one of quality?
  • Author
I dont think so.
I can boot the official system “kickpi-k2b-ubuntu-jammy-desktop-xfce-linux-5.4.125-20250901.img” using this SD card
  • Author
1 hour ago, c0rnelius said:
My only other suggestion would be; dd off the u-boot and OS from the eMMC and see if that helps.
I dd the armbian.img > emmc. and remove my sd card
still the same output
If it isn't the PSU or SD than I'm not sure.
The only REV available in the STATES "which is where I am" is the 2GB. The u-boot patch set is identical to the BPI-M4-Zero "minus the dts and defconfig of course". All my testing has been done with the unit I have available to me. It works with the Armbian, KIckpi and my own personal builds.
As an aside the Kickpi web site is down for me STATE side. Not sure what that means? Doesn't look good though.
Anyway, I'm out of ideas. Sorry.
  • Author
From what I’ve found, the K2B has three revisions; mine is REV 2.2 (it’s printed right on the PCB).
Looks like they swapped the RAM from DDR4L to DDR3—mine has DDR3 chips on board—so that might be why it’s acting up.
Kickpi’s site barely loads from China; I really dislike that company, the documentation is almost non-existent.
I found some here: https://github.com/tan-zhihao1/kickpi-book/tree/master/h618/en
Still, I want to crack the problem. With the current sale the 2 GB + 0 GB version is only 78 CNY (about 11 USD), which is hard to pass up.
Thanks for getting back to me.
K2B.zip
  • Author
U-Boot SPL 2025.07 (Oct 24 2025 - 06:19:19 -0400)
DRAM: 2048 MiB
NOTICE:  BL31: Built : 06:13:32, Oct 24 2025
INFO:    SPSR = 0x3c9
U-Boot 2025.07 (Oct 24 2025 - 06:19:19 -0400) Allwinner Technology
Model: KickPi K2B
DRAM:  2 GiB
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
RNDIS ready
, eth1: usb_ether
starting USB...
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
USB EHCI 1.00
USB OHCI 1.0
Bus usb@5310400: 2 USB Device(s) found
Scanning mmc 0:1...
4641 bytes read in 1 ms (4.4 MiB/s)
181 bytes read in 1 ms (176.8 KiB/s)
Load fdt: /boot/dtb/allwinner/sun50iw9-kickpi-k2b.dtb
67673 bytes read in 5 ms (12.9 MiB/s)
Failed to load '/boot/dtb/allwinner/overlay/h618-fixup.scr'
17096334 bytes read in 704 ms (23.2 MiB/s)
37613576 bytes read in 1549 ms (23.2 MiB/s)
   Image Name:   uInitrd
   Data Size:    17096270 Bytes = 16.3 MiB
   Loading Ramdisk to 48fb2000, end 49fffe4e ... OK
   Loading Device Tree to 0000000048f39000, end 0000000048fb1fff ... OK
Working FDT set to 48f39000
No RNG device
Starting kernel ...
and stuck here.
It makes differences!!
Another problem here is that they don't have a schematic available for the rev2. They may have changed more than the DRAM? So the first u-boot I posted could have been fine, but the kernel DTS may need adjusting.
Oh NVM. You did post the schematic :)
EDIT: Not helpful. Its the same schematic I already have, which was incorrect as the variant I purchased is using DDR4. Not sure whats up with this company but they aren't very good at providing proper sources or essential unit information.
  • Author
50 minutes ago, c0rnelius said:
Try this one
This one failed with "DRAM:This DRAM setup is currently not supported"
I found something from kickpi's site:Linux_SDK_Compilation. including building u-boot
https://github.com/tan-zhihao1/kickpi-book/blob/master/h618/en/04-SDK_Compilation_Guide/02-Linux_SDK_Compilation.md
Its too huge so I deleted the folder "source" and "toolchains".
hope it could help
I tried to upload here but it shows errors.
try this url: https://we.tl/t-t92S5rlCzD
  • Author
I build a u-boot with it
39 minutes ago, chuanzz said:
dd latest armbian.img and this u-boot,
it showed:
▒[40]HELLO! BOOT0 is starting!r = 0x1d3
[43]BOOT0 commit : 4b34f2890a
[46]set pll start
[48]periph0 has been enabled
[51]set pll end
[54]unknow PMU
[56]unknow PMU
[59]PMU: AXP1530
[64]vaild para:15  select dram para1
[68]board init ok
[69]enable_jtag
[71]DRAM BOOT DRIVE INFO: V0.651
[74]the chip id is 0x2000
[77]chip id check OK
[80]DRAM_VCC set to 1500 mv
[86]read_calibration error
[92]read_calibration error
[98]read_calibration error
[104]read_calibration error
[110]read_calibration error
[116]read_calibration error
[122]read_calibration error
[128]read_calibration error
[135]read_calibration error
[141]read_calibration error
[143]retraining final error
[152][AUTO DEBUG]32bit,1 ranks training success!
