August 26Aug 26 Hi everyone, I'm trying to boot Armbian on a TiVo Stream 4K (Model: IPA1114HDW, Board: SEI500BS/Pyxis, SoC: S905X2, Android TV 10). I've flashed S905X2-compatible images (like Armbian_23.02.2...6.1.11) using Rufus/Etcher/Armbian Imager with different DTBs, but I cannot get it to boot from SD or USB. Toothpick method (short press): Enters Fastboot (limited permissions, no flash/dump). Toothpick method (long press): Enters USB Burning Mode. adb reboot bootloader and adb reboot recovery work, but there is no root access via ADB. It seems external boot is disabled, U-Boot is locked, or secure boot is enforced. My next step is hooking up a UART USB-TTL adapter to grab the boot logs and check if U-Boot can be interrupted. Has anyone successfully run Armbian or Linux on this exact SEI500BS/Pyxis board? Thanks!
