September 7Sep 7 Hi, I'm incurring in a issue with updates of the board to Armbian 26.8. The new kernel or updates break the board connectivity gets lost, since the board boots up, the LAN port blinks but it doesn't set any IP Address. The board works in headless mode with the Debian 13 CLI UFS image, so I can't debug it using a monitor. Has anyone the same issue? How to reproduce 1.Flash the recommended Debian 13 Trixie CLI Image from Armbian Website 2.Start the board normally, in headless mode 3.login with ssh 4.set a new user account 5.Run apt update && apt dist-upgrade -y and then reboot 6.Board is not reachable anymore via ssh, board has no IP address, even when setting static IP Edited September 7Sep 7 by madduci added details