[164]DRAM CLK =648 MHZ
[166]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[174]Actual DRAM SIZE =2048 M
[177]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, dram_tpr13 = 6041
[190]DRAM simple test OK.
[193]rtc standby flag is 0x0, super standby flag is 0x0
[198]dram size =2048
[201]Use rtc to store dram tuning para
[205]card no is 0
[207]sdcard 0 line count 4
[209][mmc]: mmc driver ver 2021-10-12 13:56
[214][mmc]: b mmc 0 bias 4
[222][mmc]: Wrong media type 0x0
[225][mmc]: ***Try SD card 0***
[240][mmc]: HSSDR52/SDR25 4 bit
[243][mmc]: 50000000 Hz
[245][mmc]: 119850 MB
[247][mmc]: ***SD/MMC 0 init OK!!!***
[319]Loading boot-pkg Succeed(index=0).
[323][mmc]: b mmc 0 bias 4
[325]Entry_name        = u-boot
[332]Entry_name        = monitor
[336]Entry_name        = dtbo
[339]Entry_name        = optee
[343]Entry_name        = dtb
[346]mmc not para
[347]Jump to second Boot.
NOTICE:  BL3-1: v1.0(debug):54937d5
NOTICE:  BL3-1: Built : 17:44:59, 2021-12-13
NOTICE:  BL3-1 commit: 8
NOTICE:  cpuidle init version V2.0
NOTICE:  secure os exist
MESSAGE: [0x0] TEE-CORE: OP-TEE version: 81ab7a47 #1 2020年 05月 06日 星期三 02:40:04 UTC arm
NOTICE:  BL3-1: Preparing for EL3 exit to normal world
NOTICE:  BL3-1: Next image address = 0x4a000000
NOTICE:  BL3-1: Next image spsr = 0x1d3
and I found this: [177]DRAM SIZE =2048 MBytes, para1 = 310a, para2 = 8000000, dram_tpr13 = 6041
is this para what we need?
  • Author
I used ur project
https://github.com/pyavitz/debian-image-builder
changed this file "patches\uboot\v2025.07\sun50i-h618\002-Add-board-KickPi-K2B.patch"
+CONFIG_OF_UPSTREAM=y
+CONFIG_ARM=y
+CONFIG_ARCH_SUNXI=y
+CONFIG_DEFAULT_DEVICE_TREE="allwinner/sun50i-h618-kickpi-k2b"
+CONFIG_SPL=y
+CONFIG_DRAM_SUNXI_DX_ODT=0x03030303
+CONFIG_DRAM_SUNXI_DX_DRI=0x0e0e0e0e
+CONFIG_DRAM_SUNXI_CA_DRI=0x1f12
+CONFIG_DRAM_SUNXI_ODT_EN=0x0
+CONFIG_DRAM_SUNXI_TPR0=0xc0001002
+CONFIG_DRAM_SUNXI_TPR1=0x30fb
+CONFIG_DRAM_SUNXI_TPR2=0x0000
+CONFIG_DRAM_SUNXI_TPR6=0x33808080
+CONFIG_DRAM_SUNXI_TPR10=0x2f1107
+CONFIG_DRAM_SUNXI_TPR11=0xddddcccc
+CONFIG_DRAM_SUNXI_TPR12=0xeddc7665
+CONFIG_DRAM_SUNXI_TPR13=0x40
+CONFIG_MACH_SUN50I_H616=y
+CONFIG_SUNXI_DRAM_H616_DDR3_1333=y
+CONFIG_DRAM_CLK=648
+CONFIG_MMC_SUNXI_SLOT_EXTRA=2
+CONFIG_R_I2C_ENABLE=y
+# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
+CONFIG_SPL_I2C=y
+CONFIG_SPL_SYS_I2C_LEGACY=y
+CONFIG_SYS_I2C_MVTWSI=y
+CONFIG_SYS_I2C_SLAVE=0x7f
+CONFIG_SYS_I2C_SPEED=400000
+CONFIG_SUN8I_EMAC=y
+CONFIG_SUPPORT_EMMC_BOOT=y
+CONFIG_PHY_REALTEK=y
+CONFIG_RTL8211F_PHY_FORCE_EEE_RXC_ON=y
+CONFIG_RGMII=y
+CONFIG_RMII=y
+CONFIG_AXP313_POWER=y
+CONFIG_USB_EHCI_HCD=y
+CONFIG_USB_OHCI_HCD=y
+CONFIG_USB_MUSB_GADGET=y
and maked a u-boot
the debian was starting
I was testing it
I was just about to post a binary with something similar. So does the above work for you?
