sugatam
  1. Looks like both current and edge on sunxi64 are missing dvb support. Is this intentional? sunxi kernels include it, as do most other families.
  2. I updated my Rock-5b after a few months, but the latest edge kernel doesn't boot. Getting this on bootup: [ 38.709046] rockchip-pm-domain fd8d8000.power-management:power-controller: failed to get ack on domain 'gpu', val=0xaffff [ 38.710010] SError Interrupt on CPU5, code 0x00000000be000411 -- SError [ 38.710013] CPU: 5 UID: 0 PID: 449 Comm: (udev-worker) Tainted: G C 6.14.0-rc7-edge-rockchip64 #1 [ 38.710017] Tainted: [C]=CRAP [ 38.710018] Hardware name: Radxa ROCK 5B (DT) [ 38.710019] pstate: 404000c9 (nZcv daIF +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 38.710021] pc : _raw_spin_lock_irqsave+0x38/0x8c [ 38.710027] lr : regmap_lock_spinlock+0x18/0x2c [ 38.710031] sp : ffff800085b4b650 [ 38.710032] x29: ffff800085b4b650 x28: ffff800082263538 x27: ffff80007a891558 [ 38.710035] x26: 0000000000000001 x25: ffff000100d7b080 x24: ffff000100d9b898 [ 38.710037] x23: 0000000000000000 x22: 0000000000000001 x21: 0000000000000000 [ 38.710039] x20: 000000000000000c x19: 0000000000000000 x18: 00000000ffffffff [ 38.710042] x17: 66203a72656c6c6f x16: 72746e6f632d7265 x15: 776f703a746e656d [ 38.710044] x14: 6567616e616d2d72 x13: 000000000000030d x12: 00000000ffffffea [ 38.710046] x11: 0000000000000001 x10: 0000000000000001 x9 : ffff800082227770 [ 38.710048] x8 : 000000000002ffe8 x7 : c0000000ffffdfff x6 : 00000000000affa8 [ 38.710050] x5 : ffff800080adc9dc x4 : 0000000000000008 x3 : ffff800080adc450 [ 38.710052] x2 : 0000000000000001 x1 : 0000000000000000 x0 : ffff000100d9d400 [ 38.710055] Kernel panic - not syncing: Asynchronous SError Interrupt [ 38.710056] CPU: 5 UID: 0 PID: 449 Comm: (udev-worker) Tainted: G C 6.14.0-rc7-edge-rockchip64 #1 [ 38.710058] Tainted: [C]=CRAP [ 38.710059] Hardware name: Radxa ROCK 5B (DT) [ 38.710060] Call trace: [ 38.710062] show_stack+0x18/0x24 (C) [ 38.710066] dump_stack_lvl+0x38/0x90 [ 38.710069] dump_stack+0x18/0x24 [ 38.710071] panic+0x39c/0x3f4 [ 38.710075] nmi_panic+0x40/0x8c [ 38.710077] arm64_serror_panic+0x64/0x70 [ 38.710079] do_serror+0x3c/0x78 [ 38.710081] el1h_64_error_handler+0x30/0x48 [ 38.710085] el1h_64_error+0x6c/0x70 [ 38.710087] _raw_spin_lock_irqsave+0x38/0x8c (P) [ 38.710090] regmap_lock_spinlock+0x18/0x2c [ 38.710092] regmap_write+0x3c/0x78 [ 38.710095] rockchip_pd_power+0xf8/0x5e8 [ 38.710098] rockchip_pd_power_on+0x14/0x20 [ 38.710100] _genpd_power_on+0x98/0x18c [ 38.710103] genpd_power_on.part.0+0xa4/0x1ac [ 38.710106] __genpd_dev_pm_attach+0x1fc/0x304 [ 38.710108] genpd_dev_pm_attach+0x64/0x74 [ 38.710111] dev_pm_domain_attach+0x20/0x34 [ 38.710114] platform_probe+0x50/0xdc [ 38.710117] really_probe+0xc0/0x388 [ 38.710120] __driver_probe_device+0x7c/0x15c [ 38.710122] driver_probe_device+0x40/0x114 [ 38.710124] __driver_attach+0xf4/0x1fc [ 38.710126] bus_for_each_dev+0x74/0xd4 [ 38.710128] driver_attach+0x24/0x30 [ 38.710130] bus_add_driver+0x110/0x234 [ 38.710132] driver_register+0x60/0x128 [ 38.710135] __platform_driver_register+0x24/0x30 [ 38.710138] panthor_init+0x64/0x1000 [panthor] [ 38.710148] do_one_initcall+0x44/0x2a8 [ 38.710150] do_init_module+0x58/0x208 [ 38.710154] load_module+0x2000/0x20c0 [ 38.710156] init_module_from_file+0x84/0xc4 [ 38.710159] __arm64_sys_finit_module+0x1f4/0x2f8 [ 38.710161] invoke_syscall+0x48/0x110 [ 38.710164] el0_svc_common.constprop.0+0x40/0xe8 [ 38.710167] do_el0_svc+0x20/0x2c [ 38.710170] el0_svc+0x30/0xd0 [ 38.710173] el0t_64_sync_handler+0x144/0x168 [ 38.710176] el0t_64_sync+0x198/0x19c [ 38.710178] SMP: stopping secondary CPUs [ 38.710244] Kernel Offset: disabled [ 38.710245] CPU features: 0x380,00000070,00901250,8200720b [ 38.710247] Memory Limit: none [ 38.737861] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]--- Looks like this issue? https://patchwork.kernel.org/project/linux-rockchip/cover/20250220-rk3588-gpu-pwr-domain-regulator-v6-0-a4f9c24e5b81@kernel.org/ Are others are running into the same? Downgrading to kernel 6.12 works around this for the time being.
