Skip to content
View in the app
Armbian Community Forums
Cubieboard2 after boot is visible on network, sometimes not
Featured Replies
Hi
If i boot my cubieboard2, sometimes it's visible on network, and reachable, sometimes not at all. After that, it isn't changes. No problem with the LAN cable, i've tried two. Also the speedtest shows the maximum bandwidths in both directions (~92 mbit/sec).
The system boots always, as i see from logs.
Here is from the log:
sudo cat /var/log/messages | grep ether
Feb 23 09:14:43 localhost kernel: [    2.059648] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
Feb 23 09:14:43 localhost kernel: [    2.059661] sun7i-dwmac 1c50000.ethernet: no reset control found
Feb 23 09:14:43 localhost kernel: [    2.059690] sun7i-dwmac 1c50000.ethernet: no regulator found
Feb 23 09:14:43 localhost kernel: [    2.059979] sun7i-dwmac 1c50000.ethernet: Version ID not available
Feb 23 09:14:43 localhost kernel: [    2.059991] sun7i-dwmac 1c50000.ethernet:  DWMAC1000
Feb 23 09:14:43 localhost kernel: [    2.059999] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
Feb 23 09:14:43 localhost kernel: [    2.060006] sun7i-dwmac 1c50000.ethernet: Normal descriptors
Feb 23 09:14:43 localhost kernel: [    2.060012] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
Feb 23 09:14:44 localhost kernel: [   10.408311] sun7i-dwmac 1c50000.ethernet eth0: device MAC address 86:98:a8:6e:1b:69
Feb 23 09:14:44 localhost kernel: [   10.431624] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support found
Feb 23 09:14:44 localhost kernel: [   10.431638] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabled
Feb 23 09:14:44 localhost kernel: [   10.431648] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters available
Feb 23 09:14:44 localhost kernel: [   10.431657] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
Feb 23 09:14:45 localhost kernel: [   11.456229] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Feb 23 09:17:03 localhost kernel: [    2.059659] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
Feb 23 09:17:03 localhost kernel: [    2.059671] sun7i-dwmac 1c50000.ethernet: no reset control found
Feb 23 09:17:03 localhost kernel: [    2.059701] sun7i-dwmac 1c50000.ethernet: no regulator found
Feb 23 09:17:03 localhost kernel: [    2.059985] sun7i-dwmac 1c50000.ethernet: Version ID not available
Feb 23 09:17:03 localhost kernel: [    2.059999] sun7i-dwmac 1c50000.ethernet:  DWMAC1000
Feb 23 09:17:03 localhost kernel: [    2.060006] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
Feb 23 09:17:03 localhost kernel: [    2.060013] sun7i-dwmac 1c50000.ethernet: Normal descriptors
Feb 23 09:17:03 localhost kernel: [    2.060019] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
Feb 23 09:17:05 localhost kernel: [   11.008585] sun7i-dwmac 1c50000.ethernet eth0: device MAC address ca:33:74:13:5c:2b
Feb 23 09:17:05 localhost kernel: [   11.033583] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support found
Feb 23 09:17:05 localhost kernel: [   11.033600] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabled
Feb 23 09:17:05 localhost kernel: [   11.033611] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters available
Feb 23 09:17:05 localhost kernel: [   11.033620] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
Feb 23 09:17:06 localhost kernel: [   12.064089] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Feb 23 09:17:03 localhost kernel: [    2.060202] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
Feb 23 09:17:03 localhost kernel: [    2.060213] sun7i-dwmac 1c50000.ethernet: no reset control found
Feb 23 09:17:03 localhost kernel: [    2.060260] sun7i-dwmac 1c50000.ethernet: no regulator found
Feb 23 09:17:03 localhost kernel: [    2.060547] sun7i-dwmac 1c50000.ethernet: Version ID not available
Feb 23 09:17:03 localhost kernel: [    2.060559] sun7i-dwmac 1c50000.ethernet:  DWMAC1000
Feb 23 09:17:03 localhost kernel: [    2.060567] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
