Skip to content
View in the app
Armbian Community Forums
Wi-Fi chip information and WPA3 compatibility
Featured Replies
In this topic I'll share information from Wi-Fi modules found in SBCs, and their compatibility with WPA3 standard.
WPA3-Personal Only (not Transitional or Compatible)
Wi-Fi 5 (ac), 6 (ax), 7 (be) on 2.4 and 5 GHz:
  • Authentication and Key Management (AKM): WPA3-SAE with SHA256 (AKM:8, AKM:9 FT), optionally WPA3-SAE with a variable hash algorithm depending on Diffie-Hellman (DH) group SHA-256, SHA-384, or SHA-512 (AKM:24, AKM:25 FT)
  • Key derivation methods: Hunting and Pecking (HnP) or Hash-to-Element (H2E)
  • Pairwise cipher (PTK): CCMP-128, optionally GCMP-256, others possible but not TKIP
  • Group data cipher (GTK): CCMP-128, optionally GCMP-256, others possible but not TKIP
  • Group management cipher (IGTK): BIP-CMAC-128, optionally BIP-GMAC-256
  • Protected Management Frames (PMF/802.11w): required
Wi-Fi 6 ax @ 6 GHz / Wi-Fi 7 be @ 6 GHz OR with Multi-Link Operation (MLO):
  • Authentication and Key Management (AKM): WPA3-SAE with a variable hash algorithm depending on Diffie-Hellman (DH) group SHA-256, SHA-384, or SHA-512 (AKM:24, AKM:25 FT)
  • Key derivation methods: Hash-to-Element (H2E)
  • Pairwise cipher (PTK): GCMP-256 required, CCMP-128 optional, others possible but not TKIP
  • Group data cipher (GTK): GCMP-256 required, CCMP-128 optional, others possible but not TKIP
  • Group management cipher (IGTK): the same as non-6GHz (??) BIP-CMAC-128, optionally BIP-GMAC-256
WPA3-Enterprise Only (not Transitional or Compatible)
Same as for Personal, but:
  • Authentication and Key Management (AKM): At least WPA3 AKM:5 (IEEE 802.1X with SHA-256)
  • Group management cipher (IGTK): BIP-CMAC-128, optionally BIP-GMAC-256, additional optional BIP-CMAC-256 and BIP-GMAC-128
Same additional Key Deviation and GCMP constrains as for Personal.
WPA3-Enterprise 192-bit mode
Same as for Personal + Enterprise, but:
  • Authentication and Key Management (AKM): only WPA3 AKM:12 (Suite B 192b, IEEE 802.1X with SHA-384). WPA-EAP-SUITE-B-192 in key_mgmt output.
  • Pairwise cipher (PTK): GCMP-256 only
  • Group data cipher (GTK): GCMP-256 mandatory, others optional
  • Group management cipher (IGTK): BIP-GMAC-256 mandatory, others optional
Source: https://www.wi-fi.org/system/files/WPA3 Specification v3.5.pdf
Edited by ValdikSS
  • Author
My tests:
1. Get information of the adapter capabilities with:
iw phy
2. Get pairwise/group ciphers, supported key management and authentication algorithms with:
for i in eap pairwise group key_mgmt proto auth_alg channels freq modes; do
  CAPABILITY="$(wpa_cli get_capability $i | grep -v 'Selected interface')"
  echo "get_capability $i:"
  echo "$CAPABILITY"
  echo
done
3. Connect to WPA3-Personal Only network and check the information about connected client on the router.
Caveats you should be aware of
wpa_supplicant creates key_mgmt from the chip's cipher list if the chip does not return key_mgmt. It's filled from the presets and miss for example WPA-EAP-SHA256 needed for WPA3-Enterprise. Most probably it will work even if it's not listed.
To detect whether key_mgmt you see is from chip or filled from the template, run
wpa_supplicant ... -d | grep 'supported key_mgmt'
If you don't see this string in the output, this means the key_mgmt is filled from the template.
