Skip to content
View in the app
Armbian Community Forums
systemd-journald writes to /run/log/journal instead of persistent storage with Armbian ramlog
Featured Replies
I am trying to determine whether this is expected behavior or a bug/ordering issue in Armbian's armbian-ramlog.
My /etc/systemd/journald.conf contains:
Storage=persistent
SystemMaxUse=20M
Persistent journal storage is available:
/var/log/journal -> /var/log.hdd/journal
and /var/log.hdd is mounted read-write.
However, after every reboot, systemd-journald initially writes to /run/log/journal.
I verified this directly:
sudo ls -l /proc/$(pidof systemd-journald)/fd | grep journal
Immediately after boot I get:
33 -> /run/log/journal/d1d6e2a49fd24499b90cb6d5198cb70e/system.journal
So journald is actually holding the runtime journal open.
The system has armbian-ramlog enabled. Its unit contains:
Before=rsyslog.service sysinit.target syslog.target RequiresMountsFor=/var/log /var/log.hdd
Interestingly, running this manually:
sudo journalctl --flush
immediately switches journald to persistent storage.
Afterwards:
shows:
33 -> /var/log.hdd/journal/d1d6e2a49fd24499b90cb6d5198cb70e/system.journal 34 -> /var/log.hdd/journal/d1d6e2a49fd24499b90cb6d5198cb70e/user-1000.journal
So the persistent filesystem is definitely accessible and writable.
This makes me wonder:
Is armbian-ramlog causing systemd-journald to remain on /run/log/journal after boot, or is this simply an ordering issue involving systemd-journal-flush.service?
In other words, should armbian-ramlog allow/trigger the journal flush automatically once /var/log.hdd is mounted?
Any insight from the Armbian side would be appreciated.
Your debugging is already spot on — journald only stays on /run/log/journal until something runs journalctl --flush, and the fact that a manual flush works proves the storage side is fine. So this is purely an ordering problem: systemd-journal-flush.service runs early in boot, and on Armbian images /var/log.hdd is typically mounted by the armbian-ramlog machinery, which replaces /var/log with its tmpfs/overlay quite late compared to when the flush service expects a real /var/log/journal to exist. If the flush fires while ramlog hasn't finished restoring the /var/log/journal symlink into /var/log.hdd, it silently gives up and journald keeps the runtime journal open — exactly what you're seeing in /proc.
You can confirm by comparing timestamps: systemctl status systemd-journal-flush.service versus armbian-ramlog (or mount time of /var/log.hdd). The clean fix is a drop-in for the flush unit, something like After=armbian-ramlog.service plus RequiresMountsFor=/var/log.hdd, so flush waits until the persistent path is actually there. Alternatively, an override on the ramlog unit adding Before=systemd-journal-flush.service achieves the same ordering from the other side. Either way the runtime journal gets flushed on the next boot instead of being stranded in /run until a manual flush.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