Feb 23 09:17:03 localhost kernel: [    2.060574] sun7i-dwmac 1c50000.ethernet: Normal descriptors
Feb 23 09:17:03 localhost kernel: [    2.060580] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
Feb 23 09:17:05 localhost kernel: [   10.659666] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support found
Feb 23 09:17:05 localhost kernel: [   10.659682] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabled
Feb 23 09:17:05 localhost kernel: [   10.659692] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters available
Feb 23 09:17:05 localhost kernel: [   10.659701] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
Feb 23 09:17:06 localhost kernel: [   11.680327] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Feb 23 09:41:44 localhost kernel: [    2.059654] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
Feb 23 09:41:44 localhost kernel: [    2.059666] sun7i-dwmac 1c50000.ethernet: no reset control found
Feb 23 09:41:44 localhost kernel: [    2.059712] sun7i-dwmac 1c50000.ethernet: no regulator found
Feb 23 09:41:44 localhost kernel: [    2.059995] sun7i-dwmac 1c50000.ethernet: Version ID not available
Feb 23 09:41:44 localhost kernel: [    2.060006] sun7i-dwmac 1c50000.ethernet:  DWMAC1000
Feb 23 09:41:44 localhost kernel: [    2.060014] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
Feb 23 09:41:44 localhost kernel: [    2.060021] sun7i-dwmac 1c50000.ethernet: Normal descriptors
Feb 23 09:41:44 localhost kernel: [    2.060027] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
Feb 23 09:41:47 localhost kernel: [   10.794927] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support found
Feb 23 09:41:47 localhost kernel: [   10.794943] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabled
Feb 23 09:41:47 localhost kernel: [   10.794953] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters available
Feb 23 09:41:47 localhost kernel: [   10.794961] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
Feb 23 09:41:48 localhost kernel: [   11.808501] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Feb 23 10:06:08 localhost kernel: [ 1472.004740] sun7i-dwmac 1c50000.ethernet eth0: Link is Down
Feb 23 10:06:45 localhost kernel: [ 1508.868185] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Feb 23 10:17:03 localhost kernel: [    2.059849] sun7i-dwmac 1c50000.ethernet: PTP uses main clock
Feb 23 10:17:03 localhost kernel: [    2.059860] sun7i-dwmac 1c50000.ethernet: no reset control found
Feb 23 10:17:03 localhost kernel: [    2.059889] sun7i-dwmac 1c50000.ethernet: no regulator found
Feb 23 10:17:03 localhost kernel: [    2.060183] sun7i-dwmac 1c50000.ethernet: Version ID not available
Feb 23 10:17:03 localhost kernel: [    2.060195] sun7i-dwmac 1c50000.ethernet:  DWMAC1000
Feb 23 10:17:03 localhost kernel: [    2.060203] sun7i-dwmac 1c50000.ethernet: DMA HW capability register supported
Feb 23 10:17:03 localhost kernel: [    2.060210] sun7i-dwmac 1c50000.ethernet: Normal descriptors
Feb 23 10:17:03 localhost kernel: [    2.060216] sun7i-dwmac 1c50000.ethernet: Ring mode enabled
Feb 23 10:17:05 localhost kernel: [   10.606215] sun7i-dwmac 1c50000.ethernet eth0: No Safety Features support found
Feb 23 10:17:05 localhost kernel: [   10.606228] sun7i-dwmac 1c50000.ethernet eth0: RX IPC Checksum Offload disabled
Feb 23 10:17:05 localhost kernel: [   10.606238] sun7i-dwmac 1c50000.ethernet eth0: No MAC Management Counters available
Feb 23 10:17:05 localhost kernel: [   10.606247] sun7i-dwmac 1c50000.ethernet eth0: PTP not supported by HW
Feb 23 10:17:06 localhost kernel: [   11.616350] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
2 times it was reachable from network (2nd, and 4th boot), 2 times not. Anyone sees something?
Where is armbianmonitor -u ? Showing only errors is not sufficient.
I don't have this board to reproduce (also impossible due to unknown kernel u-boot version) nor its on the supported list ... you can try to install older versions of u-boot too see if that helps?
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