Edited by ValdikSS
  • Author
Radxa Zero 3w.
AIC8800D80 — 2.4 + 5 GHz 802.11b/g/n/ac/ax 80 MHz 1x1 + BT5.3.
Datasheet.
✔️ Works in WPA3-Personal Only: WPA3-SAE + CCMP-128 for pairwise/group ciphers.
✔️ Should work in WPA3-Enterprise Only: will connect if the AP supports CCMP-128 for pairwise/group ciphers.
❌ Does not work for WPA3-Enterprise 192-bit mode (no support for GCMP-256, no support for WPA-EAP-SUITE-B-192 key_mgmt).
Tested on Armbian 26.8.1 (Armbian_26.8.1_Radxa-zero3_trixie_vendor_6.1.115_minimal.img.xz).
More information in the attachment.
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 3
        max scan IEs length: 200 bytes
        max # sched scan SSIDs: 0
        max # match sets: 0
        Retry short limit: 7
        Retry long limit: 4
        Coverage class: 0 (up to 0m)
        Device supports RSN-IBSS.
        Device supports AP-side u-APSD.
        Supported Ciphers:
                * WEP40 (00-0f-ac:1)
                * WEP104 (00-0f-ac:5)
                * TKIP (00-0f-ac:2)
                * CCMP-128 (00-0f-ac:4)
                * CMAC (00-0f-ac:6)
                * WPI-SMS4 (00-14-72:1)
        Available Antennas: TX 0 RX 0
        Supported interface modes:
                 * managed
                 * AP
                 * AP/VLAN
                 * monitor
                 * mesh point
                 * P2P-client
                 * P2P-GO
                 * P2P-device
get_capability eap:
MD5 TLS WFA-UNAUTH-TLS MSCHAPV2 PEAP TTLS GTC OTP SIM LEAP PSK AKA AKA' FAST PAX SAKE GPSK WSC IKEV2 TNC PWD EKE
get_capability pairwise:
CCMP TKIP
get_capability group:
CCMP TKIP WEP104 WEP40
get_capability key_mgmt:
NONE IEEE8021X WPA-EAP WPA-PSK WPA-EAP-SUITE-B OWE DPP FT-PSK FT-EAP
get_capability proto:
RSN WPA
get_capability auth_alg:
OPEN SHARED LEAP SAE
get_capability channels:
Mode[G] Channels: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Mode[A] Channels: 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 144 149 153 157 161 165
Mode[B] Channels: 1 2 3 4 5 6 7 8 9 10 11 12 13 14
get_capability modes:
AP MESH
Router data, 802.11k/v and PMF supported, WPA3-SAE connection.
          station:
                  mac: xx:xx:xx:xx:xx:xx
                   ap: WifiMaster0/AccessPoint0
                  psm: no
        authenticated: yes
               txrate: 65
               rxrate: 65
               uptime: 410
              txbytes: 18787
              rxbytes: 27140
                   ht: 20
                 mode: 11n
                   gi: 800
                 rssi: -57
                  mcs: 7
                 txss: 1
                  _11: k
                  _11: v
                  pmf: yes
             security: wpa3-psk
radxa-zero-3w-AIC8800D80.zip
Edited by ValdikSS
  • Author
Orange Pi 3G-IoT-A.
MT6620 (?) Wi-FI inside Mediatek MT6572 smartphone chip.
❌ Does not work in WPA3-Personal Only: no WPA3-SAE support
❌ Does not work for WPA3-Enterprise 192-bit mode: no PMF no GCMP support
I've applied this patch to kernel 3.4 to enable PMF, IEEE 802.1X with SHA-256 support was already in the driver.
This confirms that WPA3-Enterprise is possible even on ancient kernels/modules and does not require anything special besides PMF.
Tested on Armbian 24.xx
orange-pi-3g-iot-mtk.zip
Edited by ValdikSS
  • Author
Orange Pi Zero3.
