Skip to content
View in the app
Armbian Community Forums
Build failed: "chroot: failed to run command ‘/bin/bash’: No such file or directory"
Featured Replies
I'm trying to build the Armbian for Rock64.
Host machine is Ubuntu 24.04 AMD64 (but it is running in VirtualBox under Windows).
Build fails with the following error:
[🐳|🌱] Deploying qemu-user-static binary to chroot [ qemu-aarch64-static during image-early ]
[🐳|🔨]   '/usr/bin/qemu-aarch64-static' -> '/armbian/.tmp/rootfs-232e77ba-e6ab-4067-8029-afd44bd1d0b9//usr/bin/qemu-aarch64-static'
[🐳|💥] Error 127 occurred in main shell [ at /armbian/lib/functions/rootfs/distro-specific.sh:276
   create_sources_list_and_deploy_repo_key() --> lib/functions/rootfs/distro-specific.sh:276
        extract_rootfs_artifact() --> lib/functions/rootfs/create-cache.sh:130
                do_with_logging() --> lib/functions/logging/section-logging.sh:81
   get_or_create_rootfs_cache_chroot_sdcard() --> lib/functions/rootfs/create-cache.sh:90
         build_rootfs_and_image() --> lib/functions/main/rootfs-image.sh:14
   full_build_packages_rootfs_and_image() --> lib/functions/main/default-build.sh:36
          do_with_default_build() --> lib/functions/main/default-build.sh:42
         cli_standard_build_run() --> lib/functions/cli/cli-build.sh:25
        armbian_cli_run_command() --> lib/functions/cli/utils-cli.sh:136
                 cli_entrypoint() --> lib/functions/cli/entrypoint.sh:208
                           main() --> compile.sh:50
The /bin/bash (/armbian/.tmp/rootfs-232e77ba-e6ab-4067-8029-afd44bd1d0b9/bin/bash) seems an ARM64 and this might be the reason for "failed to run".
Is this a known issue? Can I fix it?
I've tried to avoid using chroot in this line, the build goes forward but fails with similar error later.
Solved by Werner
I ran into what appears to be the same issue (see my log). I have added the suggested qemu-user-static package, which forced removal of another qemu- family package I had previously installed to work around problems with binfmt. Not only did it compile correctly, it also ran so much faster, as you can see in the number of log lines for this build! Thank you for the assistance and getting me on the right track with the right package selection!
Best Regards,
Lobosito
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