  3. I didn't build it, just installed the kernel it from the beta armbian repo via the following commands: apt-get install linux-dtb-collabora-rockchip-rk3588 linux-image-collabora-rockchip-rk3588 \ linux-headers-collabora-rockchip-rk3588 linux-u-boot-rock-5b-collabora \ armbian-bsp-cli-rock-5b-collabora My apt sources.list has: http://beta.armbian.com bookworm main bookworm-utils bookworm-desktop
  4. Did you try the the latest 6.9rc collabora branch? The build was just moved by ColourfulRhino yesterday from 6.7.0 to 6.9.0rc2. This kernel should have all the USB patches. I'm not near my OPi5 otherwise I'd have tried it.
  5. I'm glad you started this thread Gullik. I too am keen to see the vertical port and USB-C work. So far, running 6.8rc1, they don't. I haven't tried the collabora kernel yet on my OPi5, have you? That is off of collabora's branch, so has the latest patches that haven't been upstreamed yet, but the latest release of that is on 6.7.0. Separately, I have an issue with even the two horizontal USB ports. When using a 2.5" portable HDD, normally things work ok, but heavy activity, usually when I'm rsync'ing, leads to USB disconnects. Is anyone seeing this? [1294682.126819] usb 2-1: USB disconnect, device number 8 [1294682.127247] sd 3:0:0:0: [sdf] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s [1294682.127256] sd 3:0:0:0: [sdf] tag#0 CDB: Read(10) 28 00 00 0e 59 d8 00 00 08 00 [1294682.127261] blk_print_req_error: 4 callbacks suppressed [1294682.127263] I/O error, dev sdf, sector 940504 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [1294682.139910] device offline error, dev sdf, sector 940504 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 [1294682.139931] buffer_io_error: 256 callbacks suppressed [1294682.139934] Buffer I/O error on dev sdf1, logical block 117307, async page read [1294682.140082] device offline error, dev sdf, sector 361648 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [1294682.140105] device offline error, dev sdf, sector 361648 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 [1294682.140109] Buffer I/O error on dev sdf1, logical block 44950, async page read [1294682.140442] device offline error, dev sdf, sector 2235835648 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [1294682.140461] device offline error, dev sdf, sector 2235835648 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 [1294682.140464] Buffer I/O error on dev sdf1, logical block 279479200, async page read [1294682.140617] device offline error, dev sdf, sector 359856 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [1294682.140629] device offline error, dev sdf, sector 359856 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 [1294682.140632] Buffer I/O error on dev sdf1, logical block 44726, async page read [1294682.141065] device offline error, dev sdf, sector 941832 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [1294682.141114] device offline error, dev sdf, sector 941832 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 [1294682.141126] Buffer I/O error on dev sdf1, logical block 117473, async page read [1294682.141452] Buffer I/O error on dev sdf1, logical block 44798, async page read [1294682.159672] Buffer I/O error on dev sdf1, logical block 44683, async page read [1294682.162683] Buffer I/O error on dev sdf1, logical block 115454, async page read [1294682.164797] Buffer I/O error on dev sdf1, logical block 44930, async page read [1294682.170128] Buffer I/O error on dev sdf1, logical block 44756, async page read [1294683.623276] sd 3:0:0:0: [sdf] Synchronizing SCSI cache [1294683.623322] sd 3:0:0:0: [sdf] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK [1294683.899994] usb 2-1: new SuperSpeed USB device number 9 using xhci-hcd [1294683.918703] usb 2-1: New USB device found, idVendor=0480, idProduct=0900, bcdDevice= 3.15 [1294683.918714] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [1294683.918720] usb 2-1: Product: External USB 3.0
  6. Isn't the reason you created the "collabora" branch? Its unfortunately stuck at 6.7.0, but I was happily using it as it was getting all of Sebastian's (and team collabora's) updates before they were accepted upstream.
