Skip to content
View in the app
Armbian Community Forums
OPI Lite wants to connect eth0
Featured Replies
I'm running a OPI Lite with debian jessie,
All works fine until i have to reboot, and that happens quiet often while testing software.
AFTER the boot i'm not able to reach the OPI via SSH, because the eth0 is activated ...and has a 169.x.x.x ip adress...
On the OPI Lite i can ONLY discover WIFI and no eth0 connector...So i go into the "nmtui" tool and "disactivate" the eth0...
Than i have access again via the wifi to my OPI lite.
How can i completely disable the eth0, that only WIFI connects to my network?
I didn't find about this behavior on the web, anyone else have that problem?
Kind regards from Hans F4VSJ
I know the 169.x.x.x addresses only from Windows, when the Interface is set to DHCP, but here is no DHCP-Server.
I did found a way to deactivate eth0 via nmtui, but if you will try of the follwoing commands from the named url in the
/etc/rc.local before the command 'exit 0'
Page-URL: https://www.thegeekdiary.com/how-to-configure-and-manage-network-connections-using-nmcli/
find the part 'Example 2 : The nmcli connection up|down Commands'
First use the command to find the name of your connection:
# nmcli connection show
NAME         UUID                                  TYPE            DEVICE
Wired_conn1  dba7561b-dd02-3b58-92c0-07ce94b6250f  802-3-ethernet  eth0
Wired_conn2  bbe539aa-5042-4d28-a0e6-2a4d4f5dd744  802-3-ethernet  eth1
 and then add the follwing command for the name of your connection in your /etc/rc.local (before exit 0):
#  nmcli connection down id Wired_conn1
Connection 'Wired_conn1' successfully deactivated
PS: # is the root-prompt - dont use it in /etc/rc.local because then it will be a commentar :(
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