CDTech CDW-20U5622 / AllWinner AW859, Unisoc UWE5622 (sc2355) chip: 2.4, 5 GHz 802.11a/b/g/n/ac 1x1 MU-MIMO, Bluetooth 5.0
Datasheet.
🤷 Maybe it supports WPA3-Enterprise AKM:5 (IEEE 802.1X with SHA-256), don't know the method to check
❌ Does not work for WPA3-Enterprise 192-bit mode: no support for GCMP-256, no support for WPA-EAP-SUITE-B-192 key_mgmtno WPA3-SAE support
Supports PMF for WPA2-PSK Station, but fails to configure AP with PMF.
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 12
        max scan IEs length: 2304 bytes
        max # sched scan SSIDs: 9
        max # match sets: 9
        RTS threshold: 2353
        Retry short limit: 10
        Retry long limit: 9
        Supported Ciphers:
                * TKIP (00-0f-ac:2)
                * CMAC (00-0f-ac:6)
                * 00-0f-ac:255
        Available Antennas: TX 0x1 RX 0x1
                 * IBSS
                 * managed
                 * AP
                 * P2P-client
                 * P2P-GO
                 * P2P-device
get_capability eap:
CCMP TKIP
RSN WPA
OPEN SHARED LEAP
IBSS AP
orange-pi-zero3-uwe5622.zip
Edited by ValdikSS
  • Author
Continuing.
Radxa Rock Pi S.
Realtek RTL8723DS, 2.4GHz 1T1R 802.11bgn SDIO WLAN with Bluetooth 4.2 Single-Chip Controller
Datasheet.
Proprietary Realtek 8723ds driver (v5.1.1.5_20523.20161209_BTCOEX20161208-1212, year 2016)
❌ Does not work in WPA3-Personal Only: no WPA3-SAE support, no PMF support (no CMAC support)
❌ Does not work in WPA3-Enterprise (IEEE 802.1X with SHA-256): no PMF support (no CMAC support)
❌ Does not work for WPA3-Enterprise 192-bit mode: no support for GCMP-256, no support for WPA-EAP-SUITE-B-192 key_mgmt, no PMF support (no CMAC support)
Tested on Radxa Rock Pi S image, Wed, 24 Jan 2024
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 9
        max # match sets: 0
        Retry long limit: 4
        Supported Ciphers:
                * TKIP (00-0f-ac:2)
                 * IBSS
                 * managed
                 * AP
                 * P2P-client
                 * P2P-GO
get_capability eap:
CCMP TKIP
RSN WPA
OPEN SHARED LEAP
IBSS AP
Router:
                  psm: no
        authenticated: yes
               txrate: 65
               rxrate: 52
               uptime: 10
              txbytes: 6438
              rxbytes: 1460
                   ht: 20
                 mode: 11n
                   gi: 800
                 rssi: -55
                  mcs: 7
                 txss: 1
                  _11: k
             security: wpa2-psk
Mainline rtw88 rtw_8723ds driver (SoftMAC driver, supports any feature the kernel/wpa_supplicant supports. Kernel 6.1):
✔️ Works in WPA3-Personal Only: WPA3-SAE + CCMP-128/GCMP-128/GCMP-256 for pairwise/group ciphers.
✔️ Should work in WPA3-Enterprise Only: will connect if the AP supports CCMP-128 or GCMP-256 for pairwise/group ciphers.
✔️ Works for WPA3-Enterprise 192-bit mode (supports GCMP-256).
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 4
        max scan IEs length: 2257 bytes
        max # match sets: 0
        Retry long limit: 4
        Device supports T-DLS.
