- Helios64 - Armbian 23.08 Bookworm issues (solved)
Thanks guys, Last time I used Armbian_23.5.4 with 5.15 kernel , and I had about 60 days of uptime. Today I switched for Armbian 24.05 with DTB patched . Im using ZFS so only what Im do, is working with older packages, and do a hold with future updates I have SMB and NFS configured, I ran some tests and everything looks very good. Even my power consumption is down (I have 2x WD RED 4TB + Exos 18TB + WD RED 14TB + 1 SSD) and now its about 23 W Currently I have 'previous' values of cpu freq: (to have some compare) root@helios64:~# cat /etc/default/cpufrequtils ENABLE=true MIN_SPEED=408000 MAX_SPEED=1200000 GOVERNOR=ondemand
I installed Armbian_23.5.4_Helios64_bookworm_current_6.1.36 and kernel helios64 6.6.8-edge-rockchip64. Generally it is ok. First from long time I do not need to limit my sata to 3gbit , and I using cpu governor : on demand with min: 408000 max: 1200000 . ,instead of performance 1416000 My configuration its little specific because Im using LUKS crypt on top of my ZFS mirror (2x 4TB) + 1 cache SSD + 2 hdd EXT4 encrypted with ZFS. I tested NFS yesterday , and I successfully downloaded ~ 700GB without any errors . only what is not working as expected, that running sbc-bench.sh , causing kernel panic . ( http://sprunge.us/3VLJNX ) I will still test it, but it good point to start. [ 3500.389590] Internal error: Oops: 0000000086000004 [#1] PREEMPT SMP [ 3500.390166] Modules linked in: governor_powersave governor_performance dm_crypt trusted asn1_encoder nfsv3 nfs fscache netfs rfkill lz4hc lz4 zram binfmt_misc zfs(PO) spl(O) snd_soc_hdmi_codec snd_soc_rockchip_i2s crct10dif_ce rockchip_vdec(C) hantro_vpu snd_soc_core rockchip_rga v4l2_vp9 leds_pwm snd_compress v4l2_h264 ac97_bus videobuf2_dma_contig v4l2_mem2mem snd_pcm_dmaengine videobuf2_dma_sg snd_pcm pwm_fan panfrost gpu_sched gpio_charger drm_shmem_helper videobuf2_memops videobuf2_v4l2 snd_timer rk_crypto videodev snd videobuf2_common nvmem_rockchip_efuse mc soundcore gpio_beeper ledtrig_netdev nfsd lm75 auth_rpcgss nfs_acl lockd grace sunrpc ip_tables x_tables autofs4 efivarfs raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear cdc_ncm cdc_ether usbnet r8152 rockchipdrm realtek dw_mipi_dsi dw_hdmi analogix_dp fusb302 drm_display_helper tcpm cec typec dwmac_rk stmmac_platform drm_dma_helper drm_kms_helper stmmac drm adc_keys pcs_xpcs [ 3500.398227] CPU: 4 PID: 0 Comm: swapper/4 Tainted: P C O 6.6.8-edge-rockchip64 #1 [ 3500.399007] Hardware name: Helios64 (DT) [ 3500.399362] pstate: 000000c5 (nzcv daIF -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 3500.399988] pc : psi_group_change+0xc8/0x358 [ 3500.400388] lr : psi_task_change+0x8c/0xbc [ 3500.400767] sp : ffff80008203bd60 [ 3500.401069] x29: ffff80008203bd70 x28: ffff800075e65000 x27: ffff800081cac8e8 [ 3500.401720] x26: ffff800081909d40 x25: 0000000000000000 x24: ffff800081907008 [ 3500.402368] x23: 0000000000000001 x22: 0000000000000000 x21: 0000000000000000 [ 3500.403015] x20: ffff0000f776ed40 x19: 0000000000000004 x18: 0000000000000000 [ 3500.403662] x17: ffff800075e65000 x16: ffff800082038000 x15: 0000000000000001 [ 3500.404309] x14: 0000000000000000 x13: ffff800081581d50 x12: ffff800081c89b68 [ 3500.404957] x11: 0000000000000040 x10: 0000000000000004 x9 : 0000032eff793e13 [ 3500.405605] x8 : ffff800081c8dd28 x7 : 0000000000000000 x6 : 000000001c036006 [ 3500.406252] x5 : 0000000000000001 x4 : 0000000000000001 x3 : 0000000000000001 [ 3500.406898] x2 : 0000000000000001 x1 : 0000000000000004 x0 : ffff0000f776ed40 [ 3500.407545] Call trace: [ 3500.407771] psi_group_change+0xc8/0x358 [ 3500.408131] psi_task_change+0x8c/0xbc [ 3500.408479] activate_task+0xcc/0x128 [ 3500.408818] ttwu_do_activate+0x58/0x274 [ 3500.409180] sched_ttwu_pending+0xe4/0x1c0 [ 3500.409557] __flush_smp_call_function_queue+0x14c/0x458 [ 3500.410042] generic_smp_call_function_single_interrupt+0x14/0x20 [ 3500.410594] ipi_handler+0x84/0x250 [ 3500.410920] handle_percpu_devid_irq+0xa4/0x230 [ 3500.411337] generic_handle_domain_irq+0x2c/0x44 [ 3500.411756] gic_handle_irq+0x50/0x128 [ 3500.412097] call_on_irq_stack+0x24/0x4c [ 3500.412458] do_interrupt_handler+0xd4/0xd8 [ 3500.412842] el1_interrupt+0x34/0x68 [ 3500.413173] el1h_64_irq_handler+0x18/0x24 [ 3500.413548] el1h_64_irq+0x64/0x68 [ 3500.413860] cpuidle_enter_state+0xc0/0x4bc [ 3500.414246] cpuidle_enter+0x38/0x50 [ 3500.414577] do_idle+0x1fc/0x270 [ 3500.414878] cpu_startup_entry+0x38/0x3c [ 3500.415238] secondary_start_kernel+0x128/0x148 [ 3500.415653] __secondary_switched+0xb8/0xbc [ 3500.416043] Code: 54fffec1 52800002 52800024 34000173 (8b224a80) [ 3500.416592] ---[ end trace 0000000000000000 ]--- [ 3500.417009] Kernel panic - not syncing: Oops: Fatal exception in interrupt [ 3500.417621] SMP: stopping secondary CPUs [ 3500.418110] Kernel Offset: disabled [ 3500.418425] CPU features: 0x1,00000208,3c020000,1000421b [ 3500.418903] Memory Limit: none [ 3500.419192] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
grek
