klaute
  1. The cable is fine. Also tried a different one. I tested it with UART connected to my notebook. The system is available after I have disconnected the network cable. But I can see that some tasks running in docker container after a few seconds cause 100% CPU usage. And the load of the system is growing again and again. I guess that this will kind of „lock“ the device after a few minutes, this tasks are running as root. Thank you for the support and hint with the UART, now I can go on to figure out what the problem is with those tasks…
  2. With the comment I only want to say that I have tested the behavior with a second switch. The problem is that if the network cable is reconnected again, the orang pi is still not again available over network. I have to reboot it to have a working network connection. I try to connect to the serial port later. Thank you for your support!
  3. Hello, I‘m recently updated to Armbian 24.2.1 Bookworm with Linux 6.6.16-current-sunxi. The system is running fine but if I disconnect the network interface, the system gets stuck in kind of a dead loop. This behavior gave me the hint that my WiFi repeater is broken and needs to be exchanged. Anyway, the CPU temperature rises and no further interaction with the system is possible. If I disconnect it, from a normal operating switch, the OpiOne’s behavior looks the same. My problem with this behavior is that after reconnecting the network, it does not get back available, until I do a power cycle. I tried to read out the root of that problem out of the logs but didn’t had success yet. I have uploaded the monitor logs: https://paste.armbian.com/cuqayiyimi Further information: A cooler is attached to the CPU and my PSU is able to provide 6A current. I haven’t had a problem with this Orange Pi during the last 4 years of running an older outdated version of Armbian. I’m only running some docker container with only use minimum resources. I hope that this isn’t a duplicate, haven’t found other topics like that. best regards kai