        Supported Ciphers:
                * TKIP (00-0f-ac:2)
                * CCMP-256 (00-0f-ac:10)
                * GCMP-128 (00-0f-ac:8)
                * GCMP-256 (00-0f-ac:9)
                * CMAC (00-0f-ac:6)
                * CMAC-256 (00-0f-ac:13)
                * GMAC-128 (00-0f-ac:11)
                * GMAC-256 (00-0f-ac:12)
get_capability eap:
CCMP-256 GCMP-256 CCMP GCMP TKIP
CCMP-256 GCMP-256 CCMP GCMP TKIP WEP104 WEP40
NONE IEEE8021X WPA-EAP WPA-PSK WPA-EAP-SUITE-B WPA-EAP-SUITE-B-192 OWE DPP FILS-SHA256 FILS-SHA384 FT-FILS-SHA256 FT-FILS-SHA384 FT-PSK FT-EAP SAE
RSN WPA
OPEN SHARED LEAP SAE FILS_SK_WITHOUT_PFS FILS_SK_WITH_PFS
IBSS AP
Router:
                  psm: no
        authenticated: yes
               txrate: 65
               rxrate: 72
               uptime: 451
              txbytes: 13352
              rxbytes: 3779
                   ht: 20
                 mode: 11n
                   gi: 800
                 rssi: -58
                  mcs: 7
                 txss: 1
                  _11: k
                  _11: r
                  _11: v
                  pmf: yes
             security: wpa3-psk
radxa-rock-pi-s-rtl8723ds.zip
Edited by ValdikSS
  • Author
Wukong Pi, an Orange Pi Zero LTS clone.
AllWinner XR819, 2.4GHz 1T1R 802.11bgn.
Datasheet.
Open https://github.com/fifteenhex/xradio Armbian SoftMAC driver (1 Sep 2026), supports everything Linux kernel and wpa_supplicant supports.
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 2
        max # match sets: 0
        Retry long limit: 4
        Supported Ciphers:
                * TKIP (00-0f-ac:2)
                * CMAC (00-0f-ac:6)
get_capability eap:
RSN WPA
IBSS AP MESH
Router:
                  psm: no
        authenticated: yes
               txrate: 65
               rxrate: 65
               uptime: 223
              txbytes: 8617
              rxbytes: 4220
                   ht: 20
                 mode: 11n
                   gi: 800
                 rssi: -51
                  mcs: 7
                 txss: 1
                  _11: k
                  _11: v
                  pmf: yes
             security: wpa3-psk
Tested on Armbian sunxi 26.11.0-trunk.40 (fc4623bc6), 6.18.49-current-sunxi
orange-pi-zero-xr819.zip
Edited by ValdikSS
  • Author
ArmSoM P2pro.
Ampak AP6256, Synaptics SYN43456 (Broadcom licensee, BCM43456). 2.4, 5 GHz 802.11a/b/g/n/ac 1x1 SISO, UART/PCM for Bluetooth 5.2
Datasheets: [1], [2]
bcmdhd module @ Kernel 5.10.110, firmware: Aug 25 2022 12:38:28 version 7.45.96.150 (g31bd2ca8) FWID 01-af0bb8b0 es7.c5.n4.a3
❌ Does not work in WPA3-Personal Only: fails to associate, seems to be a known bug in driver/firmware, affects Raspberry Pi 4/5 as well
✔️ Should work in WPA3-Enterprise (supports PMF, CCMP-128 and GCMP-256 for pairwise/group ciphers)
✔️ Should work in WPA3-Enterprise 192-bit mode (supports PMF, GCMP-256, WPA-EAP-SUITE-B-192)
Confirmed SAE not working for BCM/SYN43456 also on Raspberry Pi 400 (Raspberry OS, kernel 6.18.39), Orange Pi 4a (Armbian kernel 7.1.13, AurealNix v0.4.1 kernel 6.18.44).
# iw phy
Wiphy phy0
        wiphy index: 0
        max # scan SSIDs: 10
        max scan IEs length: 2048 bytes
        max # match sets: 0
        Retry long limit: 4
        Device supports roaming.
