Skip to content
View in the app
Armbian Community Forums
ask for TCP BBR module to be added in kernel
Featured Replies
  • Author
I found that I need to compile kernel with TCP BBR as build-in or module that takes a lot to do. Can this to be added in next kernel build?  Cheers!
This is a community project and you can and should add it on your own. It is prepared to be simple:
https://docs.armbian.com/Process_Contribute/#collaborate-on-the-project
Edit this line: https://github.com/armbian/build/blob/master/config/kernel/linux-rockchip-next.config#L788
Wait up to a day for kernel automated build at beta.armbian.com repository.
  • Author
Thank you  @Igor! I've just added a pull request in the project but not sure if the procedure is correct or not.
I've request to change CONFIG_TCP_CONG_BBR=y  in linux-rockchip-next.config.
Correct me if I'm wrong!
On the other side, I do make a  try to install Ubuntu and compile the kernel later.
  • Author
Thank you @Igor, you're the man. I finally complied the whole OS image myself with TCP BBR enable and it's working now!
  • Author
@Igor Hi! To keep BBR enable,I know it still not build-it for the next release. Can I just build my own kernel and update it when there's a new release?
After compile new kernel and there will be several debs , is the command with 'dpkg -i linux-image*.deb' and 'reboot' will update kernel? Thank you!
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
