Skip to content
View in the app
Armbian Community Forums
NanoPi R76S: U-Boot 2026.04 warm-reboot mmc failure — OpenWrt PR #23520 workaround does not work on Armbian vendor kernel
Featured Replies
Hi @Kwiboo and Armbian rk35xx maintainers,
I'm hitting a boot-time eMMC reliability issue on NanoPi R76S with the current
Armbian U-Boot 2026.04 build, and the community-known workaround from OpenWrt
PR #23520 breaks kernel boot completely in our Armbian environment. Sharing
detailed reproduction and requesting guidance.
## Setup
- Board: NanoPi R76S (RK3576), 4GB LPDDR5, 64GB Hynix eMMC (hC8aP, manfid 0x000090)
- Armbian build: derived from 26.5.1, `linux-u-boot-nanopi-r76s-vendor 26.5.1`
- U-Boot: 2026.04_armbian-2026.04-S88dc-P3cfe-H30d2-V3c1d-Bd0d2-R448a
- Kernel: 6.1.115-vendor-rk35xx (Armbian rk35xx vendor kernel)
- BL31: v2.3 fwver v1.20
## Baseline Symptom (Reproducible ~50%)
`sudo reboot` from Linux → SPL/BL31/U-Boot proper OK → boot.scr loads (255 B) →
first `ext4load` of kernel Image fails with `fs_devread read error - block`.
Second `ext4load` also fails, block layer reports `No partition table - mmc 0`.
Reproduction across both warm reboot and cold power cycle. Matches OpenWrt
issue #23491 exactly.
Interestingly `mmc rescan` in U-Boot prompt re-reads mmc info (58.2 GiB Hynix
detected, partition table intact) but subsequent `boot` command still fails —
suggesting U-Boot driver leaves stale state that even a manual rescan cannot
clear.
## Attempted Workarounds (All Failed in Our Environment)
### v1: 26 MHz variant (aggressive)
- U-Boot embedded DT `mmc@2a330000`: dropped `cap-mmc-highspeed`,
  `mmc-hs400-1_8v`, `mmc-hs400-enhanced-strobe`; set `max-frequency=<26000000>`
- Kernel DT overlay (same node): same property removal + 26 MHz
- Result: `Starting kernel ...` reached, then **immediate hang, no dmesg**.
### v2: OpenWrt PR #23520 exact patch (52 MHz, U-Boot only)
- U-Boot DT: kept `cap-mmc-highspeed`, removed only `mmc-hs400-1_8v` and
  `mmc-hs400-enhanced-strobe`; set `max-frequency=<52000000>` (52 MHz HS)
- Kernel DT: untouched (HS400ES)
- Result: U-Boot loads kernel at 44.5 MiB/s (HS speed confirmed), reaches
  `Starting kernel ...`, then **hang, no dmesg**.
### v3: Symmetric 52 MHz on both U-Boot and kernel DT
- U-Boot DT: same as v2
- Kernel DT overlay: removed HS400 properties + 52 MHz cap
- Result: identical hang after `Starting kernel ...`.
Observation: **any modification to U-Boot's embedded DT for mmc@2a330000
appears to make the Armbian vendor kernel silently fail before earlycon
initialization.** The stock Armbian U-Boot + stock kernel DT combination boots
kernel reliably (log flushes normally), but exhibits the ~50% warm-reboot bug.
Rolling back U-Boot to the original (via slot B rootfs `u-boot.itb`) restores
kernel boot immediately.
## Questions
1. Has anyone successfully applied OpenWrt PR #23520's workaround (or any
   variant) to Armbian's vendor kernel on RK3576? If so, what was the specific
   property combination?
2. Is this a known incompatibility between the mainline U-Boot mmc probe path
   and the Armbian rk35xx vendor kernel's dw_mshc driver? The Rockchip PSCI
   handoff seems to fail silently before console_init.
3. Would upgrading to U-Boot 2026.07 (just released) help? My search showed
   zero mmc/sdhci commits in v2026.04..v2026.07 range for rockchip. Am I
   missing a Karlman patch series that isn't yet in Armbian's fork?
4. Any suggested next step: (a) chase FriendlyElec BSP U-Boot behavior, (b)
   patch the vendor kernel's dw_mshc probe to handle inherited controller
   state, or (c) accept as known-limitation until Armbian moves to kernel 6.6+?
5. If (b), which specific probe/reset path in
   `drivers/mmc/host/dw_mmc-rockchip.c` or `sdhci-of-dwcmshc.c` should we
   audit? Any references to similar rk3588 handoff issues that were resolved?
Full boot logs (successful, failed variants v1/v2/v3, rollback recovery)
available on request. Willing to test patches against test board and report
back with UART logs.
Thanks for maintaining rockchip U-Boot,
Peter Rim
Related:
- https://github.com/openwrt/openwrt/issues/23491
- https://github.com/openwrt/openwrt/pull/23520
- https://github.com/armbian/build/pull/9869 (R76S migration to v2026.04)
rk3576-mmc-bug-attachments.tar.gz
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
