mss
  1. Thanks a lot, It worked for me. You should add `extraargs=fsck.mode=force fsck.repair=yes` to `/boot/armbianEnv.txt` to force scan and automatically fix file system problems. otherwise It just scan and break boot sequence into intfs console and you should manually enter the command. Finial instruction : 1) Set fsck to scan on every boot: tune2fs -c 1 /dev/mmcblk0p1 2) Add bellow line to `/boot/armbianEnv.txt` extraargs=fsck.mode=force fsck.repair=yes
  2. I just build the build the driver for my RTL8188FTV that supported by rtl8188fu. It works as wifi hot spot but has some problems with nmcli . I share what is done and I hope it be useful for others. 0. Install dkms , make and git: apt install dkms make git 1. Remove any existing source and dkms config for module : dkms remove rtl8188fu/1.0 --all rm -f /lib/firmware/rtlwifi/rtl8188fufw.bin rm -f /etc/modprobe.d/rtl8188fu.conf rm -r /var/lib/dkms/rtl8188fu 2. Get current kernel version and install matching headers: uname -a My results are: Linux orangepipc 5.10.21-sunxi #21.02.3 SMP Mon Mar 8 00:28:04 UTC 2021 armv7l GNU/Linux so my matching kernel headers package would be `linux-headers-current-sunxi=21.02.3` . You might replace `sunxi` and `21.02.3` depending on your top results. I installed it by specifying version: apt install linux-headers-current-sunxi=21.02.3 3. Make kernels headers scripts: cd /usr/src/linux-headers-$(uname -r) make scripts 4. Clone arm branch from driver repository: git clone -b arm https://github.com/kelebek333/rtl8188fu rtl8188fu-arm 5. Disable power saving in make config. find and replace this variable in `./rtl8188fu-arm/Makefile` and set as below: CONFIG_POWER_SAVING = n CONFIG_WIFI_MONITOR = y 6. Build and install driver: ln -s /lib/modules/$(uname -r)/build/arch/arm /lib/modules/$(uname -r)/build/arch/armv7l dkms add ./rtl8188fu-arm dkms build rtl8188fu/1.0 dkms install rtl8188fu/1.0 cp ./rtl8188fu/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/ # Known problems : - ` nmcli dev wifi list` not works. Refrences: - https://github.com/kelebek333/rtl8188fu/tree/arm#how-to-install-for-arm-devices - https://docs.armbian.com/User-Guide_Advanced-Features/#how-to-build-a-wireless-driver - https://forum.armbian.com/topic/13628-help-me-to-setup-a-wifi-ap-via-command-line/?do=findComment&comment=104106 - https://github.com/ulli-kroll/rtl8188fu - https://askubuntu.com/a/1131265/483814 - https://github.com/brektrou/rtl8821CU#arm-architecture-tweak-for-this-driver-this-solves-compilation-problem-of-this-driver
