registr123
  1. I think I did. Let me know is it didn't work.
  2. Helios64 for sale. Works well. With battery. 2.5 lan mod haven't been done. Based in Germany.
  3. If anyone is interested I might sell mine.(In the process of building a rack nass) Works well, inc the battery pack. ( Germany. )
  4. ❯ dmesg | grep r8152 [ 14.455547] usbcore: registered new device driver r8152-cfgselector [ 14.671357] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 14.774179] r8152 2-1.4:1.0: load rtl8156a-2 v2 04/27/23 successfully [ 14.831885] r8152 2-1.4:1.0 eth0: v1.12.13 [ 14.832087] usbcore: registered new interface driver r8152 [ 14.906183] r8152 2-1.4:1.0 enx646266d00305: renamed from eth0 [ 20.052308] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 20.165729] r8152 2-1.4:1.0: load rtl8156a-2 v2 04/27/23 successfully [ 20.237442] r8152 2-1.4:1.0 eth0: v1.12.13 [ 20.982002] r8152 2-1.4:1.0 enx646266d00305: renamed from eth0 [ 45.044206] r8152 2-1.4:1.0 enx646266d00305: carrier on [ 319.888218] r8152 2-1.4:1.0 enx646266d00305: NETDEV WATCHDOG: CPU: 5: transmit queue 0 timed out 6412 ms [ 319.889163] r8152 2-1.4:1.0 enx646266d00305: Tx timeout [ 319.894396] r8152 2-1.4:1.0 enx646266d00305: Tx status -2 [ 319.894464] r8152 2-1.4:1.0 enx646266d00305: Tx status -2 [ 319.894525] r8152 2-1.4:1.0 enx646266d00305: Tx status -2 [ 319.894582] r8152 2-1.4:1.0 enx646266d00305: Tx status -2 [ 321.999005] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 1370.733798] r8152 2-1.4:1.0 enx646266d00305: NETDEV WATCHDOG: CPU: 5: transmit queue 0 timed out 6380 ms [ 1370.734704] r8152 2-1.4:1.0 enx646266d00305: Tx timeout [ 1370.737585] r8152 2-1.4:1.0 enx646266d00305: Tx status -2 [ 1370.737684] r8152 2-1.4:1.0 enx646266d00305: Tx status -2 [ 1370.737755] r8152 2-1.4:1.0 enx646266d00305: Tx status -2 [ 1370.737816] r8152 2-1.4:1.0 enx646266d00305: Tx status -2 [ 1372.846993] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd @ebin-dev Thanks. I have implemented the tweaks you pointed to. For me the problem persists. Maybe I have not done everything correctly. I will start from scratch. it seams that the the tweaks doubled the "size" - now I can transfer files up to 5G without the adapter hanging. Kinda usable, but still I will probably have to move back to the gigabit adapter.
  5. I did try anything I could find as a solution but with no luck. I guess it's back to 1GB port for now. Schade
  6. @jmanes Yes I did. ❯ dmesg | grep 2-1.4 [ 2.811429] usb 2-1.4: new SuperSpeed USB device number 3 using xhci-hcd [ 2.833769] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00 [ 2.833809] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 2.833826] usb 2-1.4: Product: USB 10/100/1G/2.5G LAN [ 2.833840] usb 2-1.4: Manufacturer: Realtek [ 2.833853] usb 2-1.4: SerialNumber: 000000001 [ 14.509784] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 14.843654] r8152 2-1.4:1.0: load rtl8156a-2 v2 04/27/23 successfully [ 14.943938] r8152 2-1.4:1.0 eth0: v1.12.13 [ 15.037724] r8152 2-1.4:1.0 enx646266d00305: renamed from eth0 [ 21.011116] r8152-cfgselector 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 21.096900] r8152 2-1.4:1.0: load rtl8156a-2 v2 04/27/23 successfully [ 21.168702] r8152 2-1.4:1.0 eth0: v1.12.13 [ 21.798235] r8152 2-1.4:1.0 enx646266d00305: renamed from eth0 [ 28.273526] r8152 2-1.4:1.0 enx646266d00305: carrier on I also lose ssh in fact all connections. Sometimes it recovers it left. Adapter restarting maybe. Also noticed - if the file is below 2 to 3 GB it seams to be working fine. Files larger than 3GB trigger the problem. So yes there seams to be some improvement.
  7. HI all, I have copied the 9 rtl_nic firmware files to /lib/firmware/rtl_nic , However the large files transfer problem still exist. v24.8.4 for Helios64 running Armbian Linux 6.6.47-current-rockchip64 what am I missing?
