- Helios64 - Armbian 23.08 Bookworm issues (solved)
@BipBip1981 did you perform a clean install or update? I'm still using the following combination and am considering updating... 23.08.0-trunk Bookworm with Linux 6.6.8 I've had repeated connection problems over the last few months, which meant I couldn't access it via smb and all my backup jobs went wrong. However, it has been running stably again for some time now, which is very strange.
my bookworm installation is now over 1 year ago, has there been any further optimization in that time that should be adopted? Which setup combination is currently the most stable? Armbian 23.08.0-trunk Bookworm with Linux 6.6.8-edge-rockchip64 user@helios64:~# uname -a Linux helios64 6.6.8-edge-rockchip64 #1 SMP PREEMPT Wed Dec 20 16:02:07 UTC 2023 aarch64 GNU/Linux I have been successfully connecting my Helios64 to a 2.5G Unifi switch for some time now and recently noticed that it kept interrupting the transfer when transferring files via 1G client. I then deactivated the scatter/gather offloading option, but did not yet adjust the /etc/rc.local as described here...
now that OMV is finally installable on the Bookworm image from @ebin-dev (hopefully a proper fix will come from the OMV devs soon) I would like to share the changes you have made to the system for the Helios64. Here are my optimizations... CPU Frequency: Since only 2 of the 6 cores of the Helios64 can reach the max of "1800000", the general max setting must unfortunately be set to a value below which all 6 cores can reach. CPU 1: Microarchitecture: Cortex-A53 Max Frequency: 1.416 GHz Cores: 4 cores Features: NEON,SHA1,SHA2,AES,CRC32 CPU 2: Microarchitecture: Cortex-A72 Max Frequency: 1.800 GHz Cores: 2 cores Features: NEON,SHA1,SHA2,AES,CRC32 Theoretically, all 6 cores can handle a max of "1416000", but unfortunately there have also been frequent problems with this, so a value of max "1200000" is recommended for a stable system. root@helios64:~# cat /etc/default/cpufrequtils ENABLE="true" GOVERNOR="ondemand" MAX_SPEED="1200000" MIN_SPEED="408000" root bashrc In order to be able to use the bashrc with the root user, the following .profile file must be created in the /root directory with the following content... root@helios64:~# cat .profile if [ "$BASH" ]; then if [ -f ~/.bashrc ]; then . ~/.bashrc fi fi mesg n || true Docker Fix to fix the problem the line with ledtrig-netdev must be commented out so that containers can be started... root@helios64:~# cat /etc/modules-load.d/modules.conf lm75 #ledtrig-netdev Fancontrol: Here I have the following optimizations of the Fancontrol settings from a user from here... root@helios64:~# cat /etc/fancontrol # Helios64 PWM Fan Control Configuration # Temp source : /dev/thermal-cpu INTERVAL=10 FCTEMPS=/dev/fan-p6/pwm1=/dev/thermal-cpu/temp1_input /dev/fan-p7/pwm1=/dev/thermal-cpu/temp1_input MINTEMP=/dev/fan-p6/pwm1=45 /dev/fan-p7/pwm1=45 MAXTEMP=/dev/fan-p6/pwm1=110 /dev/fan-p7/pwm1=110 MINSTART=/dev/fan-p6/pwm1=25 /dev/fan-p7/pwm1=25 MINSTOP=/dev/fan-p6/pwm1=20 /dev/fan-p7/pwm1=20 #MINPWM=20 MINPWM=/dev/fan-p6/pwm1=20 /dev/fan-p7/pwm1=20 MAXPWM=/dev/fan-p6/pwm1=120 /dev/fan-p7/pwm1=120 after the change restart the fancontrol.service with... root@helios64:~# systemctl restart fancontrol.service LED State: If the flashing of the blue status LEDs of the Helios64 bothers you, you can simply stop the service, then it's quiet... root@helios64:~# systemctl stop armbian-led-state.service Alternatively, you can also just stop the status LED from flashing heartbeat by changing the value from heartbeat to none... root@helios64:~# cat /etc/armbian-leds.conf [/sys/class/leds/helios64::status] trigger=none brightness=0 invert=0 Do you have other optimizations for the system or other values like me? Please share them here 😉
- Helios64 - Armbian Bookworm -> OMV 7 RC1 install problems (SOLVED)
