alchemist
  1. yeah, after reformatting eMMC (using nand-sata-install), I have a blank armbian running on eMMC. Now I can push my backop on eMMC and roll again This helios64 has too much failures, I will transfer the disks back to the helios4 I still have, and the server software to a Intel N100 mini PC...
  2. OK , I can boot from USB. Let's see what happened... EDIT: and access to the eMMC and disk 1 (system + swap). Both seems OK. Will reformat eMMC and see what happens
  3. Hi! My Helios64 crashed, rebooted, then refuses to continue. Seems something is corrupted : the eMMC module? The eMMC contains the /boot folder, then the rootfs is on 1st disk, sda1. So I didn't lose anything, I guess. I will try to boot an microSD card with armbian and if it works, I will boot from it. With the sd card, it doesn't boot, I will disable eMMC with the jumper as documented in the wiki Is it fixable? Here are the startup messages: DDR Version 1.25 20210517 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1 Release Time: May 29 2020 17:36:36, version: 1.26 CPUId = 0x0 ChipType = 0x10, 351 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 SdmmcInit=0 1 StorageInit ok = 68635 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3335db8 signature is wrong recovery gpt... GPT 0x3335db8 signature is wrong recovery gpt fail! Trust Addr:0x4000, 0x58334c42 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xea92c RunBL31 0x40000 @ 95489 us NOTICE: BL31: v1.3(release):845ee93 NOTICE: BL31: Built : 15:51:11, Jul 22 2020 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1196): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2021.07-armbian (Feb 27 2022 - 08:44:53 +0000) SoC: Rockchip rk3399 Reset cause: POR DRAM: 3.9 GiB PMIC: RK808 SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: dw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. scanning bus for devices... Hit any key to stop autoboot: 0 Card did not respond to voltage select! : -110 switch to partitions #0, OK mmc0(part 0) is current device Scanning mmc 0:1... libfdt fdt_check_header(): FDT_ERR_BADMAGIC Card did not respond to voltage select! : -110 Scanning disk mmc@fe320000.blk... Disk mmc@fe320000.blk not ready Scanning disk sdhci@fe330000.blk... Found 2 disks No EFI system partition dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busBootOrder not defined EFI boot manager: Cannot load any image starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 4!? 5 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device scanning bus for devices... Device 0: unknown device dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_i nit: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: pxeuuid dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_i nit: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_i nit: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/0000 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_i nit: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/000 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_i nit: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/00 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_i nit: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/0 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, h registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_i nit: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-rk3399-helios64 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_i nit: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm-rk3399 dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/default-arm dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busmissing environment variable: bootfile Retrieving file: pxelinux.cfg/default dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busConfig file not found dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio busNo ethernet found. dw_dm_mdio_init: mdio node is missing, registering legacy mdio busdw_dm_mdio_init: mdio node is missing, registering legacy mdio bus=>
  4. I am stuck on pwm->chipdata that is no more accessible in 6.10 I am no linux expert, just have good C knoledge So I will stay on kernel 6.6 for now.
  5. Hi, I am trying to update the patch for kernels 6.10 and 6.11 (same code). My first try was not successful (compile error), I will try again, I think I've understood what the patch will do, but there are a lot off differences between kernel versions 6.6 and 6.10, maybe some new lines need to be patched too. Once it compiles and runs fine on my helios 4, I will provide the patch 😉 Kind regards, Xavier.
  6. Hi @Heisath I saw that the mvebu kernel patches exist for kernel 6.10 but the Helios4 fan patch has been disabled what is the status of this patch for kernel 6.10 ? How can I help for? Xavier
  7. Hi, I am testing kernel 6.7 and I don't have crashes for now. It seems stable. Will confirm it after some weeks of operations.