I was gonna try this:
CONFIG_DRAM_CLK=648
  • Author
The parameters I’m using were extracted from the official Linux SDK using GPT.
At least the DRAM parameters are functional.
Debian can boot and log in normally, but there’s no wired network or WiFi/Bluetooth.
I’m currently investigating why this is happening.
  • Author
Still no network.
I checked the official SDK, it uses the following hardware:
Wired network: Allwinner GMAC driver + external PHY;
Wireless network: AIC8800 series WiFi module driver;
Bluetooth: AIC8800 Bluetooth Low Energy driver;
USB network: RTL8152 USB to Ethernet driver.
Does this have any impact?
  • Solution
Looks like the same thing REV 1.1 uses. My guess would be the GPIO or PINCTRL may be different on the REV2.
The problem is the schematic only shows 1.0 / 1.1
You could try shooting them an email in an attempt to obtain the v2 schematic?
Without it, you would just be guessing.
  • Author
I’ve spent way too much time on this, my back is killing me.
I’d rather just buy a more common development board.
My project didn’t require me to dig into all this u-boot and DTS stuff.
So, fuck you KickPi.
Here are all the DTS files I extracted from https://github.com/pyavitz/debian-image-builder and the official Linux SDK.
Hopefully someone else can finish this job.
dts.zip
  • Author
I’ve sent the URL and details here, hoping they can take a look
  • Author
The official sent me the Armbian SDK, which includes kickpi-k2b-v2 and v1.
I tested it and it can boot normally.
Wired/wireless networks and Bluetooth all work fine, but the OTG function just won’t work no matter what I try.
(g_ether and g_serial not woring)
Anyway, I hope it can be merged into Armbian.
I only compressed the config and patch folders, which should be sufficient.
https://we.tl/t-wtmI81zB5e
Edited by chuanzz
HI.
I had same issue.
For all others that might hit same issue bellow are instructions:
1. Supply yourself with known good SD card.
2. Go to KickPi website, download an image supplied by them and write it to the card using dd or balena-etcher.
2.1 Make sure that you are able to boot the image from above.
3. If you are under widows it is good to have a Virtual Machine (I have Debian 13 running inside virtual box). If you are a Linux user, just skip this step
4. Clone Armbian build project
git clone  https://github.com/armbian/build
4.1. Build an image:
cd build
./compile.sh build BOARD=kickpik2b BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=yes KERNEL_CONFIGURE=yes RELEASE=trixie
4.2. Write the image to SD card from above.
sudo dd if=output/images/Armbian-unofficial_25.11.0-trunk_Kickpik2b_trixie_current_6.12.58_minimal.img of=/dev/mmcblk0 bs=1M status=progress
5. Clone Debian Image builder
git clone https://github.com/pyavitz/debian-image-builder
cd debian-image-builder
5.1 Follow the instructions from Readme.md:
./install.sh
make menu
5.2 In the menu adjust uboot version to 2025.7
5.2 Build the uboot
make uboot board=kickpik2b-v2
6. Write Uboot to your sdcard
sudo dd if=output/kickpik2b-v2/u-boot-sunxi-with-spl.bin of=/dev/mmcblk0 conv=fsync bs=1024 seek=8
7. Congratulations: Now you would have working board, but now WiFi or Ethernet.
Edited by Nasko
The v2 uses a diff wifi chip: SKW wifi module VS6621S
I have a patch for it, which came from KICKPI in the deb builder, but... I don't have a V2 to work any magic on it.
chuanzz at one point contacted KICKPI and they sent him an archive that had a bunch of Armbian adds in it, including the patches and board.confs. But the HDD I had the archive on got erased by mistake, so yeah... I don't have the info anymore.
I don't see the K2B REV2 getting official support here or by me, as its using a wifi chip that is just to obscure.
Here is a u-boot-v2025.07 binary for the K2B REV2
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