- Helios64: Kernel oops when starting docker container
@Trillien could be due to the commands after the installation... line 345-347 omv-confdbadm populate 2>&1 | tee -a ${logfile} omv-salt deploy run hosts 2>&1 | tee -a ${logfile} fi also explains why your "workaround" probably works, since the part is skipped if OMV has already been installed... line 295-297, end with fi on line 347 # install openmediavault if not installed already omvInstall=$(dpkg -l | awk '$2 == "openmediavault" { print $1 }') if [[ ! "${omvInstall}" == "ii" ]]; then ... the DEV ryecoaaron from the script is currently looking at the script fortunately and will hopefully fix the problem in the next version. Do you use Docker? For me, Helios crashes when I try to start a container, even with the hello-world test image from Docker... docker run hello-world
@Trillien your command to clean up the install doesn't work... root@helios64:~# dpkg-reconfigure -a Unknown option: a Usage: dpkg-reconfigure [options] packages -u, --unseen-only Show only not yet seen questions. --default-priority Use default priority instead of low. --force Force reconfiguration of broken packages. --no-reload Do not reload templates. (Use with caution.) -f, --frontend Specify debconf frontend to use. -p, --priority Specify minimum priority question to show. --terse Enable terse mode. edit: The following command worked and then the script ran through without any problems... finally I have OMV 7 on the eMMC (boot) + SSD installation! dpkg-reconfigure openmediavault or do you perhaps mean the following command, which has at least the -a option... dpkg --configure -a
@Trillien I have monitored the installation with the following command to see when the frequency is changed and then when it crashes. Command to monitor the cpufrequtil file... while [ 1 ]; do sleep 1; clear; tail /etc/default/cpufrequtils; done at this point the cpufrequtils file is changed to the 0 values... /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/utils/pycrypto.py:26: DeprecationWarning: 'crypt' is deprecated and slated for removal in Python 3.13 import crypt /usr/lib/python3/dist-packages/salt/modules/linux_shadow.py:21: DeprecationWarning: 'spwd' is deprecated and slated for removal in Python 3.13 import spwd Deploying service configurations ... <<<<< here !!! Processing system modifications ... <<<<< or here !!! and at this point the cpufrequtils file is changed back to its own values... - modules.omv_conf - modules.omv_utils Summary for helios64 ------------ Succeeded: 4 (changed=4) Failed: 0 ------------ Total states run: 4 Total run time: 3.700 s Summary for helios64 ------------ Succeeded: 6 (changed=5) Failed: 0 ------------ Total states run: 6 Total run time: 22.648 s and exactly then the helios64 crashes/reboots directly. I'll take a look at the script that is executed at this point and see if it can be deactivated. edit: ok the installation of omv changes the cpufrequtils file at this point of the script... line 337 - 343... _log "Installing openmediavault..." aptFlags="--yes --auto-remove --show-upgraded --allow-downgrades --allow-change-held-packages --no-install-recommends" apt-get ${aptFlags} install openmediavault 2>&1 | tee -a ${logfile} if [ ${PIPESTATUS[0]} -gt 0 ]; then _log "failed to install openmediavault package." exit 2 fi ... I'll go to the OMV forum and ask why this is done and whether it is really necessary, because changing the cpufrequtils without reboot kills the Helios! Here my OMV forum post: https://forum.openmediavault.org/index.php?thread/52156-omv-7-install-on-helios64-fails/
@Trillien you can also see the CPU frequencies in the sbc check... CPU 1: Microarchitecture: Cortex-A53 Max Frequency: 1.416 GHz Cores: 4 cores Features: NEON,SHA1,SHA2,AES,CRC32 CPU 2: Microarchitecture: Cortex-A72 Max Frequency: 1.800 GHz Cores: 2 cores Features: NEON,SHA1,SHA2,AES,CRC32
