- apt upgrade → Size + hash Sum mismatches → Mirror sync in progress?
I was simple download from link with Firefox ... .....Failed to fetch http://apt.armbian.com/pool/main/l/linux-6.6.60/linux-image-current-odroidxu4_24.11.1_armhf__1-S6ed4-D0531-P1633-C3a73H5845-HK01ba-V014b-B59f0-R448a.deb Could not resolve 'apt.armbian.com'... And then install from download folder
Second Odroid HC2 is up. This one boot from sd card and OS is on USB stick. I did all steps on sd card and did not copy anything to USB stick. Boot is ok and all my files and folder are ok. I did all that with local downloaded files without problem. Maybe it is DNS problem... Tnx @pauet for fix 👍
I cant go on.. root@debian:/# apt install linux-image-current-odroidxu4=24.11.1 Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages will be DOWNGRADED: linux-image-current-odroidxu4 0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded. Need to get 30.7 MB of archives. After this operation, 14.2 MB disk space will be freed. Do you want to continue? [Y/n] y Ign:1 http://apt.armbian.com bookworm/main armhf linux-image-current-odroidxu4 armhf 24.11.1 Ign:1 http://apt.armbian.com bookworm/main armhf linux-image-current-odroidxu4 armhf 24.11.1 Ign:1 http://apt.armbian.com bookworm/main armhf linux-image-current-odroidxu4 armhf 24.11.1 Err:1 http://apt.armbian.com bookworm/main armhf linux-image-current-odroidxu4 armhf 24.11.1 Could not resolve 'apt.armbian.com' E: Failed to fetch http://apt.armbian.com/pool/main/l/linux-6.6.60/linux-image-current-odroidxu4_24.11.1_armhf__1-S6ed4-D0531-P1633-C3a73H5845-HK01ba-V014b-B59f0-R448a.deb Could not resolve 'apt.armbian.com' E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? ....E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? - did not help 🤕
odroidhc2
