ALIGMSTEN
  1. Hi @Dmytro Lazor, Sorry for responding late. Good to see you have found your way around, hopefully the out of the blocks baseline wasnt seen as condescending, was next to establish the prefix, suggest dumping the running tree etc. The prefix environment variable, as you have added, is the recomended way. Because today's armbian/allwinner associates all h61x soc's under the h616 prefix you have to pay attention to your particular hardware. The prefix status quo is less of a bug, and more a standing choice of the present framework, the ideology is that anyone who steps into the domain, should know what they are doing, and therefore as you have shown, will navigate. Best of luck...
  2. Hello @Dmytro Lazor UART is enabled by default, you can use a usb to ttl converter at a baud rate 115200 to connect to a serial consel. Please be more specific what you are trying to achieve?
  3. @fever_wits raise your concerns and potential contributions here and hopefully someone like minded will have a conversation, other than that look at past support for the board, and ping their attention here...
  4. I don't know these boards at all, please take as an idea of experimentation, ordinarily you would have to look for differences in both the kernel (drivers) and dtb/dtsi (nodes), and where the opp tables are located. Best of luck!
  5. Hello all, in that context it possible to extend the opp points up to 1800 Mhz in the table. The original idea was to incorporate "turbo mode" so that the changes can be made in user space by choice. I don't know how stable that might be overall, perhaps its now time to introduce those options for h616/8 boards. EDIT: If remembered correctly the GPU tables were available as patch, recently removed, perhaps I'm wrong, haven't as of now checked.
