- Helios64 - Armbian Trixie with linux 6.18 (incl. opp-microvolt patch)
- Helios64 - Armbian 23.08 Bookworm issues (solved)
Hello @prahal with your voltage fix I have an uptime of 158 days. Without, maybe 3-4 days if it boots at all. Your other fixes are also great. But they don't have the same impact by far. Even if the voltage is not a 100% fix in your eyes, for most people it is a game changer and enables operation in the first place, so I am surprised that you see so little priority there. Please don't get me wrong, I'm very grateful for the fix, I just think it should be implemented first, as I think stable operation is more important than how an LED flashes
Thank you @ebin-dev same here, 6.6.29 (much more) stable with your dtb. I know we are all the community and can make changes but... is it possible for you to make a ticket/change request or as its called to add your changes to the main armbian image? so that we have a good running Helios out of the box? That would be fantastic!
Helios64 u-boot does not build anymore after we bumped to 2022.07
Kernel 5.15.93 (get not "stable" with 6x kernel) linux-u-boot-current-helios64_21.08.9_arm64.deb Uptime 20 Days (but kernel panic after ±30 Days) CPU Speed: MIN_SPEED=600000 MAX_SPEED=1200000 GOVERNOR=ondemand Systemusage: Fileserver (Mergerfs/Snapraid with 5 SSD+1USB HDD with daily diff/scrub/sync ) Webserver 1 Docker Container ./cpufreq-switching-2-b_delay_5000 allocated 64MB test: toggle freq before write 0/100 cpub_freq 600000 cpub_freq 816000 cpub_freq 1008000 cpub_freq 1200000 cpub_freq 1416000 cpub_freq 1608000 cpub_freq 1800000 cpub_freq 1608000 cpub_freq 1416000 cpub_freq 1200000 cpub_freq 1008000 cpub_freq 816000 cpub_freq 600000 cpub_freq 408000 cpub_freq 600000 cpub_freq 816000 cpub_freq 1008000 kernelpanic
Helios64: Kernel oops when starting docker container
hello mikeakers, you can test you memory with for i in $(seq 1 100);do python3 -c "import pkg_resources" || break;done it is possible that bootloader was also updated during the update to bookworm and that can be a problem if this run 5-6 times without errors you try to limit the cpu speed with armbian-config for me, my system only run "stable" with 600-1200mhz
- Helios64 u-boot does not build anymore after we bumped to 2022.07
snakekick