        Supported Ciphers:
                * TKIP (00-0f-ac:2)
                * CMAC (00-0f-ac:6)
                * 00-90-4c:0
                 * IBSS
                 * managed
                 * AP
                 * P2P-client
                 * P2P-GO
                 * P2P-device
get_capability eap:
NONE IEEE8021X WPA-EAP WPA-PSK WPA-EAP-SUITE-B WPA-EAP-SUITE-B-192 OWE DPP FT-PSK
RSN WPA
Mode[A] Channels: 36 40 44 48 52 56 60 64 149 153 157 161 165
IBSS AP
Router:
          station:
                  mac: b8:13:32:cf:b4:e4
                   ap: WifiMaster1/AccessPoint0
                  psm: no
        authenticated: yes
               txrate: 60
               rxrate: 54
               uptime: 773
              txbytes: 159775
              rxbytes: 26650656
                   ht: 40
                 mode: 11ac
                   gi: 400
                 rssi: -79
                  mcs: 3
                 txss: 1
                  ebf: yes
                dl-mu: no
                  _11: k
                  _11: r
                  pmf: yes
             security: wpa2-psk
Tested on armsom-p2pro-debian-bullseye-base-arm64-20241101 image.
armsom-p2pro-ap6256.zip
Edited by ValdikSS
Board: Orange Pi 5B (RK3588S) — onboard AP6275P module
Chip: Broadcom BCM43752 802.11ax 2×2 dual-band, PCIe (14e4:449d rev 02); BT 5.x on UART
OS / kernel: Ubuntu 24.04 (Pi Desktop, ubuntu-rockchip lineage), vendor BSP 6.1 — not Armbian, but the same vendor WiFi stack Armbian's vendor-rk35xx kernels carry
Driver: vendor bcmdhd 101.10.591.52.27 (2024-04); ethtool -i reports wl — not brcmfmac. Firmware wl0: Jul 12 2022 version 18.35.387.23.146 (g412cc5ec) FWID 01-93c53be6
Supplicant: wpa_supplicant 2.10 · NetworkManager 1.46
iw phy (security-relevant):
Supported Ciphers: WEP40, WEP104, TKIP, CCMP-128, CMAC, GMAC-256, GMAC-128, CMAC-256, GCMP-128, GCMP-256
Device supports SAE with AUTHENTICATE command
interface modes: IBSS, managed, AP, P2P-client, P2P-GO, P2P-device · HE MAC caps present (802.11ax)
wpa_cli get_capability:
key_mgmt:   … FT-SAE SAE OWE WPA-EAP-SUITE-B-192 WPA-PSK-SHA256 WPA-EAP-SHA256 …
pairwise:   GCMP-256 CCMP GCMP TKIP
group_mgmt: AES-128-CMAC BIP-GMAC-128 BIP-GMAC-256 BIP-CMAC-256
auth_alg:   OPEN SHARED LEAP SAE
WPA3-Personal only (SAE, PMF required): ✅ works
key_mgmt=SAE  pmf=2  pairwise_cipher=CCMP  group_cipher=CCMP  wpa_state=COMPLETED  freq=5745
signal -47 dBm · tx bitrate 433.0 MBit/s · DHCP lease obtained, gateway reachable
WPA3-Enterprise: not tested (no RADIUS in this lab)
WPA3-Enterprise 192-bit: not tested — the required cipher set (GCMP-256 + BIP-GMAC-256 + SUITE-B-192 AKM) is advertised by both driver and supplicant
Test environment: UniFi UDM SE, test SSID set to WPA3-only / PMF Required, 5 GHz ch 149
Notes for other OPi 5B owners: iw is missing from some images (apt install iw). The same module's Bluetooth side has a long-standing firmware-load/coex race on this board — fixes and an auto-heal service live in the Pi Desktop repo.
  • Author
11 часов назад, defcom5-rockchip сказал:
Could you please post the output of `iw dev` and wpa_cli commands, as I do? The raw output is useful for the future reference.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
