Skip to content
View in the app
Armbian Community Forums
[Luckfox Lyra Zero W] "apt upgrade" breaks dkms-installed aic8800 driver due to kernel update
Featured Replies
Hi, after doing an "apt upgrade" on my Luckfox Lyra Zero W running "Armbian 26.11.0 Minimal (Trixie)" on kernel 6.1.115-vendor-rockchip, I got an error mid-upgrade: The aic8800-usb driver did not recompile for the new kernel version:
Setting up linux-image-vendor-rockchip (26.11.0-trunk.37) ...
Armbian 'linux-image-vendor-rockchip' for '6.1.172-vendor-rockchip': 'postinst' starting.
The kernel is built without module signing facility, modules won't be signed
Autoinstall of module aic8800-usb/5.0+git20260123.5f7be68d-8 for kernel 6.1.172-vendor-rockchip (armv7l)
Building module(s)....................(bad exit status: 2)
Failed command:
make -j3 KERNELRELEASE=6.1.172-vendor-rockchip -C /lib/modules/6.1.172-vendor-rockchip/build M=/var/lib/dkms/aic8800-usb/5.0+git20260123.5f7be68d-8/build/USB/driver_fw/drivers/aic8800 && make -C /lib/modules/6.1.172-vendor-rockchip/build M=/var/lib/dkms/aic8800-usb/5.0+git20260123.5f7be68d-8/build/USB/driver_fw/drivers/aic_btusb
Error! Bad return status for module build on kernel: 6.1.172-vendor-rockchip (armv7l)
Consult /var/lib/dkms/aic8800-usb/5.0+git20260123.5f7be68d-8/build/make.log for more information.
Autoinstall on 6.1.172-vendor-rockchip failed for module(s) aic8800-usb(10).
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
run-parts: /etc/kernel/postinst.d/dkms exited with return code 1
The make error log shows that dkms could not find "scripts/basic/fixdep", which to me looks like an ordering issue (compiling the module before making the kernel scripts). Simply running "dpkg --configure -a" after the upgrade re-compiled the module successfully, and all is fine now.
I'm making this post since a) I have no idea where else to report this issue and b) to help people who might be affected by this problem as well.
Kind regards,
trayshar
luckfox-lyra-zero-w_apt upgrade.log
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
